VWVortex.com - Cabrio project for the wifey... build thread
    Page 15 of 16 FirstFirst ... 5111213141516 LastLast
    Results 351 to 375 of 381
    Thread: Cabrio project for the wifey... build thread
      Apr 2nd, 2004
      near Rochester NY
      05 Allroad 2.7T,13 GTI, 93 Cabriolet, 2009 Silverado
      03-22-2017 10:42 AM #351
      Quote Originally Posted by drkreign View Post
      Love the work and attention to detail but I have to ask, why run the brake lines inside the car and not underneath it? I would think after passengers or the first time the top leaks and moisture gets trapped near the lines you could have a rather large mess. Not knocking at all, just curious on your choice
      I dont forsee any issues with corrosion, Ive used all ss fittings and the nicopp line is VERY corrosion resistant.
      Ive done this purely for aesthetics.
      The top can only leak if you take it out in the rain.
      Dan
      Apr 2nd, 2004
      near Rochester NY
      03-22-2017 10:44 AM #352
      Finished trimming and flaring the 3 output lines last night. I also played around with some zip ties, which hold them together surprisingly well. I still need to come up with at least one mount for the firewall.
      Then it was time to tackle the input lines. Im not really happy with how these turned out. 1. the bulkheads are just so damn tall and 2. id like a little more clearance to the steering shaft (yes, I could bend them away more). So I ordered some electroless nickel plated 90 deg bulkheads this am. Ill need to have the engine bay side flange redone to accommodate the nuts and then hope like hell one out of the 6 choices allows the 90 to be keyed correctly inside (I can also shim them some if necessary).
      Note: yes, one of the bulkhead fittings i had to substitute with a bolt as I left one at work.
      Dan
    3. Member oopseyesharted's Avatar
      Mar 2nd, 2005
      Cleveland "Westside"
      07' Rabbit & 86' Cabby
      03-23-2017 06:38 AM #353
      Those lines look great. Does that line running behind the accelerator pedal come in contact with the pedal?
      Nothing interesting here.
      Apr 2nd, 2004
      near Rochester NY
      03-23-2017 10:12 PM #354
      Quote Originally Posted by oopseyesharted View Post
      Nah. It cant hit even without the plastic stop in the carpet.
      Dan
      Apr 2nd, 2004
      near Rochester NY
      03-27-2017 01:23 PM #355
      Wasnt digging the dumb bends on the input lines at the firewall so I picked up some nickel plated bulkhead 90s. It turned out SO much better.
      With that done, I whipped up the rear crossover line and bracket. Im still deciding on what to use for clamps, hence its just floating right now.
      There will be no hard line on the drivers side, the braided line from the caliper will just extend right to the tee.
      And hose routing on the pass side around the surge tank and thru the axle beam
      Finally, I was able to work out routing of the ebrake cables without getting crazy and completely re-routing them. I just need the next size longer, 1800mm vs 1730mm. They are on order. I had to do a small notch in the fuel filter bracket (still needs a tiny bit more clearance) and massaged the corner of the gas tank a bit to add a small channel.
      Dan
      Apr 2nd, 2004
      near Rochester NY
      03-29-2017 10:27 AM #356
      Test fit a wheel last night to both verify my axle spacer measurements were right and also to see how much wheel clearance I had for the axle beam brace "towers".
      Perfect fit, and no rubbing. I know very un-vw.
      With that I welded up these little towers. I happened to have the rod ends and bar "in stock", leftovers from cavy projects I guess.
      Trying to decide where to mount them. I really like them over the shock mount, but then they could get filled up with water and whatever. Im thinking a drain hole might be good enough to keep water from washes drained. Also unsure if the swaybar mount "lollipop" bolt is long enough to go through the extra metal.
      I dont know how I took this to be powder coated years ago with the condition of the pass side shock mount area. Its pretty hammerd (literally). At least I can address that now as well since its going to need to be re-coated.
      Dan
      Apr 2nd, 2004
      near Rochester NY
      04-03-2017 10:27 AM #357
      Was never a huge fan of the rear bumper cover or the huge tow hooks. The bumper flap in had a big crack right in the middle, so I decided to do a little trimming. At some point I may come up with a simple diffuser but for now just having that middle flap cut out and the tow hooks gone is a huge improvement.
      So long ugly ass tow hooks
      I think it will be pretty business looking once the bracing is in.
      Next was time to fix the pass side shock mount area on the beam. How I ever took this to powder 6 years ago Ill never know. It was very bent up and beat to hell. Must be someone couldnt get the shock out at one time. A little beating with a BFH, welding, grinding, and redrilling and its pretty close to normal.
      Also got the second brace tower welded up. Decided not to mount them over the shock hole. To keep them from filling up with water I welded up the oe hole in the beam, then tacked the towers on
      Autotech swaybar and longer tie rods will be here by thursday so I can finish up this beam and get everything back to powder sat am.
      Dan
    8. 04-07-2017 05:01 PM #358
      nice build man, cant wait to see more progress
    9. Junior Member Mr.Pink1942's Avatar
      Mar 15th, 2009
      BFE... 30 min from the border of Canada
      2000 Golf TDI, 2002 Jetta TDI, 2001 Jetta
      04-12-2017 08:47 PM #359
      Awesome work.
      Apr 2nd, 2004
      near Rochester NY
      04-17-2017 10:26 AM #360
      Fabbed up the inner axle beam bracing mounts last night. Still need to be welded but Im currently out of sheild gas for the TIG. Also dont mind the random wheel studs, it was the only 5/8" bolts I had that were long enough. The fin at the bottom double serves as a jack point should I not be near the lift.
      Dan
    11. Member matty kirk's Avatar
      Jul 2nd, 2007
      Eugene, OR, transplanted from Eastern PA
      1990 VW Cabriolet 1.8L 2H 5Spd Digi2 - 1981 Ford E-150, 300 6, 4 on the floor
      04-18-2017 09:36 AM #361
      Extreme!!
      Even a blind squirrel finds a nut in the dark, sometimes.
      Apr 2nd, 2004
      near Rochester NY
      04-21-2017 10:49 AM #362
      Finished up the beam bracing last night. Welds arent my best, but itll work
      Also had to modify the inner swaybar mounts. The OE mounts are supposed to fit the Autotech big swaybar, well mine didnt. They were about 1/4" too short. Its really weird, all of the MK1 VW cars have the same OE part number for this bracket, just different revisions dep on year. Given these are NLA and if I found a used set who knows if theyd fit, I decided just to mod them
      First welded a shim to the mounting hole side.
      Then cut off the bent end.
      Bent / cut up a new peice
      Positioned, tacked, and bent around the orig bracket
      Ugly welded in place
      Ground and sanded to sort of match the OE look
      Perfect fit
      And the whole smash on the car
      Up next I need to get the motor back in then start on the exhaust.
      Dan
    13. 05-06-2017 12:06 AM #363
      Dang ! ..sick build,....lucky wife !
    14. Member
      Apr 2nd, 2004
      near Rochester NY
      05-09-2017 09:07 AM #364
      Had an hour or two free after work yesterday, decided to get the motor in so i can start on the exhaust. Goes in so much easier from the bottom side. Im planning to make some sort of dolley that holds it in just the right position so itll go in effortlessly when everything is painted and finished. Basically just lower the car onto it, no hoist required.
      Dan
    15. Member
      Apr 2nd, 2004
      near Rochester NY
      05-10-2017 09:44 AM #365
      Fit a few things last night so hopefully I catch anything stupid that Ive long since forgotten in the last 8 years or whatever.
      Im currently struggling with my original oil cooler mount, not sure whats going to happen there yet. I hate the mustang throttle body. And the top radiator mounts suck.
      Reuger front lip
      Dan
    16. Member briano1234's Avatar
      Feb 20th, 2004
      Atlanta Ga
      90, 92, 93 Cabriolet They own you.
      05-10-2017 10:19 AM #366
      Quote Originally Posted by juicedz4 View Post
      As bad as they are and have a Negative Air Displacement Ratio (vacuous), they are still better than the old bolt at the bottom and a single clip at the top that allowed so much movement that Radiator Tanks split up the sides...
    17. Member
      Apr 2nd, 2004
      near Rochester NY
      05-10-2017 11:11 AM #367
      Quote Originally Posted by briano1234 View Post
      I dont have any OE mounts. I made up some little tabs but Im not keen on them. I need to come up with something new.
    18. Member
      Aug 10th, 2007
      Bryanston, South Africa
      '80 MK1 Golf (2 Door). '00 Golf 4 Cabrio
      05-11-2017 02:45 AM #368
      Amazing build mate! Wow!
    19. Member
      Apr 2nd, 2004
      near Rochester NY
      05-15-2017 09:40 AM #369
      Was able to use my top radiator mounts. Just took a little mod of the radiator to get them to fit.
      With that done it was time to redo the top radiator shroud that I screwed up a few years ago. I had a couple hours friday night so I knocked it out. It was my first time forming something like this. I think it turned out pretty good.
      Also started on Rev 2 of the oil cooler mount. Must happier with this one so far. I just need to redo the lower support / rock guard. Though I may add some sides to create a duct for it. we'll see.
      Dan
    20. Member
      Apr 2nd, 2004
      near Rochester NY
      06-02-2017 10:01 AM #370
      Years ago I started on an oil cooler mount, but since then decided I hated it. I mulled over lots of other ideas, but decided to just make a better version of the original. Im not going to bother showing the original, mostly b/c im too lazy to look it up. Here is the latest.
      Bent up a new upper bracket out of 0.090 alum.
      Made a rock guard frame / lower mount out of 3/16 ss rod and some 1/4-20 cap screws.
      Welded some ss mesh to the frame for the rock guard. Here it is in place.
      Then I thought it should have a scoop and some ducting. So I bent up a few more pieces and welded them up. Of course I cut one angle wrong, so I did an ugly weld on the edge and reshaped it to the right angle. Saved!
      Here is the completed duct / scoop assy. The scoop and sides are 0.090 and the long flat curved piece is 0.040. Was fun welding them together.
      And on the car, without the rock guard.
      And with the rock guard
      Just need to trim some of the threaded studs, come up with the final hardware, and get it coated.
      I got the front soft fuel lines made and routed up to the fuel rail. Came up with a little bracket to hold them between the timing and serp belts since I wont be running a timing cover (just needs a screw)
      In this week's installment of unnecessary projects that probably no one will ever notice:
      I was unhappy with the bung welds for the turbo water lines. And there was a dent in the one OE water tube that Im reusing. So I broke out the silicon bronze and took care of both. These are now ready for coating, likely black wrinkle powder.
      Next up is the starter. I saw someone on IG flip the starter to move the ugly solenoid to the bottom and just knew I had to do the same. I did a quick test a few weeks ago with an old broken oem starter, and it didnt look like it would be too bad. A little cut here and a few welds there and itd fit. New starter came yesterday so I quickly got to work.
      Pulled apart
      I skip a couple steps here, but basically I cut off the tab on the left right through the middle of the oe mounting hole. The hole to the far left is for some other bracket, but Ill be dammed if I can recall what. Cut out a chunk of 5/8" thick aluminum and welded it to the side. Also had to weld up half of the OE hole and an area I cut into when getting it into shape (the little area I bridged in the third pic here.
      Welded
      Then spent some time grinding and sanding into shape and drilled out the new mounting hole.
      Perfect fit.
      Going to check flatness of the new flange area on the mill quick, and then bead blast it so itll be ready for paint when the time comes.
      Dan
    21. 06-02-2017 03:36 PM #371
      Nice. I'd read the starter could be flipped but didn't realize it was that much work.
      Where'd you get the hose clamp/separators? They look much better than the aluminum aftermarket clamps.
    22. Member
      Apr 2nd, 2004
      near Rochester NY
      06-02-2017 03:42 PM #372
      Quote Originally Posted by blind View Post
      Ya, the mounting holes aren't symmetrical, so its some work.
      The black hose separators I get from McMaster. Look up p/n 7429K45 I believe these are for the -6 hose.
      Dan
    23. 06-03-2017 03:11 AM #373
      Thanks. They're cheaper and look much better than the china aluminum ones.
    24. Member
      Apr 2nd, 2004
      near Rochester NY
      06-05-2017 12:54 PM #374
      Here is the difference in the starter flange. The paper is the original flange position.
      Master cylinder lines showed friday. Also got rev 2 or 3 of the firewall bulkhead cnc cut by a guy I work with, turned out pretty nice this time.
      Still need to make the plugs for the unused master cyl ports. I have the pieces, just needs a little welding. But other than the soft lines to the calipers, the brake system is done.
      Dan
    25. Member
      May 30th, 2010
      Germany
      1980 W126, 1983 MK2, 2010 Passat Wagon
      06-09-2017 09:15 AM #375
      I can't say it often enough, but your fab work is amazing!
      My MK2
      • FVCKD FB | Flickr | IG/
      • IG: @schvmo
