Page 3 of 3 FirstFirst 1 2 3
Results 71 to 101 of 101
Thread: Carbonio MkV Rabbit/Jetta 2.5 Cold Air Intake Released!!!
  1. 12-10-2009 08:23 PM #71
    OK so I have had the Carbinio CAI on my 2007 Rabbit (with the MAF installed correctly) for almost 8 months and now when it gets cold i throw a cel and the dealer said it is because the temp. sensor the 90 degree angle sensor everyone is talking about is not on the intake AND IT HAS TO BE IF YOU HAVE AN INTAKE.
    I now need to either drill into the side of the carbon fiber intake or get a totally new one.
    I also need to buy a new Mass Air Flow Sensor (MAF) because running with my proportions off of air to fuel has caused the sensor to get messed up.
    SO either get a BSH or be prepared to drill into the CAI if you have the 2006-2007(maybe 2008) designed motor.
    The newer design doesn't need either sensor.... so this works fine for the 2009+
  2. 12-22-2009 07:40 PM #72
    Now I have the '05 Jetta mkV 2.5 and im assuming that its the same design as the '06-'07 design? And has anyone had problems with this CAI on the '05 2.5?
  3. Member jtrujillo86's Avatar
    Aug 21st, 2005
    Seattle, WA by way of Fort Collins, CO
    2012 MR Beetle 2.5 5MT, 2013 RS JSW TDI 6MT
    12-23-2009 05:57 PM #73
    Quote, originally posted by illblood »
    buy this **** there is a totally noticeable diffence in performance plus the sound is nutty
    I agree. I've had this for nearly a year on my car and the sound is amazing. There's a bit of power difference and my MPG increased a bit as well. And to answer the previous poster's questions, it's the same setup on the 2005.5, so there should be no issues.
    - Jeremy.
    Modified by jtrujillo86 at 2:59 PM 12-23-2009
    Quote Originally Posted by BluMagic View Post
    It's a VW; the sensors are as sensitive as women on that time of the month . . . and the dash is as anxious to light up as a stoner.
  4. 12-23-2009 11:23 PM #74
    Sorry guys if I asked another noob question, Im just trying to figure out what we bought with our first ever German car. I have the '05 Jetta mkV 2.5 and im assuming that its the same design as the '06-'07 design? And has anyone had problems with this CAI on the '05 2.5?
  5. Member JettaMk5's Avatar
    Aug 11th, 2008
    Boise
    05.5 2.5 5cyl
    12-23-2009 11:40 PM #75
    I've got one on my 05.5 and it's great. Don't hesitate to grab one!
  6. 12-23-2009 11:53 PM #76
    did you have to tap in for the 3rd sensor? or does it only run two?
  7. Member JettaMk5's Avatar
    Aug 11th, 2008
    Boise
    05.5 2.5 5cyl
    12-24-2009 12:42 AM #77
    Not sure about a 3rd sensor, I didn't remember hooking up the IAT sensor if thats what you mean. Not sure that the 05.5s have it. The MAF needs to be placed in between 2 pieces of the intake and the SAI tube connected. All pretty easy if you follow their instructions. My tip is to make sure the engine is warmed up before attempting to pull off the engine cover, that makes it ALOT easier to remove.
  8. Junior Member styxer's Avatar
    Sep 12th, 2001
    Slidell, LA
    2008 Jetta 2.5
    01-05-2010 11:22 PM #78
    So I just bought this intake from DBC performance. I have a 2008 should the temp sensor be able to be instslled in the new intake or do ai need to keep the old intake piece and it plugged in there? if anyone has this set up and some pics it would help alot. Also do I need to get a MAF insert?
    Thanks.
    2008 Jetta SE 2.5. S5 style LED Headlights with 6000K HID projectors, Euroswitch, Carbonio/APR Carbon Fiber Intake, slotted zinc plated rotors, euro ceramic pads, red painted calipers
    Currently living in Southern Louisiana
    Active Duty Navy Gunnersmate
  9. Member MKVJET08's Avatar
    Feb 12th, 2008
    Manassas, VA
    2008 Jetta 2.5, 1996 Rustbucket
    01-08-2010 09:54 PM #79
    Quote, originally posted by styxer »
    Thanks.
    You have a 2008, you don't have a temp sensor to worry about, it's built into the MAF. And no you don't need a MAF insert as the intake should come w/ one.
    They're going to their house over there.
    You're not utilizing your education properly.
  10. 02-08-2010 05:19 PM #80
    Does anyone know if this will work on an MK 6 2010 Golf 2.5L since it's basically the same engine as an MK 5? Has anyone done this yet?
  11. Member nickbeezy's Avatar
    Feb 9th, 2009
    Va Beach
    mkv
    02-08-2010 09:14 PM #81
    yes it is the same thing, you just have a MAP sensor
    follow me @dominickhenry|2.5l UM tuned!|Flickr|Build Thread
  12. Member vwjetta252006's Avatar
    Jul 31st, 2009
    Richmond Hill
    2006 2.5, 2008 Jetta 2.5
    02-20-2010 09:05 PM #82
    Does anyone know the dimensions of the FILTER for carbonio itself?
    i want to buy another air filter while i recharge the original one from carbonio...
    http://www.namotorsports.net/l...t/140
    Does anyone know the air inlet diameter , the width and the length
    and will there be a difference longer vs. a smaller one? Im guessing the longer ones will get better air intake?
  13. 03-15-2010 01:17 AM #83
    hey I just had a question
    I have an 08 2.5L Jetta
    does this cold air intake work for that engine?
  14. Member DUSlider's Avatar
    Nov 14th, 2007
    PA
    2008 Rabbit
    03-15-2010 01:28 AM #84
    Quote, originally posted by bjl_chavez »
    yes.................
  15. 03-15-2010 11:20 PM #85
    thx jeje sorry about the noob ?s but this is my first vw and i dont want to mess it up
    now does anyone have any install instructions just as to not mess it all up?
  16. Member DUSlider's Avatar
    Nov 14th, 2007
    PA
    2008 Rabbit
    03-22-2010 11:18 AM #86
    It comes with directions. Only recommendations I have...
    Don't tighten any of the clamps until it is completely installed and aligned.
    Make sure the MAF is pointing in the right direction. The arrow signifies direction of airflow.
    Don't forget to put the cookie cutter thing in.
    You can install it without removing the wheel, but it makes it easier.
    Or
    Remove the bumper skin and you don't have to remove the wheel and gives you alot more access
  17. 04-17-2010 01:42 AM #87
    I have a 2009 Rabbit. I know that it will work on my car but is there anything I need to know about sensors and such? Also what is the deal with the engine cover and the stock intake? Do I have to remove them? Is there any benefits to taking it off or leaving it on. I read something about a sensor that you can leave in the stock tube or get a intake that is tapped to accept the sensor. Does this apply to '09s? Thanks dudes!
  18. Member DUSlider's Avatar
    Nov 14th, 2007
    PA
    2008 Rabbit
    04-17-2010 02:18 PM #88
    Quote, originally posted by clutch83 »
    Doesn't apply to the 09's. Only benefit for no cover is reduced weight, which is very little, and may reduced engine noise, but you're getting an intake so I don't think that would be a problem. Otherwise, there is no reason to keep it on, unless you have no where else to store it. I'd say eventually get a beetle 2.5 engine cover to replace it.
  19. Junior Member VWtribal's Avatar
    Mar 19th, 2010
    Las vegas, NV
    2012 CW GTI, 6 speed manual =)
    04-17-2010 08:03 PM #89
    it won't work on the 2010 Golf... because of the lights..they are too big... check out the NEUSPEED SRI...that's what i ordered after trying the Carbonio..and i love it!!!!
    2012 CW GTI 6 speed manual, APR stage 1, Carbonio intake S1..(for now)
  20. 04-18-2010 02:35 AM #90
    I hate to ask this, but how low does it hang in the engine bay and is it CARB legal?
    I strongly abide by the motto safety third.
  21. 09-22-2010 04:04 AM #91
    Will a Carbonio intake made for the model 07-08 can work on the 09's model ???
    Since they don't have the same engine code.
  22. Member GrkPranksta69's Avatar
    Jan 10th, 2009
    North Carolina
    2007 VW Jetta, 1973 Pontiac Trans Am 455 SD
    09-22-2010 07:51 AM #92
    Quote Originally Posted by Pablo_2.5 View Post
    Yes
    Quote Originally Posted by Mr Miyagi View Post
    And, if the situation calls for it, you could break out some drumsticks and play the xylophone on her ribs
    God dammit Miyagi, go to school. Who the f**k plays the xylophone with drumsticks?
    You use mallets. Idiot.
  23. Semi-n00b PRJ-RABBIT's Avatar
    Jul 30th, 2010
    JERSEY
    2007 MKV RABBIT
    10-14-2010 11:45 PM #93
    ordered it 2 days ago from ecs, ups says it should be here tomorrow....... word
  24. n00b zmaderia's Avatar
    Nov 2nd, 2010
    CT
    07 jetta
    11-02-2010 09:22 PM #94
    i have an 07 under warranty still and i WANT this intake bad...!!!! will this void the warranty?
  25. Member AKdub914's Avatar
    Jun 15th, 2010
    914 ny
    09 jetta SE
    09-15-2011 06:14 PM #95
    are you selling the carbonio intake restrictor ring?
    AKdub | I NY | THREE.8.WERKS...Ferdinand's Crew
    Eurothon11 6.16.13 > @GPNY mt.kisco NY come test your true driving skills on the track!
  26. 10-08-2011 12:40 PM #96
    I was looking at getting a new filter (mine is getting old and has been cleaned several times) and was wondering if one of the tapered ones would work just the same. i don't see why it wouldn't but just wondering. It's a 3.5 inch ID filter by about 5 inches right? I also saw that some K&N filters have this plastic guard kinda looking thing that goes around it. Since i don't have fog lights the filter is directly in the stream of all that dirty air (i drive on dirt roads a lot) and i'm thinking one of those plastic guards might help keep the filter out of the direct impact of dirt, bugs and water.
    what do you think and where should i get one of those guards?
    Thanks.
  27. Semi-n00b
    Jul 28th, 2009
    El PasoTX/Mex DF
    2009/VW/Sportwagen
    03-06-2012 11:11 PM #97
    Hi guys, I´m sort of reviving this thread.
    I have a 2009 Jetta sportwagen with the 2.5 L engine and auto transmission. I bought the Carbonio CAI kit and had it installed yesterday.
    Off the bat we faced a problem. The kit has a Carbon fiber section with two sections to attach vacuum hoses. My car has only one vacuum hose.
    The installed made a plug for it and finished the job.
    The intake worked great yesterday.
    But today after driving a few miles I got a CEL light.
    Specific codes where
    P0101 Mass or volume air flow A circuit range/performance
    And
    P0171 System too lean bank 1
    Additionally I think the transmission went into limp mode disabling S mode and manual shift modes.
    Can any one help?
    Thank you very much in advanced.
    --2009 Bora(Jetta) Sportwagen. Platinum Gray with black leather interior. Panoramic roof. GLI wheels.
    -The other rides.... 2005 E60 M5, 2004 E46 M3 Hartge H5, 2000 E39 M5,
    2008 Acura MDX Tech (Wife's), 2004 Jeep Grand Cherokee Limited Armored NIJB4.
  28. n00b
    Aug 5th, 2012
    Elmont, NY
    2006/Volkswagen/Jetta
    08-05-2012 04:58 PM #98
    i just installed the apr carbonio cold air intake today...pretty straight forward installation...there was a piece of flat round metal that had spikes on the inside...where does this part go? i didn't find it in the instruction manual included...also i was thinking of installing the 2.5 beetle cover...where is the best place to get it? i see ecs selling it for about $95 and a VW part store is selling it for about $79 shipped
    any help/advice would be greatly appreciated(new forum member)
  29. Junior Member
    Sep 7th, 2012
    NYC
    09-13-2012 09:07 PM #99
    Quote Originally Posted by R6soldier View Post
    I say get it directly from the VW dealer, cheaper and its from the dealer, cannot beat that.
  30. Member phrog23's Avatar
    May 11th, 2007
    Mesa, Az
    07' hase
    09-14-2012 02:39 AM #100
    that piece goes on the intake side Toward the filter.
    I did a DIY for this back in like 08 but I can't find it, so here is a pic from it.
    APR'91/Carbonio/magnaflow catback/BSH dogbone/ clear corners/ de-badged/ Eibach sportlines/ spherical drivers mirror/ kenwood 1200W/ Vag'd/ mesh grille/
  31. 10-02-2012 10:30 PM #101
    Quote Originally Posted by jrnring View Post
    And
    Can any one help?
    Hey what came of this? I'm thinkingof ordering one for mine. Any advise?
