VWVortex.com - Jetta 2004 TDI Glow plugs
    Results 1 to 6 of 6
    Thread: Jetta 2004 TDI Glow plugs
    1. Junior Member
      Jan 30th, 2006
      Hudson, Quebec
      01-15-2008 02:04 PM #1
      What is the recommeded mileage to replace the glow plugs? How much do the glow plugs cost generally to replace? I presently have 180,000 km`s on my car.
      Thanks for the Info.
    2. Member nismodrifter's Avatar
      Apr 2nd, 2004
      Calgary, AB, Canada
      2001 Jetta TDI
      01-15-2008 02:38 PM #2
      You don't replace them until they go bad. There is no set life time for them.
      I've had to replace one in nearly 200 000km.
    3. Member slight3r's Avatar
      Jun 10th, 2007
      Brattleboro, VT
      cjaa tdi, alh tdi, awd 1.8t
      01-15-2008 02:59 PM #3
      I had to replace 2 at around 140k miles, but the all the rest are still working (193k)
    4. Junior Member
      Jan 30th, 2006
      Hudson, Quebec
      01-15-2008 03:02 PM #4
      Thank you, Does the car still start or does a warning light come on?
    5. Member nismodrifter's Avatar
      Apr 2nd, 2004
      Calgary, AB, Canada
      2001 Jetta TDI
      01-15-2008 03:30 PM #5
      Quote, originally posted by George61 »
      You will get a check engine light. It'll probably still start (unless it is properly cold) but it will run rough initially.
    6. 01-15-2008 04:53 PM #6
      my friend sells brand new ones for i think $100 a set you and send me IM if you are interested.
