does the engine actually turn over or does it not even turn over? can you scan it for dtc's
#1
Woke up this morning to start the car and tried to turn the engine over. The battery is fine, but the car wouldn't start. So before letting it just go and go, I let off the ignition and tried it again. Then I got the "Oil Pressure" warning light message...Stupid FSI won't start. Have to call a tow truck in a few minutes unless for some reason the damn thing starts on its own...
Any help, or suggestions before I off myself?
Edit: the the cause right now it seems is that I was running 100 oct race gas, which, in really cold weather is a bad bad idea on cold start-ups.
Modified by Kid Hobo at 1:55 PM 1-21-2008
Adjusting my lifestyle with the grace and wisdom of a potato.
#2
#3
Engine turns over, but I can't scan... no vag com here. But there's no CEL's either.My guess is the oil pump froze up, or the coil packs froze, or god is punishing me.
#4
So this is my second 2.0T, and one thing I'm certain of is that when it comes to cold weather... the FSI is a heaping pile of junk. I had the same cold start issues with my 06 and I do now with my 08. I'm buying a damn Honda next time.![]()
#5
Quote, originally posted by Kid Hobo » Engine turns over, but I can't scan... no vag com here. But there's no CEL's either. My guess is the oil pump froze up, or the coil packs froze, or god is punishing me.
if your oil pump locked up the engine would not turn over and i don't see a frozen coil pack happening when you just turn the ignition on do you get a check engine light solid on the dashboard to let you know the ecu is in proper running order?
#6
Quote, originally posted by jc@douglas »
if your oil pump locked up the engine would not turn over and i don't see a frozen coil pack happening when you just turn the ignition on do you get a check engine light solid on the dashboard to let you know the ecu is in proper running order?Hmm... that's interesting. I can hear something pumping in the engine bay, driver side I think, but it's not sounding like it's happy. As for the CEL, there are no solid lights that are lit, only the MFD that gives me the Oil logo and the message found on section 3.2 pg 48 in the owners manual. Nothin else...
3.2 pg 48 Warning light: engine oil pressure.
I checked oil levels (just got an oil change btw) and levels are fine.
#7
you are getting the oil light because you are cranking the car and it's not starting, but if you have no check engine light on solid when the key is on accessory with out the car running you have a problem![]()
#8
Quote, originally posted by jc@douglas » you are getting the oil light because you are cranking the car and it's not starting, but if you have no check engine light on solid when the key is on accessory with out the car running you have a problem ![]()
poopie
New car - check
Only 3400 miles - check
Engine problems - checkWell... I guess I really am screwed. I'll have to tow it.
#9
Well, despite my better judgement, I went ahead and gave it a couple more tries to get the thing started (I was in F-it mode).First time, same thing.
Second time, some sputter.
Third time, more sputter.
Fourth time, sputter and then finally a start.No check engine lights for now. Nor service indicators. But I'll try get VAGcom to scann for DTCs to see if anything is stored in there.
#10
Good to hear that it's running again. I'm sure Rich at Dubwerks, Conrad at City VW, or Autobarn MP will scan you.![]()
Hell, I would, but I'm so far west.
Unitronic Stg 2+ K04
My flickr
Past cars:
1991 Corrado G60 autotragic
1998 Jetta GLX 5MT - miss it to this day
#11
Quote, originally posted by Kid Hobo » Well, despite my better judgement, I went ahead and gave it a couple more tries to get the thing started (I was in F-it mode). First time, same thing.
Did you change to a colder plug??? or still on the stock plug ??
I would suggest putting new set of plugs in sounds like there fouled a bit .
Bob.G
Read below about mine and other fsi stage 3 owners bad experience and poor results with APR and there Stage 3 Kits. http://forums.vwvortex.com/showthrea...ge-3-dyno-runs
#12
Quote, originally posted by rracerguy717 » Did you change to a colder plug??? or still on the stock plug ??
Bob.G
Given that I'm running Stg1+ on the Uni software, from what I know the Unitronic flash runs agressive advanced timing, maybe even more so than anyone else. I also ran a couple tanks of 100 octane unleaded race gas that day (uh... btw, WOW!), which I don't know how, but might have contributed to a fouled a plug or two?
The plugs sound like a reasonable and easiest place to start looking. And I'll have to wait till I get the time to run up to Dubwerks to run a full scan. Either way, I've been intending on getting a set of 1 heat range colder NGK or Bosch plugs.
Right now, I'm going to leave my guess' open.
With a bit of luck, I might be able to convince high-command (gf), that the reason the car almost got us stranded was because my turbo wasn't big enough.
Thanks for the input guys.
Cheers,
KH
#13
Quote, originally posted by Kid Hobo » Given that I'm running Stg1+ on the Uni software, from what I know the Unitronic flash runs agressive advanced timing, maybe even more so than anyone else. I also ran a couple tanks of 100 octane unleaded race gas that day (uh... btw, WOW!), which I don't know how, but might have contributed to a fouled a plug or two?
When did you run the 100 octane? recently like right before you parked it? That could certainly lead to cold start issues if its still in the tank.
As for the timing, It should not be changing any kind of start up timing, so the chip is also unlikely the answer.
Its cold..probably really cold where you are since its also pretty cold in GA. While FSI should start better in the cold then a manifold injection car I noticed that in the winter when I Was still in nj that was not the case.
#14
Quote, originally posted by chris@revotechnik » When did you run the 100 octane? recently like right before you parked it? That could certainly lead to cold start issues if its still in the tank.
Yep, there was still 100 oct in the tank. As for cold, it probably hit -10 at night and was around 5 degrees when I tried to start it. And why would 100 oct make a difference in start up? Part of my logical brain would want to think that the 100 oct would ignite better in cold temps... or am I not seeing another perspective?
Regarding the timing, I never thought it was the software really. I don't know my way around timing and mapping, but it makes sense in a start up cycle that there would be no change from stock at start up, only during higher revs does the mapping change. But in relation to the plugs and heat range, based on what Bob brought up, I keep wanting to think/believe that that's where the issue could lie (including possible coil pack issue)... but then again, with no codes it's all conjecture for now.I need to buy a Ross Key.
#15
Quote, originally posted by Kid Hobo » Yep, there was still 100 oct in the tank . As for cold, it probably hit -10 at night and was around 5 degrees when I tried to start it. And why would 100 oct make a difference in start up? Part of my logical brain would want to think that the 100 oct would ignite better in cold temps... or am I not seeing another perspective?
Thats the problem as Chris was pointing it out .
Bob.G
#16
Quote, originally posted by Kid Hobo » Yep, there was still 100 oct in the tank. As for cold, it probably hit -10 at night and was around 5 degrees when I tried to start it. And why would 100 oct make a difference in start up? Part of my logical brain would want to think that the 100 oct would ignite better in cold temps... or am I not seeing another perspective?
Dumbed down version of how octane works..
higher number harder to ignite
lower number easier to ignite.
So you have a cold engine which already makes it difficult to ignite the fuel, with fuel that is harder to ignite to begin with. I'd say thats 100% your issue.
#17
I like the dumbed down version. But do please help in one area, will changing the plugs to a heat range colder help with race gas and cold start up situations?
Thanks,
KH
#18
Quote, originally posted by Kid Hobo » ![]()
Thanks,
KHIn the winter it will make it WORSE.
Bob.G
#19
how cold is it their? it was 11 here yesterday my 2L fsi started fine with one heat range colder but my moms 2.5L was a bitch to start and once it did it missed for like 20 seconds before smoothing out
#20
about -10 to my highest recorded temp on the car's temp sensor which was +9, so still 23 degrees below freezing.
#21
Quote, originally posted by Kid Hobo » about -10 to my highest recorded temp on the car's temp sensor which was +9, so still 23 degrees below freezing.
yea that deff cold
#22
Is your driver's side door switch working?When you open the door it turns the feeder pump in the fuel tank on. My door switch is bad and the car starts hard when it's cold. If I turn the key and wait a second, then start it, it starts easier.
#23
I spoke to God and he said that had you driven that cold day, there was a snowplow some 4 miles from your house that was going to level your car...and you were going to die
#24
Yeppers, I tried the ignition wait. The door switch was fine, I can hear it priming. In fact, I always wait an extra 5-10 seconds after getting into my car and turn the ignition switch to accessory mode. It's a simple thing to just put on my seatbelt before I actually start the car and gives the fluids just enough tender time to prime.![]()
As for the snow plow... well, I was parked in the street, but in the sticks I was sticking out like a sore thumb, I mean seriously, Sandwich Illinois! Imagine what that tow bill back to Chicago would have been!
#25
ditch the 100 octane...the ethonol that is in the gas causes longer starts but 100% race gas with no cut it take forever to turn over. If the oil light came on check the oil and keep cranking... just cuz the light comes on with no engine running doesnt mean somthing is messed up..The light came on from whatever presure you created by cranking it over. Next time run a 60% race gas 40% 93... you will have better luck.
#26
you could get some glow plugs.....![]()
old thread... sorry!
#27
Call that truck.![]()
#28
I had this same problem in my A3 the day after buying it, I would crank it over till the car seemed to warm up then it would start. I tried to wait a few seconds like stated above but that didnt work for me. I finally took it to the dealer and had it fixed under warranty. I think they said my fuel pressure sendor or sensor was bad, it was a sensor that had to do with the fueling. They replaced that and I have not had this problem again so far![]()
APR stg2+hpfp+W/M(100oct)
