Page 1 of 13 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 448
Thread: Review: USA RNS-510
  1. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-22-2008 11:23 PM #1
    DISCLAIMER (verbatim from mdonis; used without his permission so sue me.)
    This document is provided for informational purposes only. Any Vehicle modification should be done by a certified VW mechanic. Neither the author nor this website will be held liable for action taken resulting from this information set forth herein.
    CAUTION:
    Before doing any electrical work on your Vehicle make sure to disconnect the negative terminal on your
    Battery
    RNS-510 installed in a MY2007 GTI 4-door with OEM Bluetooth (Skoda), OEM iPod adapter and aftermarket processor/amps/speakers
    - Seller information: No longer I'm able to state seller information.
    Preparation:
    - RNS-510 USA Manual (for download): http://rapidshare.com/files/13....html
    - Required parts:
    twin connector : P/N 4E0 035 608 K
    antenna adapter (2) : P/N 000 098 707
    The radio antenna jacks in this unit are very close together, which requires a new dual antenna cable jack plug to be used instead of the existing individual connectors.
    - GPS antenna
    - Sirius Satellite antenna
    - Switch AUX and CD Changer grounds pin positions (Pins 2 and 3 in red): http://img233.imageshack.us/my...2.jpg
    Without this ground in the correct pin position neither the CD Changer or the AUX por will sound good because their grounds are going to be mismatched.
    OEM Accessories installed:
    - OEM BT installation P/N 1Z0 035 729: http://forums.vwvortex.com/zerothread?id=3488355
    To ease the installation of the OEM Bluetooth P/N 1Z0 035 729, a custom "quick connect" harness was created using the American International EWH-1010 and the Metra 71-9003 connectors; this custom harness also included a Line Output Converter with a built in 12V remote turn in feature (using signal sensing):
    Installation:
    - After setting up the antennas (4 connections) and looking for proper installation sites for them (in my case the GPS and the Sirius antennas are under the top of the dash to the right of the -510) and swapping the AUX and CD Changer ground wires just follow the standard DIY for Nav:
    - General removal of OEM HU for swap: http://forums.vwvortex.com/zerothread?id=3121070
    - Once everything is connected the unit will be ready for power up.
    Photos: (not high quality but it is night time)
    Installed:
    FM Radio:
    HD Radio:
    OEM Sirius:
    OEM iPod Adapter (no longer installed):
    SD Card:
    HDD:
    OEM Bluetooth:
    DVD video (it also can play DVD Audio):
    Menus (observe the option for Bluetooth Audio):
    Notes:
    - USA DVD map disc is P/N 7L6 919 859 version 1M.
    - Sound quality is excellent; remember, I'm using aftermarket equipment.
    - GUI and Video quality is excellent.
    - OEM BT module compatible with this unit is P/N 1Z0 035 729
    02/01/08 Update: Three Display Variants are available thru VAG-COM programming:
    Highline:
    Sportsline:
    Premium:
    02/06/08 Update: Custom maps loaded courtesy of Lassc at the vwnavi.com forums and still under combined development:
    06/8/08 Update: - Multimedia Device Interface (MDI) Installed:
    - P/N 5N0 035 341 A
    - $255 at 1stvwparts.com
    - Includes USB cable
    - Does not include connecting harness or iPod cable (P/N 000 051 446C)
    - requires CD Changer console and A/C rear duct if not equipped
    - Only works with RNS-510
    - Control from MFSW/touchscreen and display ID3 tags on screen and in MFD
    - Excellent sound quality from USB sticks (depending of bps recording)
    USB:
    iPod:
    Modified by M3Tech at 7:34 AM 8-13-2008
  2. 01-22-2008 11:33 PM #2
    Wow that's awesome! OEM Sirius worked out of the box?
  3. Member Tucci's Avatar
    Feb 2nd, 2005
    Oakwood GA
    3.2 TT
    01-22-2008 11:38 PM #3
    Excellent, I will have one when the Us maps are out. Looks sweet.
  4. Member mdonis's Avatar
    Sep 1st, 2005
    2005.5/VW/Jetta 2.5L
    01-22-2008 11:39 PM #4
    I am not a lawyer so I am ok with unless I sue you for the RNS-510 J/K
    Nice Setup...! I want one so bad, but I need to find out if my BT unit that I got from VrStu is compatible with this unit. So the unit comes with HD radio & SAT radio built in. So this means I could sell the stock SAT unit.
    Modified by mdonis at 8:49 PM 1-22-2008
  5. Member carlosabh's Avatar
    Jan 21st, 2003
    El Paso TX
    06 Jetta GLI, 06 VW Sharan, 98 VW GTI
    01-22-2008 11:39 PM #5
    Great work
  6. Member VWNDAHS's Avatar
    Jun 20th, 2002
    San Diego
    MkV GTI, MkV R, The Beetle
    01-22-2008 11:40 PM #6
    awesome, thank you. I fell in love with this head unit the moment i sat in a tiguan.
  7. Senior Member NoDubJustYet's Avatar
    Mar 25th, 2002
    HB, DE
    01-22-2008 11:45 PM #7
    so the OEM Sat antenna works?? Is there an additional antenna for the HD?
    is your iPod adaptor the one in the glovebox or center console?
  8. Member silverA4quattro's Avatar
    Jun 21st, 2004
    Conshohocken, PA
    '10 Jetta TDI, '13 Cruze Eco
    01-22-2008 11:46 PM #8
    Wow, HD radio too...nice.
    So am I correct in saying the Sirius tuner is built into the unit? Thus, it no longer needs the separate tuner box under the pass. seat and just an antenna?
    Interesting. I wonder how this would affect those of us who already have Sirius installed, I want to keep my shark fin.
  9. Member prodigymb's Avatar
    Mar 8th, 2004
    Philly
    996tt
    01-23-2008 12:15 AM #9
    nice
  10. 01-23-2008 12:17 AM #10
    Very nice
    What about XM satellite radio? Would it work with this unit or is Sirius the only one that's available? As far as the Bluetooth goes, do you have to operate it with the buttons on the steering wheel or can it be operated with the touchscreen? I have pacakage 1 so no buttons on the wheel.
    Thanks for your work
  11. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 12:18 AM #11
    Quote, originally posted by bigbot45 »
    Yes... the welcome channel is tuned immediately. To activate the service, press the Set Up button, select Sirius ID and the ESN's of the audio and traffic services of Sirius show up, including the telephone number to call.
    Quote, originally posted by mdonis »
    Damn...
    Stu should tell you if that unit is or not compatible; that was something that I made sure before ordering because of reported issues in Europe with certain P/N of the "Premium Bluetooth" option.
    Quote, originally posted by NoDubJustYet »
    I'm using an OEM BMW Sirius antenna with this unit. Most probably you will need an OEM VW Sirius antenna or at least the cable, as the locking plastic cap of my antenna is does not match this unit jack. I have to go ghetto on this sucker and use electrical tape to hold the connection until I get the right plastic locking cap.
    HD radio uses the same FM diversity antenna; switching to HD Radio is automatic although you could disable it in the Set Up menu.
    The OEM iPod adapter is the one in the glovebox. Either one works because they are the same module with just different iPod mount.
    Quote, originally posted by silverA4quattro »
    Yes... just need to run a new cable from the existing Sirius OEM mounted antenna to this unit, and that's it.
  12. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 12:25 AM #12
    Quote, originally posted by hamilton318 »
    Very nice
    Only Sirius; I think that VWUSA doesn't have a contract with XM anymore...
    OEM Bluetooth now can be controlled from either the MFSW or the -510. Display is on both the -510 and the MFD. Voice Commands seems to be only activated from the MFSW; haven't fully tested it yet for sure. Mute button on MFSW activates the Voice Commands; Mute button on the -510 goes straight to the Phone screen; full keypad is shown also.
    Up to 6 direct dialing entries can be programmed in the -510.
  13. Senior Member absoluteczech's Avatar
    Sep 12th, 2006
    Newport Coast, CA
    2013 VW GTI 2DR DBM
    01-23-2008 12:27 AM #13
    son,
    you have too much money sick!
  14. Member babydubz's Avatar
    Dec 12th, 2007
    The Great White North
    bagged mk5
    01-23-2008 12:31 AM #14
    off topic question, but where did you get that chrome trim and ring of light around your climate controls? looks good!
  15. 01-23-2008 12:34 AM #15
    I see that the sd input shows track info....what about ipod connection? any track info in this mode?
  16. 01-23-2008 12:39 AM #16
    Everybody has a plan till they get punched in the mouth
    1986 535i | 1995 M3 | 2002 337 | 2005 MCS | 2006 GTI | 2007 GTI | 2008 R32 | 2006 CAYENNE S | 2012 GOLF R | 1991 964
    GONE | PRESENT
  17. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 12:41 AM #17
    Quote, originally posted by babydubz »
    On eBay... I don't remember the seller right now, though.
    Quote, originally posted by microbreak »
    The OEM iPod adapter is not capable of displaying ID3 tags, it just mimics a CD Changer.
  18. Senior Member NoDubJustYet's Avatar
    Mar 25th, 2002
    HB, DE
    01-23-2008 11:18 AM #18
    Quote, originally posted by M3Tech »
    So if we already have Sirius in the car we just need to run the antenna from under the seat (where the Sirius module is) to the back of the -510? easy enough... i think?
  19. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 11:49 AM #19
    Yes, just like that although I think that you will need an extension cable... just make sure that while you are sliding this unit back into the dash the Sirius antenna connection have enough clearance in the back. It is very tight back there and if there's anything in the way (the OEM harness for example) you could easily break the unit connector... it already happened in a Passat B6.
  20. 01-23-2008 12:48 PM #20
    ...but not funny....
    It'll be interesting to see how the nav unit works one the maps are available or somebody hacks the existing maps to comply with whatever new format this unit wants to see.
    It looks quite promising.
    The install still seems a bit daunting though - not so much the nav unit itself, but the BT module and associated wiring...
  21. Member silverA4quattro's Avatar
    Jun 21st, 2004
    Conshohocken, PA
    01-23-2008 12:56 PM #21
    I was on VWNavi last night and found a post about it. I think he actually loaded the map data to the internal HDD, which is how the thing is supposed to work.
  22. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 01:05 PM #22
    Let's do something, cb1111... if you get one day the OEM Bluetooth I will personally make and ship for free a quick-connect harness exclusively for you...
    You will swear that you just bought a Parrot kit but "almost OEM"...
    Quote, originally posted by cb1111 »
  23. 01-23-2008 01:57 PM #23
    thats looks good
  24. 01-23-2008 02:39 PM #24
    I'll take you up on that.
    So where do you put the BT module? I guess you can put it under the seat where the Sirius/XM unit was, but you still need to get the cabling there, right?
    I think many of us would tackle the microphone up to the stock position, but I'm not so sure about pulling the center console apart....
  25. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 03:33 PM #25
    Count on it...
    The OEM BT module is under my driver's seat in a custom bracket that I made because I have an amp under each seat. It is placed just above an Alpine amp already there; so far no overheating, no electrical interferrence, no problem with the seat rails as long as the seat is raised above half way of maximum.
    In your case, if your passenger underseat area is already occupied you could use the driver's underseat area instead. If you are getting this Nav unit then there's no need anymore for your SatRadio tuner, so you will have the proper OEM mount real state available.
    For any wire/cable "fishing", Crutchfield "wire worm" rods - http://www.crutchfield.com/App...p=990- is a must as you will be routing wires/and cables thru the interior of your car without removing too many trim pieces. This "worm" will be very useful in getting not only the BT module harness from the OEM HU area to the module itself but to get that OEM microphone cable thru the roof trim in no time...
  26. 01-23-2008 03:35 PM #26
    Count on it...
    For any wire/cable "fishing", Crutchfield "wire worm" rods -http://www.crutchfield.com/App/Product/Item/Main.aspx?g=820&i=042DM4533&search=wire&tp=990- is a must as you will be routing wires/and cables thru the interior of your car without removing too many trim pieces. This "worm" will be very useful in getting not only the BT module harness from the OEM HU area to the module itself but to get that OEM microphone cable thru the roof trim in no time...
    So major disassembly is NOT required?
  27. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 03:47 PM #27
    No, unless removing the OEM HU, one of the side trim panels of the center console, one A-pillar cover, and the microphone trim is major dissassembly for you.
    Wire-wise, there are only 4 wires that need to be connected to the OEM harness:
    - Power
    - Ground
    - CAN +
    - CAN -
    This can be taken care for by the "quick-connect harness", so no splicing or taps is required, just plug two connectors.
    The rest are ready made connectors... microphone, module, antenna. The OEM bracket for the passenger underseat area have the holes already set for it. Check again mdonis thread and you will see how easy it is...
    Modified by M3Tech at 3:48 PM 1-23-2008
  28. 01-23-2008 03:50 PM #28
    im really unhappy with my ipod adaptor.... it was a waste of money....
    with this unit can u go thru all ur folders or is it the same crap with the unit taking the 1st 5 playlists and then just all the songs in order on the 6 position?
  29. 01-23-2008 04:52 PM #29
    looks great
  30. 01-23-2008 04:54 PM #30
    that looks awesome... is the price comparable to what one can get a pioneer avic z2 for on ebay?! He was quoting just over 900Euro for the EU version... I want nav but would love to stay OE and this looks sexxy!
    2007 GLI - Built 2.0TFSI DSG w/ 3071R, LSD, BBK, Ultralows - gathering dust
    2010 Touareg TDI - Highline, Sport Pkg, Tech Pkg
    2011 Audi S4 - DSG, Premium Package, Sport-Diff, Navi, B&O Sound
    2013 Range Rover Sport - HSE Luxury
  31. 01-23-2008 05:14 PM #31
    love it !
  32. 01-23-2008 05:57 PM #32
    awesome there is some guy that got that navi to work withUS MAPS
  33. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 06:30 PM #33
    Quote, originally posted by .ubs »
    The current OEM iPod adapter is the limiting factor, as it is a CD Changer emulator. So regardless of the OEM HU used it will still be a CD Changer emulator, with the same 6 choices and no ID3 display tags...
  34. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 06:31 PM #34
    Quote, originally posted by yvrnycracer »
    It is very comparable, at least from my seller...
  35. Member M3Tech's Avatar
    Jan 26th, 2007
    Ft Lauderdale, FL
    2012 M3/2010 CC
    01-23-2008 07:01 PM #35
    Just finishing trying to pair an iPod with a Motorola Bluetooth adapter (A2DP) to the OEM BT module but it did not work... the -510 Bluetooth Audio screen never changed from inactive. I will try a music phone later, it could work as it will need to be paired as a phone first and then it could use the A2DP stream audio profile as a separate pipe in the same connection. There was no way of doing this with this single purpose adapter...
