Page 2 of 2 FirstFirst 1 2
Results 36 to 50 of 50
Thread: TT Oil Change...How in the hell
    Oct 24th, 2007
    Dekalb/Aurora, IL
    01/audi/tt roadster 225 AND 88 RX7
    01-01-2010 10:17 PM #36
    I am a drain phine.... Usually let my personal oil change sit over night before re-filling. Also drain when HOT.
    J'S REPAIR AND PERFORMANCE
    PLAINFIELD, IL
    VAG-COM EQUIPPED-815-556-0027
    01E/01X TRANSMISSION REBUILDER- CALL FOR UN-MATCHED PRICE!!!
  2. Member chaugner's Avatar
    Jul 13th, 2002
    Miami
    Audi TTQ, Touraeg, Passat
    01-02-2010 05:18 PM #37
    yeah changing the oil filter is a pain in the butt. I decided to take the long route and make access a bit easier. Figured it would probably be the easiest way to get the filter removed. Here is a picture for reference. Yeah audi sure made it difficult to change the oil .... bastages
  3. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    01-03-2010 06:26 PM #38
    I have to say, thats about the most inconvenient way to change the oil I can think of
  4. Member chaugner's Avatar
    Jul 13th, 2002
    Miami
    01-03-2010 06:34 PM #39
    Quote, originally posted by l88m22vette »
    well its not done yet - as you can see the oil filter is still on the housing haha - it seems I missed something
  5. 01-03-2010 07:32 PM #40
    Quote, originally posted by chaugner »
    ... Here you go you forgot to take the filter off... Here's what it looks like with the filter removed
    Or you could relo it...
  6. Member Mattionals's Avatar
    Mar 8th, 2005
    Middle of NJ
    2003 Avus Silver RS6
    01-03-2010 08:33 PM #41
    Quote, originally posted by 2001TTransport »
    Which relocation kit is that? I so want that, so much easier!
  7. 01-03-2010 08:40 PM #42
    Custom made... hit my fotki, you'll see the canton take off plate, then the mocal remote four port mount and the mocal thermostatic sandwitch plate, I have a aftermarket oil pressure sensor and oil temp sensor installed along with a SETRAB oil cooler. I sourced most of my parts from bat-inc
    Here's how I change the filter...
    Modified by 2001TTransport at 5:43 PM 1-3-2010
  8. Member chaugner's Avatar
    Jul 13th, 2002
    Miami
    01-03-2010 08:52 PM #43
    thats kind if slick - always been wanting a relo kit for the filter as well to make it a bit easier to access. Gonna have to take a look at your setup
  9. 01-05-2010 10:47 AM #44
    Best thing ive ever used was a 3 inch silicone coupler, has great grip on both sides and fits the filter perfect.
  10. Member ShockwaveCS's Avatar
    Jun 22nd, 2006
    Baltimore, MD
    2001 Audi TTQ 1.8T(Sold) 2010 Audi TTQ 2.0T
    01-07-2010 08:10 PM #45
    aside from everyone elses reasons for keping the crossover pipe...you need it if you get a dieselgeek skid plate.
  11. 01-10-2010 11:00 PM #46
    Its odd, but after you do it once it's really no longer a pain. Also, the first time sucked because the monkeys at the dealer who did the last freebie oil change cranked the filter on there so tight. Once I got it off, and put the new one the correct way, I use a end cap filter wrench to break it free and then turn by hand...and when I re-install I hand tighten it, then 1/4 turn with the end cap wrench....no need to sock it on there....
    Oh, and I take the filter from below, sliding it down towards the driver side a bit and then pushing it through by a coolant hose...
    Sean
    •1995 VW Jetta GLX •2006 Saab Aero Convertible •1970 VW Bettle •2005 Audi TT (Mrs.)
    Airbags: The Padded Bra of the Automotive World.
  12. Member storx's Avatar
    Dec 6th, 2006
    Earth
    01-11-2010 01:20 PM #47
    i upgraded to an FMIC.. and oil changes are a peace of cake without that annoying crosspipe there anymore..
    2001 Audi A4Q LS1 "Race car"
    2009 VW Jetta TDI GTB2265VK, Colt Cam, HP/LP EGR delete "Daily"
    298WHP/591WTQ
    Da Build
  13. Member A4 1.8 Turbo's Avatar
    Feb 28th, 2005
    Allentown, PA
    2004 Audi S4 6 Speed Dolphin Gray
    01-11-2010 01:25 PM #48
    Why are those pipes there on the 180's? Just a weld it in on the production line and if it goes down the 225 conveyer it gets used and if it goes the 180 side it doesnt get used?!
  14. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    01-11-2010 04:42 PM #49
    Its one less special step the factory had to worry about, and its bolted in, so if you have a 180 its very easy to get rid of
  15. Member
    Dec 24th, 2003
    penna
    2001 TT 225 Q
    04-27-2012 12:45 PM #50
    great info, my new to me 2001 tt 225Q, hey TT transport how can i get to your fotki, looks like your intake goes down lo where it works, you have lots of interesting improvements
