VWVortex.com - corrado interior in mk2 jetta
    Results 1 to 20 of 20
    Thread: corrado interior in mk2 jetta
    1. 02-04-2008 12:33 PM #1
      i have a corrado interior that came out of a mk2 gti. i have a mk2 jetta that i want to put it in. I got the front seats in but i cant figure out how the rear seats go in. some help on what to do would be great.
    2. Member taymk2's Avatar
      Oct 21st, 2001
      Middleburg Va
      Alot
      02-04-2008 12:36 PM #2
      it should work but are you going to use the 60/40 split rears
    3. 02-04-2008 09:37 PM #3
      yea i want to. is there a problem using them? and would i need to make any brackets for the back rest?
    4. 02-05-2008 10:56 PM #4
      someone please let me know!!
    5. Member m2coupe's Avatar
      Aug 29th, 2005
      Mk2 Jetta coupe, Mk2 Jetta 4 door carat
      02-06-2008 11:16 AM #5
      ive done it recently. bend the lower side tabs on the upper portion straight. drill a hole in your fender next to the door seal. for the top i just screwed the seats to the seat support from the trunk;but am finding a better way to install th top. i have some errands to run will post pics later [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Modified by m2coupe at 11:35 PM 2-6-2008
    6. 02-06-2008 11:35 AM #6
      thanks dude im gonna try to figure that out today. but pics would deff help alot [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Member stntman's Avatar
      Sep 18th, 2002
      phoenix area whereabouts
      88 carat, 90 g60 corrado
      02-06-2008 11:53 AM #7
      cut the metal behind the rear seat out and swap all the little pieces from the corrado and weld them in.
    8. 02-06-2008 12:25 PM #8
      when you say swap all the little peices from the corrado what do you mean like swap the metal backing?? i dont have the carrado, just the seats.
    9. Member stntman's Avatar
      Sep 18th, 2002
      02-06-2008 12:29 PM #9
      or snag the pieces out of a golf that has a split rear seat. the parts the the seats catches with on the top outside corners. drill out the spot welds and then weld them in. viola rear corado seat. i started doing that in myjetta never welded the pieces in and now they are in washington in a shed somewhere.
      i just set the seats in there and buckled them in
      but now the seats are gone and its jst the front two
    10. 02-07-2008 12:53 PM #10
      ill check it out about the golf peices but does anyone have pictures of when they did it? that would help alot [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    11. Member m2coupe's Avatar
      Aug 29th, 2005
      02-08-2008 02:03 AM #11
      here is where i bent the lower tab straight and drilled a hole through the inner fender( dont worry i used lock nuts and lock washers)
      this is the extra room you get to fill with upholstry but its a good sacrafice for how low they sit
      the set installed
      Modified by m2coupe at 11:22 PM 2-7-2008
    12. Member m2coupe's Avatar
      Aug 29th, 2005
      02-08-2008 02:26 AM #12
      the seat belt and armreast
      i had a friend weld in a lower seat belt bolt and used a golf rear two seater set up
    13. 02-09-2008 12:43 AM #13
      thanks alot for the pics dude. thats going to be a big help when i start doing this tommorow [IMG]http://*****************.com/smile/emthup.gif[/IMG] btw those seat look real good
    14. Member m2coupe's Avatar
      Aug 29th, 2005
      02-09-2008 01:46 AM #14
      thanks man i have the matching fronts as well. did you cut out the restricter plates off the bottom of the front seats? if you do the seats will sit about 3 inches lower
    15. 02-12-2008 12:50 PM #15
      that sounds sick lol im still working on getting those seats in but its to cold here ill post pics when im done
    16. Junior Member Habi-NRW's Avatar
      Jun 17th, 2007
      '11 VW Polo 6R
      02-12-2008 01:54 PM #16
      Since the Corrado backseat is not suitably take a Golf 2 backseat, cut her suitably and refer it with suitable material, or leather! Than it look like this:
      This are my seats
      I must also build the parts!
      Greetings,
      Habi-NRW
      http://www.scenefotos.de
    17. 02-13-2008 11:09 AM #17
      wow those seat are really clean. i have the corrado seats with the cloth in the middle and leather on the outside.
    18. Member My_Gli_Is_so_Fly's Avatar
      Sep 24th, 2007
      N. Jersey/S. Florida
      92' Jetta Gli 2.0 16v(gone), 03' Audi A4 Cabriolet 3.0 V6
      02-13-2008 11:55 PM #18
      i tried to install 2 corrado front seats in my jetta and the seatbelt was an issue. what did you guys do to get the chest seatbelt to work since its 2 different clasps?
    19. 02-15-2008 10:50 AM #19
      take the lap belt from your old seats and there should be a mounting hole on the corrado seats. just put the lap belt there.
    20. Member paste's Avatar
      Dec 26th, 2004
      93 slc, 02 tt, 01 m5
      02-15-2008 11:19 AM #20
      Quote, originally posted by Habi-NRW »
      those corrado recaros?
