VWVortex.com - MK1 polo build thread
    Page 2 of 7 FirstFirst 123456 ... LastLast
    Results 26 to 50 of 169
    Thread: MK1 polo build thread
    1. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      '14 TDI JSW, '03 Xterra, '84 VR Rabbit
      02-10-2008 11:41 PM #26
      Quote, originally posted by DeezUU »
      SUB'D!! Can't wait to see how it ends up.
      BTW: wore those Vans last night!! Lol
      I have some plans coming together in my head. I tore the "system" out and am dropping it off at a repair shop this week. Gotta get that solo speaker thumpin.
    2. Member DeezUU's Avatar
      Oct 10th, 2001
      the 757
      '03 GTI
      02-11-2008 08:38 AM #27
      Lol... the stock sounds were mind blowing, weren't they?!
      David Hasselhoff 1991 Vanagon
    3. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-11-2008 09:09 AM #28
      The stock radio hasn't worked since I got it. It won't turn on. So I am having that repaired. If it is fixable I am going to just roll with the stock system.
      Do you remember exactly what suspension is on the car? I want to go lower and tunershop is a 80/60 kit I am considering.
    4. Member DeezUU's Avatar
      Oct 10th, 2001
      the 757
      '03 GTI
      02-11-2008 09:25 AM #29
      Don't remember the brand (Venom maybe?) but it was 60/40 w/adj rear perches. Don't know if you've looked at the suspension yet but it's a lil' odd. You'll see if you haven't already. The steering arm is attached to the strut. There is a company in the UK that will do coilovers w/front exchange. Best bet if you wanted to go that route is find a used set of front struts in the UK, ship them direct to the fab shop that does the coilovers, then have them sent here. I can try to get you the shop info if you can't find it and are interested.
      BTW, the radio 'works' it's just needs a good lube.
    5. Member DeezUU's Avatar
      Oct 10th, 2001
      the 757
      '03 GTI
      02-11-2008 09:30 AM #30
    6. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-11-2008 09:53 AM #31
      In fact... here you go
      http://www.clubpolo.co.uk/foru...36681
      Yeah,I ran across the Gaz suspension in my hunting. I think I am going to go with the tunershop springs for the time being and see where that puts me. The spring set is only ~$140, and if it is to low I can always put the 60/40 back on. Then I can figure out the coilovers as a last resort for the perfect ride height.
      Whats the trick for the radio? I push the power button and nothing. No light or sound.
    7. Member DeezUU's Avatar
      Oct 10th, 2001
      the 757
      '03 GTI
      02-11-2008 12:56 PM #32
      actually... the knobs are just a beotch to turn. both plastic knobs are broke because the shaft is too tight. I use to do it 'hood' style with a pair of plyers. Pull the left knob off and give it a twist. That button isn't the power. (but don't forget to turn it back off)
    8. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-11-2008 01:18 PM #33
      I will give that a try, should work. I still may take it to this old guy around here that has a repair shop and see if he can loose the knobs or something like that. I am going to keep the stock one in, then use a FM transmitter with my Ipod.
    9. Member oopseyesharted's Avatar
      Mar 2nd, 2005
      Cleveland "Westside"
      07' Rabbit & 86' Cabby
      02-12-2008 02:49 PM #34
      that suspension looks sick!!!!!!
      Did you make any progress on those carbs?
      they looked mighty crusty
      Nothing interesting here.
    10. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-12-2008 03:09 PM #35
      Quote, originally posted by oopseyesharted »
      Probably going to work on cleaning them up tonight.
    11. Member oopseyesharted's Avatar
      Mar 2nd, 2005
      02-12-2008 03:12 PM #36
      you should get your self a gallon of carb cleaner.
      Its available at autozone and advance and comes with a parts basket for dipping/soaking. I use it to clean all my holley parts. Works perfectly for heavily varnished parts like yours.
    12. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-12-2008 03:28 PM #37
      I will keep that in mind. I am going to start with just a spray can of carb cleaner to knock the big chunks off. Then I am going to use my wife's steam cleaner, which I did the bodies with and one float bowl. They came out good. If all else fails I will get a big can of the strong stuff.
    13. Member oopseyesharted's Avatar
      Mar 2nd, 2005
      02-12-2008 04:22 PM #38
      i forgot about you having that steamer.
      looks like it does a nice job.
      hopefully it all works out well. i am getting some carbs soon as well. I cant wait to try them.
    14. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-12-2008 05:54 PM #39
      Yup, actually shot them with carb cleaner a few min. ago. Just waiting on the steamer to heat up. I will have some pictures of them tonight.
    15. Member DeezUU's Avatar
      Oct 10th, 2001
      the 757
      '03 GTI
      02-12-2008 08:46 PM #40
      It's actually a relatively simple setup. In fact... take a pic of it when you get it in the air, Devin. I use to get asked all the time what kind've setup it was and explaining an I arm setup always raises an eyebrow! Lol.
    16. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-12-2008 08:55 PM #41
      Yeah, its beautiful in that as long as you don't mess with the steering rods you don't have to get it aligned at all. So when I change springs or put lowering caps in I can just slap it back together and go. I will get some pictures when I get it apart. I am going to go with a 10mm lowering cap first, see how I like that, then maybe 80mm springs.
    17. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-12-2008 11:04 PM #42
      Have the carbs cleaned up. I need to go to the local bike shot and get new gaskets for the float bowls. They are pretty brittle and I doubt they will seal properly.
    18. Member hyperformancevw's Avatar
      Mar 14th, 2007
      Ocean City, MD
      Euro Turds and an '08 Kawi zx10
      02-13-2008 10:53 AM #43
      looks 10x better. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      -87 Golf GT, built BT 1.8t 12.02@119 1.96 60' HX35@18psi pump gas (sold/parted out)
      -64 ratty bus "the slamper"
      -91 Jetta ALH TDI swap
      -80 diesel caddy
      -76 BMW 2002
    19. Member oopseyesharted's Avatar
      Mar 2nd, 2005
      02-13-2008 11:00 AM #44
      Quote, originally posted by hyperformancevw »
      X2
    20. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-15-2008 01:13 PM #45
      O-rings for the float bowls on the way...And new wheels on the way.
    21. Member oopseyesharted's Avatar
      Mar 2nd, 2005
      02-15-2008 04:22 PM #46
      Quote, originally posted by BadassLilGolf »
      Wheels???
      What wheels???
      tell tell tell......lol
    22. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-15-2008 06:25 PM #47
      Wheels???
      What wheels???
      I will let them be a surprise. The should be here next week.
    23. Member oopseyesharted's Avatar
      Mar 2nd, 2005
      02-15-2008 07:16 PM #48
      come on now!!!!
      dont do that
      LOL
    24. Member DeezUU's Avatar
      Oct 10th, 2001
      the 757
      '03 GTI
      02-15-2008 07:26 PM #49
      Lol... secrets suck!!
      BTW > anyone know how to open the door of a mk3 when your Polo handle takes a dump??
    25. Member BadassLilGolf's Avatar
      Mar 21st, 2001
      York, PA
      02-15-2008 10:02 PM #50
      All good things come with time.
      Only if it is the front pass. side door. Stand outside the car and flick the handle a bunch of times in rapid succession. Just keep doing that until the door opens. It isn't the polo handle, it is the latch. It probably doesn't open from the inside either.
