VWVortex.com - black smoke/soot on tail pipe
    Results 1 to 23 of 23
    Thread: black smoke/soot on tail pipe
    1. Banned zeroman's Avatar
      Nov 19th, 2006
      02-07-2008 02:09 PM #1
      so ive searched and not too many on ball answers to my question. I just started up my car, last night there was a huge snow storm... There was a bit of snow in my tail pipe, so i decied to start my car up and see what it sounded like...
      Perfectly fine, but i noticed that the fumes that were coming out of the tail pipe were black under high RPMs and black soot would come out. Now I am assuming this would be carbon build up and its normal but the black smoke part of it what is it? I changed oil about 1000KMs ago with Castrol GTX 10w-30 with a VW dealer filter (rated for 10, 000 KMs )
      I have not checked my oil levels lately as its been so damn cold, i know i could be low but not low enough where theres no oil and i hear my lifters, and i did not over fill it as well....
      95 2.0L ABA with chip 2.25" exhaust and intake. Its swapped into an 85 mk2. Should i be worried?
    2. Banned PELLA's Avatar
      Mar 4th, 2006
      02-07-2008 02:56 PM #2
      sounds like you got yourself a blown gasket
    3. Member 89VWdieselGolf's Avatar
      Feb 22nd, 2004
      Durham, Ont.
      2003 VW Jetta 1.8T race car
      02-07-2008 03:18 PM #3
      Quote, originally posted by PELLA »
      black smoke is fuel bud
      white is coolant (head gasket)
      blue is oil
      Jeff
      (btw, your "hydroplaining" signature is retarded)
      Modified by 89VWdieselGolf at 3:20 PM 2-7-2008
      89VWdieselGolf's Autobiography
      2003 Jetta 1.8T Race car
      1990 Golf ABA Turbo -SOLD
    4. Member
      Jul 31st, 2002
      '74 Bug (yard), '96 Jetta 255K (yard), '02 Cabrio 104K (sold), '06 Rabbit 127K BGP, '08 Jetta 55K
      02-07-2008 04:40 PM #4
      Sounds like you are running rich. When I had misfiring due to a bad coil, I had a sooty tailpipe. Right now, there is nothing there.
      I paid attention to this because my Jeep has a sooty ring around the end of it. Some on the Jeep board suggested it is normal, but I'm not buying it...
    5. Member 89VWdieselGolf's Avatar
      Feb 22nd, 2004
      Durham, Ont.
      02-07-2008 05:15 PM #5
      he said its only when its cold out, the motor isnt up to operating temp therefore its not completely burning ALL the fuel... its not rich. Its cold.
    6. Member
      Jul 31st, 2002
      02-07-2008 05:35 PM #6
      The mixture is rich at cold start up. Even then, it sounds like he is having more black smoke than you'd see at a cold start. Any drivability issues at all?
    7. Banned zeroman's Avatar
      Nov 19th, 2006
      02-07-2008 10:05 PM #7
      it was like start up and rev and i looked out it wasnt a constant black cloud it was just a puff never noticed that or seen it when it was warm. I know i'm running rich as my o2 wasn't hooked up after my swap for a while and my plugs are a bit dirty and i need to change them or i'll continue to run rich
      and no, theres nothing changed in the way the car drives. pulls strong and hauls ass
      Modified by zeroman at 10:06 PM 2-7-2008
    8. Banned PELLA's Avatar
      Mar 4th, 2006
      02-07-2008 10:13 PM #8
      Quote, originally posted by 89VWdieselGolf »
      blue is oil
      Jeff
      its jay-z!
      Jul 31st, 2002
      02-07-2008 10:55 PM #9
      Save the rolleyes next time, eh?
    10. Banned zeroman's Avatar
      Nov 19th, 2006
      02-07-2008 10:55 PM #10
      yah its jay-z lol and hes so crappy...30 something years old!! anyways so this isn't much i have to worry about new plugs and i should be good with my running rich issue ive got.
    11. Member 89VWdieselGolf's Avatar
      Feb 22nd, 2004
      Durham, Ont.
      02-08-2008 08:07 AM #11
      Quote, originally posted by FL 2.0L »
      why it was already said what the problem was... and some other "diagnostic" gets posted
      Jul 31st, 2002
      02-08-2008 05:46 PM #12
      Quote, originally posted by zeroman »
      That's why.
      Modified by FL 2.0L at 5:47 PM 2-8-2008
    13. Banned
      Jan 5th, 2008
      02-10-2008 05:47 PM #13
      Another possibility is that your PCV hoses are cracked and or leaking. Check the rigid plastic pipe that connects into the engine block, and the elbow pipe that connect into the pcv valve. Believe it or not if this is leaking the car will apparantly burn some oil. As soon as I discovered this I sealed any cracks and voila the oil burning is gone. like Dan Reed says those pipes/hoses only last till about 95 k or so. replace all and don't forget to replace the o ring that goes into the rigid plastic pipe to the block.
    14. Member
      Aug 16th, 2007
      Atlanta
      02-15-2008 05:40 PM #14
      I'm 100% stock, 18000 miles, and my friends driving behind me yesterday called me on my cell phone going down the interstate to tell me my car was putting out very black smoke when accelerating. I was at normal operating temperature.
      :X
      2015 Audi S3 Prestige w/Advanced Tech.
      -Rear Tails as DRLs Additionally
      -Light Selector to 0 -> All Lights Off
      -Enabled Active Lane Assist MMI European Menu Options
      -Enabled Active Cruise Control Automatic Go from Stop
    15. Member
      Jul 31st, 2002
      02-15-2008 06:09 PM #15
      You need the MKV forum or the 2.5L engine forum...
    16. Banned zeroman's Avatar
      Nov 19th, 2006
      02-15-2008 10:54 PM #16
      i had a crack in the PCV hard plastic pipe at one ponit in time. i fixed that along with a new crankcase breather. It was determined it was running rich due to the car not being fully warm.
      My next pet peve is the search blows for figuring out how to run a breather filter...I've got a thread for that thought trying to figure out info. I will change my plugs tomorrow to solve the rich running issue.
    17. Member
      Jul 31st, 2002
      02-15-2008 10:56 PM #17
      Search for "catch can mod" or "catch can" or something similar.
    18. Banned zeroman's Avatar
      Nov 19th, 2006
      02-15-2008 11:01 PM #18
      check out my other thread in this forum you seem to be alot of help
    19. Member
      Jul 31st, 2002
      02-16-2008 12:23 AM #19
    20. Member mrdub27's Avatar
      Mar 24th, 2002
      London ON, Canada
      97 MK3 2.slow GTI
      02-16-2008 09:13 AM #20
      TbH it does sound like you need to :
      A hook up that O2
      B check your fuel mixture..
      Yes the car runs rich at start up until warm but it sounds like under throttle your over fueling which is supposed to be compensated by the O2 and also maybe you need to replace the temp sensor that tells the engine ecm the coolant temp.. if it has failed it reads cold all the time it will always run rich.. my o2 went and my fuel mileage dropped badly and I also found a bad temp sensor too.. plugs started to foul quickly too.. have ya checked your plug gap.. maybe it's too big and that could also cause unburnt fuel too under throttle..
      Yes mine is MKIII but the issues like this are the same on the MKIV 's.. get someone to hok up a a/f gaugeand see if you are running rich all the time.. also I'd check the air filter.. if it's dirty it can choke the engine making it run rich too
    21. Banned zeroman's Avatar
      Nov 19th, 2006
      02-16-2008 09:36 AM #21
      Air filter replaced yesterday, i have trouble with a stupid broken filter from its casing. The o2 sensor is hooked up I can tell when its not car idles rough. Its my plugs i have determined. Plus it was a cold start up rev.
    22. 02-17-2008 03:15 AM #22
      its just the chip. My car ran rich for a while because of the chip.
    23. Banned zeroman's Avatar
      Nov 19th, 2006
      02-17-2008 08:02 AM #23
      i changed plugs got some NGK v powers and did a sea foam an dshe runs alot better
