VWVortex.com - New Key Programming
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 85
    Thread: New Key Programming
    1. 05-21-2002 08:15 AM #1
      Anyone know how I can program my own new key transmitter?
      THanks
    2. 05-21-2002 09:30 AM #2
      if your talking about the chip inside the key,you need to use either the vagcom software or visit a dealer
      if its the remote for the alarm,that you can do by yourself.
    3. Banned
      Oct 4th, 2000
      05-21-2002 10:04 AM #3
      The procedure is in the manual.
    4. 05-21-2002 10:06 AM #4
      Yes, what he said. If you search, you will find instructions on how to reprogram the remote functions of a key but you will not be able to drive the car with it until ALL of your keys have been reprogrammed by a VAG COM.
    5. 05-21-2002 11:18 AM #5
      I would be interested in finding out how to program the remote. Is the chip in the actual key blade or in the remote itself. If its in the blade, I can switch the blade from my old key and program the new remote myself right?
      How do I program the remote myself?
    6. Member
      Jan 15th, 2002
      Brooklyn, NY
      05-21-2002 11:19 AM #6
      I read that you can just program your key somehow..something like turn igniftion..offf..button..something like that.
      And the key is just laser cut for your car.
      (I think..search)
      Samc
    7. 05-21-2002 11:41 AM #7
      The chip is in the remote part of your key, not the blade.
      To program the remote functions on a new key, get in your car with the car off and the driver side window rolled down.
      insert the new key into the ignition
      insert your vallet key in the driver side door lock (outside the car)
      turn the vallet key towards lock and hold it there
      while it is held towards lock, press the unlock button on your new remote for
      2 seconds.
      let go
      press it again for 2 seconds
      let go and you should hear an alarm honk or something like that.
      This is from memory so it may not be right. I would recommend searching archives. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    8. 05-21-2002 10:28 PM #8
      the key programing worked perfectly and saved me some $$$
      Thanks for the info
      jc
    9. Member unclubbedvdub's Avatar
      Jul 19th, 2002
      MD
      '01 S/C VR6 '12 TTRS
      03-24-2003 12:57 AM #9
      you coul;d just swap circuit boads
      i did it
      swapped boards and blade part
      now i have a new clean key
      2012 Sepang RS Banger
      2001 Supercharged Galactic Jetta Whore
    10. 03-29-2003 06:30 PM #10
      will this trick work on all MKIV keys? I have the old style key (and the key chain clips broke) I have been thinking about getting used ones off e-bay. Will they work or do I need to buy the same style key? Could I use an audi key on my car also? And just so I get it straight, after I do this the new key will work like my old one (auto lock doors, trunk, alarm)?
    11. 04-17-2003 08:50 PM #11
      i work at a dealership..... does this mean i can program MY key (FOB) to open another VW???
      Jul 24th, 2002
      2001 VR6 Jetta IV
      04-17-2003 09:05 PM #12
      Yeah, but you NEED to have two keys. One for the ignition and one for the door lock
    13. Member
      Jul 24th, 2002
      2001 VR6 Jetta IV
      04-17-2003 09:09 PM #13
      Yeah, i got the older key style and bought a new remote section for like 20 bucks and programmed it myself. Also did it for my mom b/c i put her remote through the washer
      Im not sure if the new VW remotes will fit on the old key section...
      and yes, after you re-program the remote all the functions should work.
    14. 04-17-2003 09:18 PM #14
      so your telling me i can make my keys work for any car on the lots....i.e., if I go to a VW dealership somewhere else, I can program my key to open their doors and their trunk.... and then i can ALSO swap the key only part with them and threy will never know... i can steal a VW that easily?... wow, the radios are easy to steal... the cars are easy to steal... these cars need more security!
    15. 05-07-2003 10:57 PM #15
      i'm having a hard time doing this.
      when you actually turn the valet key & hold it. then window closes & door gets locked. can somebody please help me with brief information??
      thank you.
    16. 05-08-2003 08:12 PM #16
      bump
    17. 05-29-2003 05:20 AM #17
      Quote, originally posted by madtiger »
      thank you.
      he didnt say to close the door...
    18. 06-02-2003 01:07 PM #18
      i have a calet key that isnt coded to my car yet, can the process be done in reverse to the valet key???? i can only try this two more times before the cmputer locks out all my keys
    19. 06-02-2003 01:13 PM #19
      How do I make mine make me toast and orangejuice in the morning? Thanks.
    20. 07-07-2003 11:44 PM #20
      Ok, I bought a new key from fellow vortexer. I got the key and used programming instructions in owners manual and the remote funtions work perfect. NOW HERES THE PROBLEM I'M HAVING.....The key needs to be rekeyed for my car. None of my local key shops/locksmiths have blanks(a couple of the locksmiths can cut blanks((ie-valet type))but dont carry the blanks to work with keyfob. I went to dealer service center, they "broke" key in half, said they have to order the key section cut per vin. Is this correct?? Is there a better(cheaper) option. Anybody work at a dealer and have any knowledge???? They wanted about 60.00 just for key half of key.. HEEELLLPPPP
    21. 07-08-2003 12:23 AM #21
      Man am I glad that this post came along. I was on the verge of posting the same questions listed thus far. Here's a bump for you.
    22. 07-08-2003 12:47 AM #22
      ok my brother just got a new GTI and has 2 keys...he is letting me have one of them since i have the older style key. Can I use his new style key for my 2001 jetta? i mean the whole thing, not just the remote part....thanks
    23. 09-17-2003 11:50 AM #23
      So...I'm going to buy a blank key from and http://www.streetkeys.com and then i can do the basic programing and use it for remote start key?
      I do not need it to be cut to start my car? correct?
    24. 09-17-2003 11:55 AM #24
      can regular
      Quote, originally posted by tORiSbORa »
      Who else can cut these keys (but the dealer)
    25. 09-17-2003 11:57 AM #25
      Quote, originally posted by RedDevil »
      can regular
      I do not need the key cut. Thats my question..if I buy a blank key and program it the way people did above it will work for remote start?
