The Readiness Code is a set of 8 bits, each of which corresponds to one monitored emissions "system" in an OBD-II car. When all readiness bits show "Passed", it means that all systems have been checked and have passed the on-board tests. Whenever you clear DTC's or remove power from the ECU, all readiness bits will be set to "fail".
It takes a variety of specific driving conditions to "test" all the systems. It can be done in a short time using a very specific and complicated procedure.
http://www.ross-tech.com/vag-c....html
Since Release 704, Vag-Com has had the ability to guide the user through the process of setting Readiness on those engines which support it. The current coverage is nowhere near complete.
We are currently working our way through the Vw/Audi US engine code list from 96-08 and are looking for testers for the newly created scripts.
Please send me an email (santos@ross-tech.com), containing an Auto scan and a Channel Map. We will use the information to generate the appropriate script for the car.
The Channel Map can be generated by: selecting:
Applications -> Controller Channel Map -> Address 01,
Pre-Label file.
Function = Measuring Blocks
Login = <leave blank>
Output = Pre-label file
Please See: http://wiki.ross-tech.com/inde..._Maps For more information on Control module maps.
The Following scripts are Available for testing:
VW
UPDATED 4-9-08)
ABA Cabrio(96-02), Golf (96-99), Gti (96-99), (Jetta (96-99) Passat (96)
AEB Passat\Passat Wagon (98-99)
AHA Passat\Passat Wagon (98-99)
AFP GTI(99.5-02), Jetta(99.5-02), Jetta Wagon (01-02)
APH New Beetle (99-01)
AUG Passat\Passat Wagon (00-01)
AWD Golf\Jetta\Gti (00)
AWM Passat \Passat Wagon (01-05)
AWW Golf (01) Jetta (01-02) GTI (01)
AVH Golf (01-06), Jetta (01-03), Jetta Wagon (01-04) New Beetle(01-05)
AWP GTI (02-06), Jetta (02-05), Jetta Wagon (02-06), New Beetle (01-05)
AZG Golf(01-04,), Jetta (01-02_04), Jetta Wagon (01-02_04) New Beetle (01-05)
BDF Gti (02-05) Jetta (02-03)
BDP Passat(02-04) Passat Wagon (02-04)
BGP Jetta (05-07), Rabbit (06-07)
BGQ Jetta (05-07), Rabbit (06-07)
BPR New Beetle (06-08), Beetle Convertible (06-08)
BPS New Beetle (06-08), Beetle Convertible (06-08)
BKF New Beetle Convertible (04-05)
BJS R32 (04)
BAA Touareg (04-07)
BBW Jetta (05)
BMX Touareg (04-07)
AXQ Touareg (04-07)
BHX Touareg (04-07)
BGJ Phaeton (04-06)
BGH Phaeton (04-06)
BEV Golf (04-06), Jetta (04-05) Jetta Wagon (04-06) New Beetle(04-05) Beetle Convertible (04-05) City Jetta (07-08) City Golf(07-08) 2 Different Versions of the script Available.
BGD New Beetle Convertible (04-05)
BAP Phaeton (04-06)
BHW Passat (04-05) Passat Wagon (04-05)
BEW Golf (04-06), Jetta (04-05) Jetta Wagon (04-06) New Beetle(04-07)
BKW Touareg (04-05)
BWF Touareg (06-08)
North American 2007> MY- All engines except Diesel.
Audi: (UPDATED 4-7-08)
BHE TT (04-06)
BFH S4 (04-07) S4 Avant (04-06)
AEB A4(97-99) A4 Avant (99)
AEW A8 (97-99)
ABZ A8 (97-99)
AWN A6 (01-04)
AWM A4 (01) A4 Avant (01)
AUX A8l (01-03) S8 (00)
AYS A8l (01-03) S8 (02-03)
AHA A4 (98-99) A4 Avant (98-99) A6 (98-99) A6 Avant (99)
ART A6 (99-00)
APB A4(01) A4 avant (00-01) A6 (00-02) S4(00-02) S4 AVANT (01-02) ALLROAD (02-03)
AKB A8 (00)
ATC TT (00)
AMU TT (01-03)
AMB A4 (02-05) A4 AVANT (02-04) A4 CABRIOLET (03-06)
AWP TT (01-06)
BEA TT (02-06)
BBD S6 Avant (02-04)
BEL A6 (03-04) Allroad (04-06)
BCY RS6 (03-04)
BFM A8 (05-06) A8L (04-06)
BPY A3 (06)
CAUA S5(08)
The following Engine codes have been successfully tested and are included with the latest release.
CAU
AZA
ATQ
AHA
APE
AXK
AFP
AEB
AXX
ASN
AVU
AWW
AWP
AMU
AEG
Modified by Santos@Ross-Tech.com at 11:45 AM 8-8-2008
Modified by Santos@Ross-Tech.com at 2:22 PM 10-20-2008
