VWVortex.com - Testers Wanted!! Guided Readiness Scripts
    Page 2 of 5 FirstFirst 12345 LastLast
    Results 26 to 50 of 115
    Thread: Testers Wanted!! Guided Readiness Scripts
    1. Member fixmy59bug's Avatar
      Apr 9th, 2002
      1959 Vw Bug
      04-27-2008 08:52 PM #26
      Is there anything needed from a Tiguan?
      As soon as my dealership gets some in, the sales manager is going to let me take one to a GTG to show it off and maybe get some customers in.
      While I got it I can get a scan of anything you need.
      I just need to know how to do it. =^)
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      04-27-2008 09:51 PM #27
      We have tested on a couple of European Tiguans already, but US models usually get slightly different engines and such. Would be nice if you could send us some Control Module Maps (only from undocumented modules). Make sure to use the latest Beta for your tests/scan, the old Release 704 may not be fully compatible.
    3. Member fixmy59bug's Avatar
      Apr 9th, 2002
      1959 Vw Bug
      04-28-2008 01:54 AM #28
      Ok. I already have version 803.4 So once I can get my hands on the Tiguan I will scan what ever I can.
      Darn you guys for getting the cars before us. And for getting all the cool cars that we can't have.
    4. Member jessla's Avatar
      Feb 10th, 2002
      Williamson,
      05-04-2008 06:29 PM #29
      Andy, I'll do BJS R32
      GT35, HFC, Neuspeed exhaust. FK Silverline Plus X.
      Cleary Coachworks Clutch and Turbo Install.
    5. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      05-05-2008 10:08 AM #30
      Quote, originally posted by Santos@Ross-Tech.com »
      Please send me an email (santos@ross-tech.com), containing an Auto scan and a Channel Map. We will use the information to generate the appropriate script for the car.
      The Channel Map can be generated by: selecting:
      Applications -> Controller Channel Map -> Address 01,
      Pre-Label file.
      Function = Measuring Blocks
      Login = <leave blank>
      Output = Pre-label file
      Please See: http://wiki.ross-tech.com/inde..._Maps For more information on Control module maps.
      VCDS Diagnostic System For VW/AUDI/SEAT/Skoda/Bentley
      www.Ross-Tech.com
    6. 05-25-2008 09:57 PM #31
      sent you a file from a friends A6 [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    7. Junior Member
      Sep 6th, 2006
      SoCal
      1996 Jetta 2000 Passat 2005 RAV4 1985 Mercedes 300D 2007 Mercedes C230 1989 BMW E30
      06-20-2008 02:20 AM #32
      How about the AGZ engine found in the euro 2000 passat?
    8. Member tyrantanic's Avatar
      Jun 14th, 2004
      2001 Jetta Wolfie
      06-27-2008 08:09 PM #33
      Bump, I sent my files over and a list of mods. Too bad i waited till the last minute, I need my inspection asap haha
      Even a stopped clock gives the right time twice a day.
      Oct 15th, 2006
      Puyallup WA
      91 GLi 16v 2012 Golf TDi 06 mkV Jetta2.5
      07-11-2008 05:11 PM #34
      I'd like to test the readiness script for the 1k jetta with the 2.5
    10. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      07-14-2008 10:03 AM #35
      Please send me an email containing an auto scan and a channel map. The instructions are listed in my first post.
      www.Ross-Tech.com
    11. Member ejg3855's Avatar
      Sep 23rd, 2004
      Rochester, NY
      1993 UrS4
      08-05-2008 09:17 PM #36
      So once you have these map files is there a way to make use of them to have all readiness pass?
      This thread seems about gathering information regarding the maps but not about how to use them
      CUSTOM TUNING - IMMO DEFEAT - AWD DYNO - FABRICATION - MACHINED/DESIGNED PARTS
      NOW OBD FLASHING MK6/MK7 2.0T
      BREAKOUTMOTORSPORTS
    12. Forum Sponsor Andy@Ross-Tech.com's Avatar
      Jun 5th, 2002
      2015 GTI SE 6MT
      08-06-2008 11:06 AM #37
    13. 10-23-2008 01:54 AM #38
      Stepped through setting readiness on 2001 Audi allroad 2.7t using the built in readiness function - it was using 078-907-551-aza.crd
      My question is when I was going through I got no response in "evap purge valve diagnostic" i just forwarded to the next step but was curious if this is a problem. (w/my car or your script)
      It should be noted that I have been getting o2 and cat codes (before readiness and after) if that makes a difference. I have questions about that but I'll save them for another thread.
      Really have no idea but the readiness was great... thanks.
      VCDS Version: Release 805.0
      Data version: 20080625
      Address 01: Engine
      Control Module Part Number: 4Z7 907 551 K
      Component and/or Version: 2.7l V6/5VT G 0001
      Software Coding: 06752
      Work Shop Code: WSC 02325
      Additional Info: WAUYP64BX1N0xxxxx AUZ7Z0Y1635238
    14. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      10-23-2008 10:36 AM #39
      I just checked the script and it looks like i made a typo when entering the basic setting group.
      You can manually start the test by going into basic settings and select group 70.
      Allow engine to idle until:
      Field 4 Displays: Evap OK
      www.Ross-Tech.com
    15. 10-23-2008 01:32 PM #40
      Thanks
    16. 10-24-2008 10:47 AM #41
      would it be possible to get the scripts for the following engine cods-
      engine code
      -2.0t bpy
      -2.5l bgp
      bgq
      bpr
      bps
      -v6 3.6l blv
      -v10 dsl turbo bwf
      -v6 3.6 bhk
      -v8 4.2 bar
      -v6 3.2 bub
      any info would be great just let me know what is offered and what i could recieve.
    17. 11-07-2008 10:36 AM #42
      my 04 r32 wont set its readiness for the catalytic converter part, and the secondary air, and i have no check engine light as of now, so what can i do to get at least one of them ready????
    18. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      11-11-2008 12:43 PM #43
      Please send me an email containing an autoscan from your car. I have not received any feedback from our customers with modded R32s passing using the script. So our guided script may or may not work.
      Modified by Santos@Ross-Tech.com at 8:46 AM 11-11-2008
      www.Ross-Tech.com
    19. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      11-11-2008 12:48 PM #44
      Quote, originally posted by Eric@Gene’sForeignCar &raquo;
      -2.0t bpy
      -2.5l bgp
      bgq
      bpr
      bps
      -v6 3.6l blv
      -v10 dsl turbo bwf
      -v6 3.6 bhk
      -v8 4.2 bar
      -v6 3.2 bub
      We are currently testing scripts one at a time. Each script must be erased before scanning another vehicle. Please send me an autoscan from the car at the time you need to set readiness.
      www.Ross-Tech.com
    20. 11-15-2008 04:15 PM #45
      need anything from a 97 jetta gt 2.0 automatic
    21. 11-24-2008 09:23 PM #46
      hey santos i believe i have the latest release of vag.. i have a 96 gti .. do u need me to send you scripts to get the "set readiness " function or is it not possible with my car. Thanks
    22. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      12-01-2008 10:16 AM #47
      Quote, originally posted by _pineapplegti_ &raquo;
      Please send me an auto scan of your car via email.
      www.Ross-Tech.com
    23. 12-11-2008 05:41 PM #48
      I have a 2000 A4 Avant with engine ATW. Do you need a tester for this one? I didn't see it listed in either list. It's a 1.8t 4 cylinder, no mods......YET! L:MK
    24. 12-16-2008 07:05 PM #49
      Modified by Gozer The Destructor at 9:26 AM 12-17-2008
    25. 12-17-2008 12:42 PM #50
      E-mailed you the info on a AAA 96 VR6 Jetta. Hoping you can get to it soon, We keep failing inspection cause we have to clear the DTC's for SAI before going.. Thanks!
