VWVortex.com - Testers Wanted!! Guided Readiness Scripts
    Page 3 of 5 FirstFirst 12345 LastLast
    Results 51 to 75 of 115
    Thread: Testers Wanted!! Guided Readiness Scripts
    1. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      12-17-2008 12:49 PM #51
      Our readiness scripts force the tests to initialize not to "trick" the system into making it pass. If a problem truly exists you will fail that bit and may have a CEL.
      VCDS Diagnostic System For VW/AUDI/SEAT/Skoda/Bentley
      www.Ross-Tech.com
    2. Member o2bad455's Avatar
      Aug 22nd, 2003
      Northeast US and Canada
      VW (A1) Mk2 Scirocco ABA2L16vT, VW (A4) Jetta 1.8T, Audi (B5) S4 2.7T
      01-31-2009 12:29 AM #52
      Quote, originally posted by BlckIvie6xoxo9 »
      E-mailed you the info on a AAA 96 VR6 Jetta. Hoping you can get to it soon, We keep failing inspection cause we have to clear the DTC's for SAI before going.. Thanks!
      Quote, originally posted by Santos@Ross-Tech.com »
      Most states allow at least one unset readiness bit, and some allow several. This isn't a "trick". I have an unsolved SAI issue with a 97 AAA too, but have been able to set all the other readiness bits using VAG-COM and pass emissions before the SAI became ready and kicked the CEL on. Obviously, a script would have made it a bit easier, as long as one or more readiness bits/systems (e.g., SAI) could be skipped. It would be nice if the scripts allowed this.
      Modified by o2bad455 at 11:39 PM 1-30-2009
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      02-01-2009 07:32 PM #53
      Simply pressing next at the bit/thing you are trying to skip should do what you're asking.
    4. Member o2bad455's Avatar
      Aug 22nd, 2003
      02-01-2009 10:22 PM #54
      Quote, originally posted by Theresias »
      I think you're right, but not positive. I juggled the order of the other tests when trying to get it through, but I'm not sure if that was necessary or just coincidence.
    5. 02-06-2009 02:09 PM #55
      Hi Santos, Andy
      I have the 08 TT w/ engine code BWA.
      Are you looking for info on this platform as well?
    6. Member
      Feb 11th, 2004
      Magdeburg, Germany
      02-06-2009 05:45 PM #56
      2.0Ts AXX/BWA/BPY etc. are covered. Thanks for asking.
    7. 02-27-2009 10:32 PM #57
      My car wont set readiness for SAI or O2 sensors. Here is the auto scan... Any advice would be great.
      Chassis Type: 1J - VW Golf/Bora IV
      Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
      76
      VIN: 9BWDE61J134052348 Mileage: 81640km/50728miles
      Address 01: Engine Labels: 06A-906-032-AWP.lbl
      Part No: 06A 906 032 LP
      Component: 1.8L R4/5VT G01*0005
      Coding: 11510
      Shop #: WSC 10002
      XXXXXXXXXXXXXXXXX XXXXXXXXXXXXXX
      No fault code found.
      Readiness: 0010 1000
      Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
      Part No: 1C0 907 379 K
      Component: ASR FRONT MK60 0103
      Coding: 0021505
      Shop #: WSC 00000 785 00200
      Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
      Part No: 1C0 909 605 F
      Component: 08 AIRBAG VW61 0202 0001
      Coding: 12344
      Shop #: WSC 00000
      Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
      Part No: 1J0 920 906 J
      Component: KOMBI+WEGFAHRSP VDO V07
      Coding: 07232
      Shop #: WSC 25641
      9BWDE61J134052348 VWZ7Z0C6715048
      1 Fault Found:
      01177 - Engine Control Unit
      64-10 - Not Currently Testable - Intermittent
      Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
      Part No: 6N0 909 901
      Component: Gateway K<->CAN 0001
      Coding: 00006
      Shop #: WSC 00000
      Address 46: Central Conv. Labels: 1C0-959-799.lbl
      Part No: 1C0 959 799 C
      Component: 8B Komfortgerát HLO 0003
      Coding: 00064
      Shop #: WSC 00000
      Part No: 1C1959801A
      Component: 8B Tõrsteuer.FS KLO 0009
      Part No: 1C1959802A
      Component: 8B Tõrsteuer.BF KLO 0009
      Address 56: Radio Labels: 3B7-035-1xx-56.lbl
      Part No: 3B7 035 180
      Component: Radio ZSW 0018
      Coding: 00031
      Shop #: WSC 00000
      End ---------------------------------------------------------------------
    8. Member VWTattoo's Avatar
      Apr 25th, 2001
      Reading, PA
      2016 Tiguan SEL (wife's car)-bye 2004 R32 ...bye 84 Scirocco
      03-05-2009 06:53 PM #58
      Hello- I'm trying to get the Secondary Air Injection bit to pass for inspection, and have an 04 R32 with only a BMC CDA for a mod. Is there a script that I can try to set this to pass for inspection, as well as for the rest of the script processing to help you out with this engine code? I have no codes to clear at this point, but can scan for whatever you'd like and send it to you.
      UPDATE: Sent AutoScan.txt to support. [IMG]http://*****************.com/smile/emthup.gif[/IMG] (03/05/09, 6:00 PM ish)
      UPDATE 2: No reply back since sending that file. Did I not send the file correctly? I just want to help get the BJS engine code script working for y'all. My SAI Reaidness was set by Friday AM, so I had all 0's for the emissions inspection and I am in no need to get it set for myself, but if it helps to have someone test this for the masses, I am willing. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      UPDATE 3: File Received from Santos this AM, will test tonight, hopefully! ---Just tried it, couldn't get the Set Readiness button to be clickable. Sent email to Santos.
      VWTat
      Modified by VWTattoo at 6:53 PM 3-9-2009
    9. Member Fissues's Avatar
      Nov 6th, 2008
      Marblehead
      '09/TTS/Roaster/APR Tuned 100 Octane, '11 S5 Cabrio
      03-11-2009 08:53 PM #59
      Just got my Vagcom cable. Can I be of any help with my TTS Roadster? Not that I would know how yet.
      Modified by Fissues at 5:04 PM 3/11/2009
      '09 TTS/Roadster/APR Tuned/100 Octane - 1st TTS delivered in the US, '11 S5 Cabrio
    10. 03-23-2009 03:13 PM #60
      I found an error, which I thought I had fixed in an earlier release by editing a script or *.lbl file.
      Engine: AWW 1.8t (North-American)
      When going through the automated readiness script in the latest VCDS release, version 80x.x, it asks to verify the O2 sensor status as 111, and 110, this is found in block 030.
      Block 30 should read: "Oxygen Sensor Status, Bank 1, Sensor 1, Spec: 111, Bank 1, Sensor 2, Spec: 110"
      The script shows Block 028; Knock Sensor Test, instead of block 030. Block 030 does not come up at all when Setting Readiness via. the VCDS Script. I would assume this is just a small type-o on Vag-Com's end. I double checked in the MKIV Bentley DVD just to be sure, and block 030 is correct.
    11. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      03-23-2009 03:16 PM #61
      Thanks for the feedback. I will make the necessary corrections. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      www.Ross-Tech.com
    12. 03-26-2009 09:20 AM #62
      Woopi!! I would highly appreciate do the one for the AFP if you ever do it.
    13. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      03-26-2009 10:21 AM #63
      The AFP readiness script is already included in VCDS.
      www.Ross-Tech.com
    14. 04-03-2009 12:17 PM #64
      is the script in the vcds for aeg? i tried and i can't seem to get it to run...i get it saying "test off" alot
    15. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      04-04-2009 11:50 AM #65
      I'm currently on Vacation but should be back on Tuesday. I have a 99.5 jetta with an AEG and will be able to test it pretty quick.
      www.Ross-Tech.com
    16. 04-10-2009 09:19 PM #66
      do you know some internet pages with manuals for v.a.g 1799 and v.a.g 1551?? thancks
    17. 04-11-2009 02:18 PM #67
      Quote, originally posted by Santos@Ross-Tech.com &raquo;
      i got it to go..it was cold and just took a bit of extra time
    18. 04-14-2009 12:34 AM #68
      I have an AMB ('04 A4 1.8T). I'm willing to be a guinea pig if you need me =P
    19. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      04-15-2009 10:22 AM #69
      please send me an email with an autoscan and channel map.
      www.Ross-Tech.com
    20. 05-06-2009 11:38 PM #70
      Santos, we're one of your clients from Reading Pa. If you are missing certain ECM's, give me a shout. http://www.mairscontinentalmotors.com
    21. 06-19-2009 10:27 AM #71
      If you guys would like to send me a Micro-CAN cable I'll be happy to test out 3.6 VR BLV.
      I plan to buy one soon anyway.
    22. Member Jonmedic's Avatar
      Apr 20th, 2009
      British Columbia Canada
      2011 Touareg Comfortline TDI, 2012 Beetle, 2015 Audi Q3
      06-29-2009 03:44 PM #72
      I have a 2009 Passat CC 2.0T Sportline with Auto Trans purchased in Alberta Canada. I would love to do some Beta testing for you.
    23. Senior Member PanEuropean's Avatar
      Nov 3rd, 2001
      Toronto, Canada
      2015 Golf Highline
      08-17-2009 03:17 AM #73
      Santos:
      Attached is a document that explains how to set the readiness code in the W12 engine. I have already mapped out both controllers for this engine when I wrote the label files for the W12.
      If you want me to test a script and see if it works, send me an email. Click on my user name (to the left) to reveal my email address.
      Michael
    24. Forum Sponsor Santos@Ross-Tech.com's Avatar
      Feb 16th, 2007
      Abington ,PA
      2008 GTI
      08-17-2009 11:51 AM #74
      Thanks Michael, I will send you the script as soon as its completed.
      www.Ross-Tech.com
    25. 09-01-2009 04:48 AM #75
      Do You need anything from the newest SEAT models?
