anyone?
#1
I got the code p0441(Evap Emission purge flow)I searched and came up with a little, someone said something about it just being because of the cold, now I'm up in vermont when the code popped up so could it simply be just the cold? or will i need to replace it. or is my cap just not clicked in enough? tia
#3
Here you might want to read this http://forums.vwvortex.com/zerothread?id=3694323
#4
yea that would be helpful if it was my temp sensor....
#5
tighten gas cap.If that isn't it, check all the cloth-covered hoses - they tend to crack easily.
Modified by AZ_NaTiV at 6:04 PM 2-20-2008
Just put it on my tab at Harry's
#6
XBOX GT:SO ICY GOON SQD mainly play MW2 and Halo
#7
Quote, originally posted by AZ_NaTiV » tighten gas cap. If that isn't it, check all the cloth-covered hoses - they tend to crack easily.
If all else fails, try buying a replacement gas cap as well.
#8
Quote, originally posted by maddenbowler » http://theunixguys.com/vwtunin....html I already know what the code is...so that helped me none...
I tightened the gas cap...would the light shut off on its own or do i need to clear it to see if that was the problem...and those hoses..located on the left side of the engine bay i assume??
#9
clear code, tighten gas cap. pull out n80 valve. its on the pass side near the washer tank. tap it on some white paper. if some black crap comes out then replace the valve. if the code comes back you need a new charcoal canister.
