VWVortex.com - Dies when warm, starts after it cools off????
    Results 1 to 22 of 22
    Thread: Dies when warm, starts after it cools off????
    1. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      02 S4 Stage 2+, 08 A4 S-line Titanium
      02-23-2008 08:10 PM #1
      This is my buddys car, it runs fine until it gets warm and then just dies on him. After he lets it sit and cool off for about 10min it starts right back up and drives until it gets to operating temps again.
      WTF?
      Modified by Mr. Merk at 7:57 AM 3-12-2008
      02 S4 2.7T Stage 2+ | VAST | Penske | Stasis | Hotchkis | Stoptech | Alcon | Neuspeed | XSP | IPP | JHM | Stern | ASP | VMR | Podi | 034
      13 S4 3.0T | Sports Diff | Nav | Alcantara | Peelers | ADS | STOCK
      Sold: 04 GTI 1.8T, 01 A4 1.8T, 08 A4 2.0T
      Nov 26th, 2007
      kamloops canada
      1997 2.0L GTI, 1994 Golf CL winter driver
      02-23-2008 11:36 PM #2
      may need to clean your air filter
      Nov 26th, 2007
      kamloops canada
      02-23-2008 11:37 PM #3
      forgot to mention coolante temp sensor may be faulty
    4. Member 96jettasexer's Avatar
      Jun 7th, 2004
      Killadelphia
      02 Jeep Wrangler
      02-24-2008 12:04 AM #4
      Quote, originally posted by Little Golf Mklll »
      x2
      CTS sends a signal to the PCM, letting it know how much fuel to add. it will add more fuel at cooler temps to try and warm the motor up faster. as the car gets warmer, less fuel is added to the motor.
      Franco
    5. 02-25-2008 12:19 PM #5
      I have a similar problem. I own a 2000 2.0L GLS Jetta and recently it started having problems starting after i drive it around for a while. However, it has no problem starting up cold.. but like i said after the engine warms and i turn it off it wont start up untill cool again? any help from past experiences
    6. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      02-25-2008 09:07 PM #6
      ok, he changed the engine coolant temp sensor and it made NO difference
      he also unplugged the MAF and it made no difference besides making it run rough
    7. 02-25-2008 09:24 PM #7
      Possibly a vacuum leak or TB issue then, but stop throwing parts at this car until you can get it scanned.
      Jul 31st, 2002
      '74 Bug (yard), '96 Jetta 255K (yard), '02 Cabrio 104K (sold), '06 Rabbit 127K BGP, '08 Jetta 55K
      02-25-2008 09:45 PM #8
      How does it run before it quits? My bad coil behaved that way, but I had a clear intermittent miss while it ran. Could be CPK that gets flaky when hot.
    9. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      02-26-2008 12:11 AM #9
      been scanned, we know it has a leak in the PCV system
      it runs perfectly fine during warm up, then as soon as it hits operating temp its kills itself
    10. Member digraph's Avatar
      Jul 23rd, 1999
      Bay State
      '12 Impreza, '10 Forester, '09 Matchbox Unimog
      02-26-2008 01:20 PM #10
      I have to suggest that maybe one of the fuel system relays or other electrics is going out. Sometimes when they die they get really temperature sensitive.
    11. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      02-26-2008 06:11 PM #11
      called both the local euro specialists today and they both said ignition module
      Jul 31st, 2002
      02-26-2008 10:46 PM #12
      That's the coil/module? One piece deal, in case you want to do it yourself...
    13. 02-27-2008 01:51 AM #13
      yea, could be a bad coil. Could also be a hot fuel pump relay or ECM main relay. When it cools off it works again. Bad ECM relay would also cause no spark.
    14. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      03-05-2008 10:39 PM #14
      ok, so it gets blue spark
      that rules out ECM relay and the coil etc etc
      i'm betting on the fuel pump relay at this point, others are pointing to the computer....
    15. Member
      Jul 31st, 2002
      03-05-2008 10:45 PM #15
      What's the spark like right after it quits? My coil behaved like that until it just wouldn't start again.
    16. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      03-05-2008 10:53 PM #16
      he said it is getting blue spark after it quits
    17. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      03-12-2008 08:56 AM #17
      OK, FIXED!!!
      here is the run down
      1. he ran it out of gas one day
      2. shortly after it started dying on him randomly while driving
      3. it started dying every time it got to operating temps
      4. he replaced the ECT sensor, didnt work
      5. it WAS getting spark
      6. he took the fuel pump relay out to try to have it matched, no luck
      7. he changed the fuel filter and put the old relay back in, wouldnt start AT ALL
      8. got a new relay, it took a bit of convincing but now it finally runs properly (lines were dry!)
      theory is that the car sat for 2 years previously, my friend then ran it out of gas and sucked all the crap off the bottom of the tank, that restricted the fuel filter and put a strain on the fuel pump which overheated the FUEL PUMP relay after running for several minutes and eventually caused it to fail completely
      so it took a NEW fuel filter and a NEW fuel pump relay
    18. 03-12-2008 04:51 PM #18
      Sounds very familiar.
      Was it just the fuel pump relay?? Or did he replace the pump too?
      I replaced my fuel filter but I suspect my pump/pump relay may be heat sensitive..
    19. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      03-12-2008 05:05 PM #19
      just the filter and the relay were replaced, and happy to report he made it to work today without it dying!
    20. 03-12-2008 05:16 PM #20
      Quote, originally posted by Mr. Merk »
      FTW! Good diagnosis. Thanks for the wrap-up. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      86 Scirocco, 2.0L CIS, "Jezebel" --- Rebuild Thread
      93 Volvo 240 Classic Wagon, "Victoria" --- The Other Car I Love
      I fix broken things, and break fixed things.
      Fb
    21. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      03-13-2008 12:34 AM #21
      Quote, originally posted by LastMartian »
      gah, it started acting up again this evening....but its restarting easier and not completely dying every time....
      thinking the pickup screen on the fuel pump may be getting a bunch of crud on it, might pull it tomorrow and see!
    22. Member Mr. Merk's Avatar
      Jun 29th, 2007
      NW Arkansas
      03-19-2008 11:44 PM #22
      OK now its really fixed...
      took it to a shop and turned out it wasnt making spark, it ended up being the first thing we thought of!
      the ignition module/coil
