Results 1 to 21 of 21
Thread: Patched tire?
  1. Member EUROBORA8V's Avatar
    May 15th, 2005
    Moscow, Russia/Los Angeles
    03 Bora Variant 1.8T, 07 Golf 2.5, 08 Polo 9n3 1.4TDI, 14 Tiguan S 6mt ON ORDER
    02-27-2008 02:19 PM #1
    I am very lucky on getting screws into my tires
    I have 10000 miles on my Pirelli PZERO NERO. I dont drive hard at all so my tires are stlll new. Pirelli tend to last if you drive it propely. I've got a screw into one of them and it can easily be patched. Just Tires is where i got them is willing to patch it for free.
    The question in mind is whether it is safe? I am planning to AutoX this summer and i've heard that i should replace it if i am planning to see the track.
    Whats is your input?
  2. Senior Member StormChaser's Avatar
    Jan 3rd, 2000
    Galesville, MD
    2006 Volvo V50, 1993 RX-7 R1, 1980 Hatteras 53MY, 2002 Grady White Release 283, 1958 Mohawk 14
    02-27-2008 02:22 PM #2
    Patch from the inside and I'd feel fine about it...but NO plugs...
    Dave
    Demokratically Elekted Minister of Ginger Affairs and Fist Dates; Orakle of the Weathers; Creeper Extraordinaire of the Independent People's Republik of Offtopikstan
    Quote Originally Posted by Biz View Post
    If Chilledman and Stormy won't hit it, you know it's gone rancid.
  3. Member Surf Green's Avatar
    Feb 16th, 1999
    Silver Spring, GerryMarylandering
    2002 Golf Wagon TDI. 1996 Surf Green GTI VR6. 2005 Chrysler T&C.
    02-27-2008 02:22 PM #3
    I know of a few plugged tires that see track use.
    Those booger strings are almost better than the tire itself.
    I'm just here for the sanctimonious circle jerk.
    2002 Golf Wagon TDI - 1996 GTI VR6 - Bendpack HD9-STX - flickr
  4. Member EUROBORA8V's Avatar
    May 15th, 2005
    02-27-2008 02:27 PM #4
    Great, thanks for response.
    I guess as long as i am not doing a highspeed run in Nardo Italy
  5. Member aethelwulf's Avatar
    Mar 2nd, 2004
    Rochester, NY
    05 STi
    02-27-2008 02:32 PM #5
    Quote, originally posted by EUROBORA8V »
    The biggest thing is to make sure they remove the tire when they fix it. It really should have an internal patch, but more importantly it should be checked for runflat damage that might not otherwise be apparent. You don't want to be riding around on a tire that's had its innerliner shredded.
    Current: '05 STi 20g'd at 18psi
    Past: '87 XR4Ti, '01 Jetta VR6, '73 240Z
  6. 02-27-2008 02:42 PM #6
    Have them repair the tire by dismounting it and have them use a "plug patch". It is the best repair method, and combines the best of both a patch and a plug. You should be fine for auto-x use. I may re-consider if you are going to be doing high speed track days that will see sustained high speed loading.
  7. Member SleeperPrelude's Avatar
    Sep 24th, 2005
    Dallas, TX
    01 Silverado 5.3, 87 BMW 325e
    02-27-2008 02:43 PM #7
    At my last dealership we routinely used a patch/plug that went in from the inside and had a plug attached that went through a bored out hole where the object was. I don't recall ever having a comeback on one. I wouldn't worry if it was one of those patches.
  8. Member TurboWraith's Avatar
    Sep 4th, 2004
    Morton, IL
    3 Hatch, VFR800 (Vtec, Yo!)
    02-27-2008 03:15 PM #8
    Quote, originally posted by SleeperPrelude »
    Thats what we used when I was working as a tire jocky at wally world while I was in school. Never had one come back after I did the work on it. Usually takes about 20 minutes or so cause you have to knock the tire off the wheel, do the repair, and rebalance before its ready to go. I wouldn't be scared of driving on one.
  9. 02-27-2008 03:43 PM #9
    i would get an employee at the dealership to check it out.
  10. 02-27-2008 04:20 PM #10
    plugs and patches have always proven to be fine in my experiences. I have heard of some with multiple plugs and or patches and lasted until the tread was worn.
    I see no reason why it would become unsafe under track use, street driving depending on how and where you live is pretty tough as it is.
  11. Senior Member AZGolf's Avatar
    Jun 6th, 2000
    Phoenix area
    02-27-2008 04:25 PM #11
    Quote, originally posted by Surf Green »
    Yeah, I never mentioned it to the tech inspector, but I autocrossed on a plugged street tire a few times myself. That was with the puncture between treadblocks however. If it were in a treadblock or on an R tire, I would definitely patch, not plug the tire. Still, I would not hesitate to autocross on a patched tire. Open Track? Maybe a little hesitation, but there's still a physical limit as to how quickly the air can leak out, even with total failure of the patch. It's not like the tire will just detonate if the patch fails, your grip will just get worse and worse from one turn to the next, which should be a red flag that something has gone wrong.
  12. 02-27-2008 04:58 PM #12
    I wouldn't bother autocrossing.
    Problem solved!
  13. 02-27-2008 07:33 PM #13
    As mentioned, it's a non-issue for autocross OR track use provided that the hole is patched properly with the plug/patch inserted from the inside out.
    I've road raced on a patched tyre which lasted a full life and died due to tread loss and old age.
  14. Member timsvr's Avatar
    Nov 14th, 2008
    RI
    97 GLX, 2009 Civic Si
    06-07-2009 11:21 AM #14
    bumping this back up... what about patching a stretched tire? stupid question?
    there are actually only 9 black jettas
    F2D
    GDIB
  15. Banned
    Jul 30th, 2004
    Fancy in the Not fancy, CT
    06-07-2009 11:29 AM #15
    I always plugged my tires and never had a problem...
  16. Member
    Dec 31st, 2005
    SoCal
    Corvette & SV650
    06-07-2009 01:31 PM #16
    I've gone over 170 mph, verified on gps, on patched tires.
    Quote, originally posted by timsvr »
    Stretched tires are always a dumb idea.
    Quote Originally Posted by apizzaparty View Post
    never thought once to use my lefty for the brake. sorry in my opinion it is dumb.
  17. Member VR6GTI72's Avatar
    Mar 13th, 2002
    Jacksonville, OR
    06-07-2009 01:39 PM #17
    Always patch, never plug.
    3 patch maximum
    Ive patched streched tires it was fine as long as its not near the sidewall.
    XBL: Skip Fourplay
    GO SHARKS!!!
  18. Member 08-Jetta's Avatar
    Feb 17th, 2008
    Canada
    an early 90's tissue box.
    06-07-2009 01:54 PM #18
    I just plugged - from the outside in - a tire in 2 places about 30 minutes ago. Am I going to hell?
  19. Member MK39920's Avatar
    Sep 12th, 2003
    Toronto Ontario
    2009 Jetta Wagon
    06-07-2009 01:56 PM #19
    I average one or two patches a year in my car never had a problem.
    Quote, originally posted by sperkins »
    Why? you mean the tire dealer right?
  20. Member tyrantanic's Avatar
    Jun 14th, 2004
    2001 Jetta Wolfie
    06-07-2009 02:33 PM #20
    I had a large screw taken out of a tire, they took the tire off, cleaned the inside, roughed it up a bit, put the patch on that had a plug that went completely through the hole, glued it with whatever they used, and cut off the excess on the other side.
    He mentioned if it were any more to the side he wouldn't have been able to patch it on the sidewall. Also mentioned it's probably stronger now w/ the patch.
    Even a stopped clock gives the right time twice a day.
  21. Member VR6GTI72's Avatar
    Mar 13th, 2002
    Jacksonville, OR
    06-07-2009 02:46 PM #21
    Quote, originally posted by 08-Jetta »
    yes.
    They work, just not as well as a patch. Seems to be a little more of a crap shoot on the long term reliability with plugs.
    XBL: Skip Fourplay
    GO SHARKS!!!
