any deals on a kit for B5's? im guessing theis are all for the GTI's and jetta's
#1
All Items Include Free Ground Shipping in the lower 48 states5 Speed 02J/ 02A Fits Golf Jetta Non Quattro TT
------Full Clutch Kits contain clutch disc, pressure plate, flyweel, flywheel and pressure plate bolts,Release bearing and alignment tool----1.8T Clutch Kits Starting @ $324.95 (228MM Sachs VR6 Clutch Kit 14 pound Cast Steel Flywheel W/ Starter ring gear Includes 6 flywheel and pressure plate bolts, Alignment tool as shown)
1.8T 1.9 TDI 2.0 Single Mass Clutch W/ Cast Steel 14 LB Flywheel $324.95
1.8T 1.9 TDI 2.0 Single Mass Clutch W/16 LB Cast Steel Flywheel $324.95
1.8T 1.9 TDI 2.0 Single Mass Clutch W/ Cast Steel 22 LB Flywheel $339.95
1.8T Clutch Kits $484.95 (228MM Sachs VR6 Clutch Kit, 11.75 pound Steel Billet Flywheel W/ Starter ring gear Includes 6 flywheel and pressure plate bolts, Alignment tool as shown)
1.8T Single Mass Clutch W/ Steel Billet Flywheel1.8T Stage 1+ Clutch Kit W/ Flywheel $425 ( Includes 228MM Sachs Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, ESS 14 lb Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 300 TQ at flywheel.
1.8T Single Mass Clutch W/ ESS Cast Steel Flywheel
1.8T Stage 2 Clutch Kit W/ Cast Steel Flywheel $539.95 ( Includes 228MM Clutchnet Yellow Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, ESS 14 lb Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 375 TQ at flywheel.
A HREF="http://fourseasontuning.com/?product=322" TARGET="_blank">1.8T Stage 2 Clutch W/ Cast Steel Flywheel1.8T Stage 2 Clutch Kit W/ Billet Flywheel $664.95 ( Includes 228MM Clutchnet Yellow Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, AST 10 lb Billet Flywheel w/ ring gear, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 375 TQ at flywheel.
1.8T Stage 2 Clutch W/ Steel Billet Flywheel1.8T Stage 3 Clutch Kit W/ Cast Steel Flywheel $554.95 ( Includes 228MM Clutchnet Red Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, ESS 14 lb Cast Steel Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 445 TQ at flywheel.
1.8T Stage 3 Clutch W/ Cast Steel Flywheel1.8T Stage 3 Clutch Kit W/ Billet Flywheel $679.95 ( Includes 228MM Clutchnet Red Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, AST 10 lb Billet Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 445 TQ at flywheel.
1.8T Stage 3 Clutch W/ Steel Billet Flywheel5 Speed-----Clutch Kits without flywheel contain clutch disc, pressure plates, pressure plate bolts, and alignment tool----
1.8T Stage 2 Clutch Kit $359.99 ( Includes 228MM Clutchnet Yellow Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub,Sachs T/O bearing and alignment tool. Rated at 375 TQ at flywheel.
1.8T Stage 2 Clutch Kit1.8T Stage 3 Clutch Kit $375.00 ( Includes 228MM Clutchnet Red Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, Sachs T/O bearing and alignment tool. Rated at 445 TQ at flywheel.
1.8T Stage 3 Clutch Kit1.8T Stage 2X Kevlar Clutch Kit $445.00 Shipped Ground ( Includes 228MM Clutchnet Red Pressure Plate,Kevlar Clutchnet Disc w/ Steel covered 6 spring Hub, Sachs T/O bearing and alignment tool. Rated at 400 TQ at flywheel.
1.8T Stage 2X Clutch Kit1.8T Stage 2X Fiber Carbon Clutch Kit $445.00 Shipped Ground ( Includes 228MM Clutchnet Red Pressure Plate,Fiber Carbon Clutchnet Disc w/ Steel covered 6 spring Hub, Sachs T/O bearing and alignment tool. Rated at 400 TQ at flywheel.
1.8T Stage 2X Clutch Kit02J/02A Single Mass Flywheels
Eurospec Sport Lightweight Flywheel Single Mass Cast Steel Flywheel. 14 pounds with starter ring gear
1.8T Eurospec Sport Single Mass Cast Flywheel $179.95 shipped
Autotech Lightweight Flywheel Single Mass Steel Billet Flywheel. 11.75 pounds with starter ring gear. Comes with Flywheel and pressure plate bolts.
1.8T Autotech Steel Billet Flywheel $310 shipped
-------------Flywheel Install Kits contain Crankshaft Seal with Tool, Main Shaft Seal, Throwout Bearing Guide Tube---------------1.8T Flywheel Install Kit W/ Flywheel and Clutch disc bolts
(FITS MK4 1.8T 5 SPEED ONLY
1.8T FLYWHEEL INSTALL KIT1.8T Flywheel Install Kit(FITS MK4 1.8T MK1 TT SEE DESCRIPTION) 5 SPEED ONLY
Visa Mastercard Discover and American Express can be accepted via Paypal without registration.
California residents will be charged 8.00 % sales tax.
http://www.FourSeasonTuning.com
The current site only has a fraction of the parts listed that we carry.Please contact us if the items you seek are not on the site.Competitive pricing, Fast shipping, If you see a lower price let us know, chances are we can work with you.
Questions at 714-997-5842
Email is better than IM
sales(AT)fourseasontuning.com*Thanks for looking.
JamesAKA wld101turkey
:: www.FourSeasonTuning.com
:: Wössner-APR-C2-United-Supertech-Clutchnet-DXD/SBC-Koni-KW- IE-Bosch-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
:: VW / Audi Performance and Oem Parts Source and Service Center ::714-997-5842 M-F 10:30-6:30 PST
#2
#3
-----02M Clutch Kits 6 Speed Fits 337-20th-GLI-Quattro TT -----
-----6 Speed 02M Kits W/Steel Single Mass Flywheels-----
$654.95 Stage 1 OEM LUK Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM LUK Pressure Plate, LUK Unsprung Disc,6 flywheel & 6 pressure plate bolts, LUK release bearing.
STAGE 1 KIT
$674.95 Stage 1 Sachs Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE Sachs Pressure Plate,Sachs Unsprung Disc,6 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 1 KIT
$749.95 Stage 1+ CLUTCH KIT with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM Sachs Pressure Plate,Clutchnet Sprung Hub Full face Organic Disc,6 flywheel & 6 pressure plate bolts, OEM release bearing.
STAGE 1+ KIT$934.95 Clutchnet Stage 2 CLUTCH KIT 16.5lb flywheel FST Single mass steel billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet Full face Disc,flywheel & pressure plate bolts, OE release bearing.
CLUTCHNET STAGE 2 KIT$1035.00 Clutchnet Stage 2X Fiber Carbon CLUTCH KIT W/16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet Fiber Carbon Steel covered Sprung hub Disc,flywheel & pressure plate bolts, OE release bearing.
CLUTCHNET STAGE 2X Fiber Carbon KIT$1035.00 Clutchnet Stage 2X Kevlar CLUTCH KIT W/16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet Kevlar Steel covered Sprung hub Disc,flywheel & pressure plate bolts, OE release bearing.
CLUTCHNET STAGE 2X Kevlar KIT$1035.00 Clutchnet Stage 3+ Copper CLUTCH KIT W/16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet Copper Steel covered Sprung hub Disc,flywheel & pressure plate bolts, OE release bearing.
CLUTCHNET STAGE 3+ Copper KIT$934.95 Clutchnet Stage 3 CLUTCH KIT 16.5lb flywheel FST Single mass steel billet 16.5 pound 240MM flywheel, 240MM CLUTCHNET 2,200lb modified Pressure Plate,Clutchnet 6 puck Disc,flywheel & pressure plate bolts, OE release bearing.
CLUTCHNET STAGE 3 KIT------Full Clutch Kits contain clutch disc, pressure plate, Alloy Flyweels, flywheel and pressure plate bolts,Release bearing and alignment tool----
CLUTCHNET STAGE 2 W/ FLYWHEEL KIT $945.00 (FITS VW MK4 Golf Jetta 02-04 1.8T W/ 6SP, Audi TT MK1) FST ALLOY L/W 9LB,CLUTCHNET PRESSURE PLATE 29081R18 ORGANIC FULL FACE DISC W/STEEL BACKING 43507G19,0A5 141 671 RELEASE BEARING.RATED @ 375 TORQUE AT THE FLYWHEEL
CLUTCHNET STAGE 2 W/ FST FLYWHEELCLUTCHNET STAGE 2+ W/ AST FLYWHEEL KIT $1025.00 (FITS VW MK4 Golf Jetta 02-04 1.8T W/ 6SP, Audi TT MK1) AST ALLOY L/W 9LB,CLUTCHNET PRESSURE PLATE 29081R18 KEVLAR FULL FACE DISC W/STEEL BACKING 43507G19,0A5 141 671 RELEASE BEARING.RATED @ 440 TORQUE AT THE FLYWHEEL
CLUTCHNET STAGE 2+ W/ FST FLYWHEELCLUTCHNET STAGE 3 W/ FST FLYWHEEL KIT $955.00 (FITS VW MK4 Golf Jetta 02-04 1.8T W/ 6SP, Audi TT MK1) FST 9LB L/W FLYWHEEL 29081FG17,CLUTCHNET PRESSURE PLATE 29081R18 6 PUCK SPRUNG HUB CLUTCH DISC 43707CR21,0A5141671 RELEASE BEARING. THIS KIT IS RATED @500 TORQUE AT THE FLYWHEEL.
CLUTCHNET STAGE 3 W/ FST FLYWHEEL6 Speed----Clutch Kits without flywheel contain clutch disc, pressure plate,release bearing, and alignment tool----
$589.99Clutchnet Stage 2 Kit 240MM FULL FACE Clutch disc and modified pressure plate ,Alignment tool & OE release bearing.
Clutchnet 02M Stage 2 kit$589.99 Clutchnet Stage 3 Kit 240MM 6 PUCK Clutch disc and modified presssure plate ,Alignment tool & OE release bearing.
Clutchnet 02M Stage 3 kit
02M FST STEEL BILLET L/W Flywheel 16.5 pounds
02M FST STEEL BILLET L/W Flywheel 20 poundsFST Alloy Flywheel Single Mass Alloy Flywheel. 9 pounds with starter ring gear. Comes with Flywheel and pressure plate bolts.
1.8T FST Alloy L/W FlywheelAutotech Lightweight Flywheel Single Mass Alloy Flywheel. 9 pounds with starter ring gear. Comes with Flywheel and pressure plate bolts.
1.8T Autotech Alloy L/W FlywheelRELEASE BEARING 02M 02Q FITS VW AND AUDI 6 SPEED TRANSVERSE MOUNT FWD AND QUATTRO
#5
SOUTH BEND CLUTCHES/ DXD ( FITS 1.8T 5 SPEED FWD & QUATTRO) AUDI A4 (B5/B6) PASSAT 98-2005 (Does not fit Golf Jetta or TT)
$395 SBC Stage 1 Kit (AKA DXD Stage 2 Daily) 228MM Organic Sprung hub Clutch disc, modified Sachs pressure plate & OE release bearing. Rated @ 280 Torque.
SBC DXD Stage 2 daily
$475 SBC Stage 3 OFE (AKA DXD Stage 2 ENDURANCE) Kit 228MM OFE stage 3 Clutch disc, modified Sachs pressure plate & OE release bearing. Rated @ 325 Torque.
SBC DXD Stage 2 ENDURANCE
$685 SBC DXD Stage 3 Daily 228MM Organic Sprung hub Clutch disc, Sachs Sport pressure plate & OE release bearing. Rated @ 395 Torque.
SBC Stage 3 Daily kit
$725 SBC/DXD Stage 3 Endurance Kit 228MM Kevlar Sprung hub Clutch disc, Sachs Sport pressure plate & OE release bearing.Rated @ 425 Torque.
$725 SBC/DXD Stage 3 OFE Endurance Kit(aka old Stage 4 OFE) 228MM OFE Sprung hub Clutch disc, Sachs Sport pressure plate & OE release bearing.Rated @ 440 Torque.
$749.95 SBC/DXD Stage 5 FE Endurance 228MM FE Sprung hub Clutch disc, Sachs Sport pressure plate & OE release bearing.Rated @ 576 Torque.
SBC/DXD Stage 5 FE Kit
Steel Billet Flywheels
FST Single Mass Steel Billet Flywheel. 17 pounds with starter ring gear
1.8T Single Mass Steel Billet Flywheel $375 shipped
SBC/DXD Single Mass Steel Billet Flywheel. 20 pounds with starter ring gear
1.8T Single Mass Steel Billet Flywheel $395 shipped
ALLOY FLYWHEEL
FST Single Mass W/ replaceable steel friction surface. 12 pounds with starter ring gear
1.8T Alloy Single Mass Flywheel $399.99 shipped
#7
ill be ordering my stg2 very soon(once i figure out how much power im putting down exactly).
Modified by dcEuro at 11:41 AM 3-20-2008
#8
replied
#9
will these work for 6 speed cars or just 5 speed?
Am I OG status yet? Close to 40 years old and still driving a slammed and Boosted 'Dub...cool or sad?
#10
The kits listed are for 5 speeds. 6 speed ones are on the site.
#11
Can I use a VW single mass flywheel/ VR6 clutch combo on an '01 A4 B5 1.8T Manual Quattro...?Thanx - Eric
#12
No, but there are some solid mass flywheels that use a modified pressure plate. Please contact us as these kits are not on the site yet.Here are a few options.
Clutchnet Kevlar clutch disc with sprung hub
Clutchnet Yellow Or Red Modified pressure plate
Clutchnet L/W 11 pound Alloy Flywheel ( with replaceable friction plate)
Sachs Release bearing$870 Shipped Ground
Or a Spec Stage 2 W/ their 16 pound steel billet flywheel $815 shipped.
#13
Bump for a GREAT company to deal with. Thanks for all the parts help last weekEddie - ForceFed Engineering
FFE Racing
FFE Parts
1015whp 20v on Gasoline - 9.61 lifting.
"ignorance can be temporary, stupidity is forever"
#14
got one for a 2003 6 speed? price?
#15
Stock or Performance kit?
#16
performance, the VR6 sachs pressure plate and 14ib flywheel
#17
What stage from the kits above?
#18
I need a kit that can handle 300WHP and will last... I've got a spec stage II in the car right now but ive felt it slip a few times, hoping its not on its way out but I've seen the VR6 sachs kits since and like them so was curious incase mine goes out in the near future...
#19
The dish and offset of the 5 speed and 6 speeds flywheels are different and do not interchange.The only mfg that uses a VR6 pressure plate for A 6 speed 02M application is Eurospec Sport. The kit uses a 228MM 11 pound custom cast steel flywheel and a modified (for extra clamping force) VR6 pressure plate . It uses a stock Sachs 228mm full face disc w/ 23 spline center as opposed to the 28 spline for the 5 speed cars. We have had Clutchnet make us other discs for this application that would be stronger than the OE disc supplied in the ESS kit. I will list the kit and a few disc options here and more 02M kits in the first post.
1.8T 02M 6 speed $720 ESS kit
1.8T 6 Speed kit.Clutchnet Full Face Disc $155
Clutchnet Full Face Disc for use W/ above ESS kitClutchnet 6 Puck Disc $167
Clutchnet 6 Puck Disc for use W/ above ESS kit
#22
Replied
#23
Recently was in a bind with needing a clutch for my 01 1.8T 5spd and FourSeasonTuning really helped out with overnite shipping! Great price on the 1.8T clutch kit VR6 upgrade too.Thanks James
#24
Your welcome.
#25
what would be a good street application? I'm thinking my clutch will be out in another 30k or so, is the lightweight fly wheel going to affect the longevity of the engine? Only mods done currently are intake and turbo-back. ( Then TIP, Chip, ungraded inter-cooler AND suspension and brakes are coming later)
#27
and last question is could use the stage 2 before some of the mods are done?
#28
Stage 1 or 1+ would also work for most chipped cars w/o larger turbo upgrade. The 12.5-14 pound flywheels have been used for quite some time with no issues.The stock flywheels range from 22-25 pounds depending on the diameter.
Yes stage 2 could work before and after mods.
#30
looks like ECS tuning kits? what makes your stage 1 kit better then the ECS anything at all?
B6 A4 1.8T Dolphin Grey --> 3' turboback AWE exhaust --AWE DV1 D.v-- ITG drop in panel filter--20% tints all around -- GIAC FX tune(coming soon)
#31
whats the major benefit of the 14lb flywheel. also. since its 7-8lbs lighter does that make it LESS durable? or more unstable?
#32
The Sale price mainly ( first to offer it for less than $325, when MSRP is $425) as the kits use the same Sachs pressure plate, Sachs Disc and Sachs release bearing. Our kits also include new OE flywheel and pressure plate bolts along with a plastic alignment tool ( it does not need to be metal as they don't wear out that easy).These kits are almost Identical to the OEM Corrado G60 setup ( the only difference is the weight of current flywheel, IIRC the G60 flywheel were 17.75 pounds). The 228MM single mass design has been proven very durable over the years. Used on all Corrados, Passat's B3-B4 , all MK3 MK4 12V VR6 ( the only difference when used on a VR6 are the amount of holes in the flywheel).
Many users have chosen to lighten their existing flywheel or purchased lighter ones. The 14 pound flywheel still offers stock like Driveability. Another plus side is that the single mass flywheel can be easily resurfaced and reused with a 12V VR6 clutch kit when replacement is needed ( 5 speed users only).
#33
I purchased
1.8T Clutch Kits $324.95 (228MM Sachs VR6 Clutch Kit 14 pound Cast Steel Flywheel W/ Starter ring gear Includes 6 flywheel and pressure plate bolts, Alignment tool as shown)1.8T Single Mass Clutch W/ Cast Steel Flywheel
Any my mechanic is saying there is size difference that is making him question if it will fit into my 1.8T 2002.....he's comparing it to the current stock clutch that he's replacing...
Should I be nervous or is there any sort of detail that I can relay to him?
Thanks,
#34
The clutch kit / flywheel is larger, no problem they fit. Make sure the clutch disc spring pack is facing toward the gearbox side as stated on the disc.
#35
thank god my mechanic is from germany LOL.. he just knows this stuff
