do u guys ship to canada?
#36
:: www.FourSeasonTuning.com
:: Wössner-APR-C2-United-Supertech-Clutchnet-DXD/SBC-Koni-KW- IE-Bosch-Hawk-Peloquin-TT-Sachs-Brembo-Samco-Much More...
:: VW / Audi Performance and Oem Parts Source and Service Center ::714-997-5842 M-F 10:30-6:30 PST
#37
Immobilizer off and plug & play harness for your swap, VCDS (vag com) scaning, cluster repair/odometer correction, key programing (including newest VW/AUDI), radio/NAVi decoding (including rns 510)....PM me
#38
Yes. Send a list and a freight quote can be figured for you.
#39
Quote, originally posted by FourSeasonTuning.com » Yes. Send a list and a freight quote can be figured for you. this is what i need:
1.8T Clutch Kits $299.95 (228MM Sachs VR6 Clutch Kit 14 pound Cast Steel Flywheel W/ Starter ring gear Includes 6 flywheel and pressure plate bolts, Alignment tool as shown)
#40
http://www.fourseasontuning.com/?product=101freight is $77 for usps priority air mail 6-10 day service (includes insurance for purchase price) http://www.fourseasontuning.com/?product=211 adjust qty to 77
#41
Quote, originally posted by FourSeasonTuning.com » 6 Speed 02M Kits W/Steel Single Mass Flywheels
$639.95 Stage 1 Sachs Clutch Kit with 16.5lb flywheel FST Single mass Steel Billet 16.5 pound 240MM flywheel, 240MM OE Sachs Pressure Plate,Sachs Unsprung Disc,6 flywheel & 6 pressure plate bolts, OE release bearing.
STAGE 1 KITI just wanted give a review and feedback to this clutch kit in case anyone else is interested in buying.
First off let me say James at FourSeasonTuning does a great job taking care of his customers, and certainly knows his stuff. I had many questions trying to figure out what decisions to make and he didn't lead me wrong!
After installing the clutch and diagnosing a bad master cylinder in my case, I was able to take the car for my initial spin.
Pedal feels exactly as it did stock, and as it should since the Sachs kit is an OEM replacement. Engagement with the lightweight flywheel however is very crisp and responsive. The car itself actually runs and idles MUCH better with the 16lb flywheel and believe it or not, the chatter is very, VERY minimal. Any chatter is only audible from the outside of the car, if you listen carefully. To give you an idea of how feint it is, I've heard Miatas with louder valve noise, and Injectors louder than what I suspect is the actual chatter.
All in all, the price is right, the performance is there and a great upgrade for everyone. Still very daily driveable and i'm very glad I dealt with James.
I would certainly recommend anyone to James! Thanks again
#42
Thank you for the review.
#43
James,Do you have a LWFW/Clutchkit for a 5spd comparable to what you sold me for my 02M? I see the 11lb FST billet flywheel with sachs kit, but anything weighted closer to the 16lb like mine? I have a buddy that needs a clutch
#44
1.8T Single Mass Clutch W/ Cast Steel Flywheel1.8T Clutch Kits $324.95 (228MM Sachs VR6 Clutch Kit, 11.75 pound Steel Billet Flywheel W/ Starter ring gear Includes 6 flywheel and pressure plate bolts, Alignment tool as shown)
1.8T Single Mass Clutch W/ Steel Billet Flywheel
#45
Fantastic, you'll be hearing from me or him soon!
#47
Im sent
#49
Quote, originally posted by FourSeasonTuning.com » 12V VR6 Stage 2 Clutch Kit W/ Billet Flywheel $589.95 ( Includes 228MM Clutchnet Yellow Pressure Plate, Clutchnet Disc w/ Steel covered 6 spring Hub, AST 10 lb Billet Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 375 TQ at flywheel. The weight of the flywheel will be 12.5 pounds when your existing ring gear is reattached.
How about a stage 3??
IWEDNESDAYS!!!! <--DUB CARTEL'S PAGE!!
www.dubcartel.net
STANCE is the new RICE
Everytime I use the bathroom, I always do a HELLAFLUSH
#50
VR6 Stage 3 Clutch Kit W/ Billet Flywheel $604.95 ( Includes 228MM Clutchnet Red 2X Pressure Plate, Clutchnet Disc 6 Puck Steel covered 6 spring Hub, AST 10 lb Billet Flywheel, includes flywheel & pressure plate bolts, Sachs T/O bearing and alignment tool. Rated at 445 TQ at flywheel.
Stage 3 Clutch W/ Steel Billet Flywheel
Modified by FourSeasonTuning.com at 6:00 PM 2-19-2009
#51
anything for 2.0 aeg ?
#52
^^ Me to please ^^2.0 aeg stage 1 would be good
thanks
#53
IM sent with questions.
#54
12v kits stg 2Can i upgrade straight to this from stock ?
BBS sport cup classic II
http://forums.vwvortex.com/showthrea...p-classic-II-s
#55
If you have stock flywheel let us know.
#56
do you guys do anything for the tdi engines? ive got ajm 115 tdi, im looking for a flywheel and clutch kit
#57
5 or 6 speed?
#58
Quote, originally posted by FourSeasonTuning.com » 5 or 6 speed? 6 speed, also postage to uk if poss
#59
just curious
do you guys carry any kits for the 2.0 8v engine?
#60
Yes, what year?.
#61
nothing there for a 2L?
#62
Stock or Modified?
#63
Well if I'm replacing the clutch I want something a little better .....
#64
#65
lol. james is tearing it up!
Clutch, Cams, Engine Tuning, Coilovers etc. Call (714)997-5842
#66
Eh, might order a clutch/ flywheel combo shortly for 2.not so slow...I''ll know in the next few days. Scheduled install is 2 weeks away so preventative maintenance it is!
#67
#68
thank you guys! i received my clutch kit/fw in the mail on thursday and finished installing everything and getting the car back together yesterday. took her for a test drive today and all is well.bought the stage 2 clutch kit with 16.5lb flywheel. it chatters a little bit at idle and a little bit more between 900-1100 rpms when revving some, but it's bearable. i'll report back in ~500mi after it's broken in. good stuff.
for fourseason
#69
It has been a while since this was posted up is the price on these still good?
#70
A few kits have gone up, the links have the most up to date pricing.
