Page 1 of 2 1 2 LastLast
Results 1 to 35 of 66
Thread: Hesitation or loss of power at partial throttle in 1st and 2nd?
  1. Member pseudosuit's Avatar
    Sep 25th, 2007
    Pittsburgh, PA
    2008 UG .:R32
    02-29-2008 10:03 AM #1
    Car is a 20th, 1.8t 6-speed.
    I noticed something the other day that is happening occasionally on acceleration. At partial throttle, usually pulling away from a light or stop sign, I get this weird hesitation. It only happens at partial throttle and usually only in first, sometimes in second. As the RPMs increase up to around 3k, it's as if I lose power for a second. You can feel the car stop accelerating for a second, then it begins to pull again.
    If it's under heavy acceleration it never happens. It doesn't feel like the clutch slipping, more like the motor hesitating, but there's no noises or missing or anything like that. The RPMs don't jump up or anything. It's like for a second it's making no power, then it comes back.
    Anyone experience anything like this. Anything I should check? Thanks for any help.
  2. 02-29-2008 10:05 AM #2
    Check your coil pack?
    J
  3. Banned
    Nov 24th, 2001
    02-29-2008 10:06 AM #3
    is your ASR warning lighting up/flashing when this happens??
  4. 02-29-2008 10:12 AM #4
    Quote, originally posted by LSinLV »
  5. Banned
    Nov 24th, 2001
    02-29-2008 10:18 AM #5
    Quote, originally posted by hipsiguy »
    if you see that dash warning light flashing, that means you are losing traction and the ASR system has throttled back the motor, and applied braking to stop/minimize the traction loss. some people new to the MKIV are not aware of this, and don't realize the car is doing what it was programmed to do.
    if this is the case, be more smooth on the throttle, or just turn the ASR off.
  6. Member pseudosuit's Avatar
    Sep 25th, 2007
    Pittsburgh, PA
    2008 UG .:R32
    02-29-2008 10:24 AM #6
    It's not ASR because I have it disabled through vagcom. It did it before that however, with ASR on or off. It's definitely not the traction control. And we're talking very partial throttle here, like if you were pulling away from stop and trying not not spill your coffee. No chance of wheel spin.
    Modified by pseudosuit at 10:26 AM 2-29-2008
  7. 02-29-2008 10:24 AM #7
    I have a similar situation, but I do notice a difference in exhause note, it gets quite a bit louder and seems to bog, but only like he is saying at around 3K and is only evident for about 200-300 RPM. No ASR lights, and happens almost everyday when it is cold.
  8. Member pseudosuit's Avatar
    Sep 25th, 2007
    Pittsburgh, PA
    2008 UG .:R32
    02-29-2008 10:28 AM #8
    Quote, originally posted by Warriv04 »
    Yup, almost exactly like that. It has been very cold here, but it seems to do it when the car is warmed up also.
    So you guys think it could be coil packs? There's no CEL and no codes when I scan the car.
  9. Banned
    Nov 24th, 2001
    02-29-2008 10:38 AM #9
    if the coilpacks or ignition was the issue you WOULD have a CEL.....have you scanned to see if there are any "35-10" intermittant codes in memory???
    if not, then I'd say you need to start using measuring blocks to verify that all sensors are within spec....FAQ's/DIY's and the VAGCOM Forum have good info on these tests.
  10. Member pseudosuit's Avatar
    Sep 25th, 2007
    Pittsburgh, PA
    2008 UG .:R32
    02-29-2008 10:57 AM #10
    Only stored code is a intermittent short to ground on a the driver's power window switch. I guess I'll just wait until I actually get a CEL. Maybe it'll clear up when the weather gets nicer. I hate winter.
  11. 02-29-2008 10:58 AM #11
    Im bankin on it having somethin to do with my old sparkplugs, 57K on them, but thats just a thought... I guess ill have to start accelerating harder.... we all hate doing that...
  12. 02-29-2008 01:36 PM #12
    i've been having the same issue at ~59,000mi. I replaced all sparkplugs, put new Hitatchi Style Coils, new fuel filter, Green Top Coolant Sensor, cleaned IAT sensor and MAF, and i am still getting it occasionally. Next thing on the list is Fuel Treatment to clean-up the injectors and valves and cleaning the MAP sensor. it's getting pretty annoying i'm almost wondering if it is weather related also.
  13. Member pseudosuit's Avatar
    Sep 25th, 2007
    Pittsburgh, PA
    2008 UG .:R32
    02-29-2008 10:24 PM #13
    bumpage for some more input
  14. Member TheWolfsburg's Avatar
    Sep 22nd, 2007
    Waco, TX
    MkIV,VI Jetta:::'87 QStationW:::'08 TT
    02-29-2008 10:47 PM #14
    Experienced the same thing, with CEL... random misfire on piston #1. As you drive the car a little more it stops and some times it just keeps doing in first gear. Nearly positive its a bad coil. Probably the solution to yours too.
    The Mexicans who assembled my Wolfsburg like German food... good enough for me!
    VW Mk2 Transmission Installation Specialty Tool = 25th Anniversary Foose Channel Locks
    Quote Originally Posted by Deezy View Post
    Don't be a vagina. Take it apart
  15. Member VW1.8Tsunami's Avatar
    Mar 7th, 2007
    Atlanta, GA
    2011 Ram 1500, 2003 Stratus SXT
    02-29-2008 10:53 PM #15
    bump because I have the EXACT same problem as the OP...I have a CEL but its for the rear o2 sensor (had it scanned). Mine has been doing it since summer.
    Previously Owned: 2010 Kia Forte, 2010 JK Wrangler, 2007 Passat, 2003 Jetta, 2002 Jetta, 1992 Sentra, 1998 Dakota, 1990 Ford Ranger
  16. Member gen2fanatic's Avatar
    Feb 10th, 2008
    backwoods MD
    mk1, mk4, and a bunch of hondas.
    02-29-2008 11:06 PM #16
    Also experiencing a similar problem. Seems to loose a very little bit of power when slowing down to slower traffic. I throw it in 2nd to start moving with traffic, and seems to loose very little power for a second, then picks back up...
    Quote Originally Posted by POUNDxSAND View Post
    i love cats.
    WoW!crew.
  17. Member pseudosuit's Avatar
    Sep 25th, 2007
    Pittsburgh, PA
    2008 UG .:R32
    02-29-2008 11:19 PM #17
    Yup, that's it for sure. Well it looks like I might do plugs and coil packs when spring comes around CEL or not. How much do these coil packs run?
  18. Member GTIMike1.8T's Avatar
    Jan 15th, 2006
    Germany
    UG '10 GTI
    02-29-2008 11:29 PM #18
    mine is doing the exact same. More so when its cold but even more when its warm. I have noticed a quick fix is plugs. Also may want to see if you have a vac leak. Im gonna try coils and a green top too to see what happens. Anyway if you find a fix before me let me know.
  19. Member pseudosuit's Avatar
    Sep 25th, 2007
    Pittsburgh, PA
    2008 UG .:R32
    02-29-2008 11:32 PM #19
    Will do. I think my vacs good or so the boost gauge says. I don't know how accurate that is though. I'll probably just start replacing stuff. Even if it doesn't fix it I'll still feel better. hehe
  20. Member TheWolfsburg's Avatar
    Sep 22nd, 2007
    Waco, TX
    03-01-2008 09:48 AM #20
    I think your looking at about $100 for the coils $20-30 for the plugs.
  21. 03-01-2008 10:34 AM #21
    i have the same thing happening ... but i notice that if you nurse the clutch a little more in those gears in slow acceleration ... it stops ... well i'll have to do coils and plugs too i guess .... ::shrugs::
  22. Member GTIMike1.8T's Avatar
    Jan 15th, 2006
    Germany
    UG '10 GTI
    03-01-2008 09:16 PM #22
    I fixed mine, decided to get off my ass and change the oil and what not and looked and saw a slight tear in my DV hose going back into the intake. Replaced the hose and yup that was the deal. Even fixed my rough idle.
  23. 03-01-2008 09:20 PM #23
    winter gas FTL.
    Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. It would be better to live under robber barons than under omnipotent moral busybodies. The robber baron's cruelty may sometimes sleep, his cupidity may at some point be satiated; but those who torment us for our own good will torment us without end for they do so with the approval of their own conscience.
  24. Member gen2fanatic's Avatar
    Feb 10th, 2008
    backwoods MD
    03-03-2008 11:26 PM #24
    Quote, originally posted by GTIMike1.8T »
    Damn, I was just under there today. lol Ill check another time.
    And when you talk about a rough idle, is yours doing it at every idle, or just when you start it up and it idles rough within the 3-5 minutes after startup?
    i love cats.
    WoW!crew.
  25. 03-03-2008 11:33 PM #25
    Same problem as the OP,
    was going to post about it, but yay for finding this first..
    It's weird, because it only happens on partial throttle, not WOT..
    and it doesnt happen every time, probably like 1/4 or 1/5 times from 0.
    Some days it doesnt even happen at all..
    Things to check:
    coil packs
    DV hose
    vac
  26. Member The J's Avatar
    Feb 26th, 2007
    Long Island
    03-07-2008 09:24 AM #26
    Mine has been doing the same thing for over a year.
    I've had it back at the dealer while the car was under warranty and reported this 3 times... they could never replicate the problem, which is the response I'd expect from them.
    Like posted above, it happens every 1 out of 4 or 5 times, the car just stumbles for a second. No codes or fault codes.
    It's not my air filter, coils, plugs, oil, coolant. All those are clean or new. I recently had a coilpack fail so I replaced all 4 and replaced the overboost valve that was throwing intermittent fault codes. I will check the DV hose tomorrow morning and see if there are any leaks.
    This is terribly frustrating. Could there be any connection between the ecu and drive by wire throttle?
    [Mine's an 03 AWP 1.8T 5 Speed]
    Modified by The J at 6:26 AM 3-7-2008
    Items for sale: OEM MK4 Golf/GTI lower center grill (new); OEM MK4 Golf/GTI Rear Valence with Exhaust Cutouts (used); 15" OEM Mk4 Hubcaps; 15" OEM Mk5 Hubcaps; Amber sidemarkers
  27. 03-07-2008 10:17 AM #27
    I had the same problem as the OP since I had my car until I got it chipped, now it never does it. It almost felt like a surging sort of issue, even though it would happen when the rev's were real low and no boost was made. It made me come to the conclusion that it could've been something with the stock ecu program...or just a crazy coincidence. Either way, since I've been chipped the problem has completely disappeared.
  28. 03-07-2008 12:55 PM #28
    I scanned the car again recently and got the codes P0135, P0171. These point in the direction of the pre-cat O2 sensor and the MAF. When i get back in a week i am going to replace the Pre-Cat O2 sensor and see if that fixes it. If not the MAF will be replaced along with a throttle body cleaning
  29. Member The J's Avatar
    Feb 26th, 2007
    Long Island
    03-07-2008 01:51 PM #29
    The more I think about it, the more it seems to me like some of the electrical gremlins that plague these cars. From my experience, outside temp and humidity, engine temp, condition of plugs, oil, coils, have had absolutely no effect on this.
    It really may be a bad spot in the ECU maps, where a certain throttle input + MAP reading makes it stutter for a second. Frustrating!
  30. Member GTIMike1.8T's Avatar
    Jan 15th, 2006
    Germany
    UG '10 GTI
    03-08-2008 11:09 AM #30
    Quote, originally posted by gen2fanatic »
    Mine would idle like garbage the whole time it was on. Im talking 3-400 rpm increase and decrease. Sometimes it would get so low in the rpms my battery light would come on. But now its all good after replacing the hose.
  31. Member The J's Avatar
    Feb 26th, 2007
    Long Island
    03-17-2008 09:16 AM #31
    Mike,
    How big of a tear did you have in the DV hose? I checked mine carefully yesterday and didn't see any tears, but I also didn't remove the hose completely. And what part of the hose had the tear?
    On a side note, I pulled my ECU last night, plugged it back in, turned key to ON for 3 mins as it says in the APR instructions for throttle adaptation. This morning the car did not hesitate once and I have a ton of lights and stop signs to try it out. Weird.
    I will update this thread if/when it returns.
    [By the way, is the key ON for 3 mins for throttle adaptation only for chipped ECUs or is this for all ECUs?]
  32. Member The J's Avatar
    Feb 26th, 2007
    Long Island
    03-18-2008 09:01 AM #32
    Had 2 slight hesitations this morning. But they were nothing compared to the noticeable surge I have been getting though. This was a mild but smooth hesitation.
  33. Member ruetzal's Avatar
    Dec 17th, 2007
    Wisco
    '13 WRX, 2009 A3 sold, '03 GTI sold
    03-18-2008 09:19 AM #33
    yep I have the same exact (I mean exact thing happen to me) My best guess since I did change the plugs and my coilpacks are fine (when coilpacks go you can feel the miss) the only thing I can think of that may need looking at is the drive by wire. I think mine needs to be cleaned and re-adjusted. That is my best guess and my cousin had this same thing happen to him on his gti and after he had it chipped it magically disappeared for good..Thats why I am just going to wait until I get mine chipped to bother with any fixes for the time being.
  34. 03-18-2008 09:30 AM #34
    Same issue on a AWP 1.8T.
    Really slight hesitation around 2,300-2,400 rpm, not all the time but sometimes.
    It always seems to happen when I'm going light on the throttle.
    I'd just put it down to the turbo starting to spool up and there not being enough power fed in to compensate. (But I'm the first to admit I know sweet FA about how it works in reality).
    My solution: give it more gas in first and second.
  35. 03-18-2008 09:32 AM #35
    i have the same issue but with a 2.0l.
    1st and 2nd gear at light throttle at around 3000 rpm it seems to make less power for a split secound then pick up again. it doesnt feel like a cylinder is missing it just not making the power its supposed to.
    I have a newer coil, wires and plug and oil change .
