Results 1 to 19 of 19
Thread: obd error- 17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
  1. 03-01-2008 02:00 PM #1
    Can somone give some advice on what to check next. My W8 has been running a little rough, especially at low RPM's. My engine light came on and I read the code given above. I changed out the camshaft position sensor for the intake on bank 1. This did not resolve the problem. It seems like a timing issue but nothing major has been done to the car. I did change plugs on the car recently but that was it.
  2. 03-01-2008 08:42 PM #2
    If I'm reading my Bentley correctly G40 on the 4.0L is cam position sensor Bank 2 (driver's side), not Bank1 (passenger side).
    G28 is indeed the engine speed sensor (RPMs) but the Bentley code section doesn't list the location of the sensor - it does for the 1.8T and 2.8.
    I will look at the detail of the engine later to see where it might be.
    Try posting on theW8forum.dk, and see if anyone is familier with it.
    I just had my bank 1 adjuster and sensors replaced under warranty (as well as the thermostat), but mine had thrown the P0011 code.
    My extended warranty more than paid for itself that day.
  3. 03-02-2008 03:47 PM #3
    I double checked my Bently and it does indeed say that for engine code BDP the G40 sensor is on bank 1. On all other engines except for the MP fuel injected motors it appears the G40 sensor is on the bank 2 side.
  4. 03-03-2008 02:07 PM #4
    I am looking in my Bentley (hard copy) on Y764.
    Oddly enough, it shows G40, G62, G300 and G301 as all being "Camshaft position sensor, bank 2".
    Since each bank has an intake and exhaust cam position sensor that can't be right.
    My guess is G300 & G301 are the Bank 2, and G40, G62 are Bank 1?
    The wiring diagram then shows
    G40 - Cam shaft position sensor
    G163(?) - Cam shaft position sensor 2
    G300 - Cam shft position sensor 3
    G301 - Cam shaft position sensor 4
  5. 03-03-2008 04:09 PM #5
    So with all of this, it appears I changed the correct sensor. Again, this had no positvive effect. Any suggestions on next step?
  6. 03-03-2008 07:07 PM #6
    Well, the next best guess would be the G28 Engine Speed Sensor - I have no idea exactly where that is, however.
    I'll see if they show its location in Bentley.
    Oct 13th, 2003
    Memphis TN / AR
    2002 S55, 2001 E320, 1972 280SE, 1990 Vanagon, 1987 Vanagon, 1990 Corrado 16v turbo, 1992 VR6 Corrad
    07-18-2008 07:16 PM #7
    i'm having the same problem on a 06 jetta 2.5 same code 17748 engine is also running rough , and at cruising speed it sound like the lifters are making noise, but once you give it gas or let off gas the noise goes away. I also have a code p0300 random misfire , i have replaced coil packs, spark plugs, and even checked for water in the fuel.
  8. 07-22-2008 11:30 AM #8
    This is an early W8. The vehicle is having cam adjuster issues and just does give you the cam adjuster fault. The software system is to early. Good luck
  9. 07-23-2008 07:07 PM #9
    RE the Jetta - My trusted mechanic says that this crap screen that restricts the cam exists in many VW and Audi models. The good news for you is that yours will be easier and less expensive to replace. Let us know if that does the trick.
    Modified by alaskadub at 3:09 PM 7-23-2008
  10. 07-24-2008 08:28 AM #10
    Be sure to call VWOA
  11. Member
    Oct 13th, 2003
    Memphis TN / AR
    07-24-2008 06:03 PM #11
    Quote, originally posted by alaskadub »
    so what do you think that needs to be replaced?
  12. 07-24-2008 10:38 PM #12
    talk to your tech. Reference the information on these threads regarding the oil screen that is in front of the cam. See if they think that is a likely problem. If he gives you a blank look call a couple other techs and see if they think it sounds like its the problem.
  13. 07-28-2008 09:08 AM #13
    Modified by flavin42 at 11:40 AM 7-28-2008
  14. Member vr6pilot's Avatar
    Jul 5th, 2000
    Keyton, AL USA
    2000 GTI, orig owner 2005 Boeing AH64D (rented)
    08-07-2008 02:24 PM #14
    Posting here because I have a nearly identical problem on a 2000 VR6 GTI. i.e. "G40 camshaft position sensor/g28 speed sensor incorrect allocation"
    the car runs all day but the start up is not as immediate as would be normally (hot or cold) and at low rpm accelerating, the engine just has a burble to it and a steady vibration you can feel (I do have a poly dogbone mount but it didnt' feel this way 2 weeks ago and I've had the poly mount for 9 months). I can still run the engine up in speed and the vibe seems to diminish above 4000 rpm or so and it is also not present while decelerating off the gas.
    I've replace my pre cat 02 sensor (had a code for that, now it's gone) resistance checked all of my 8,000 mile old plug wires, new plugs are in, pulled the cam sensor and checked it for metal fuzz accumulation (only the slightest film of gunk on it) cleaned that and reinstalled it. No change.
    I'm going to hunt down the G28 on my car and see what's up with that but I really am curious to hear how this turns out on the OP's car.
    cheers
    Keurig...because landfill.
  15. Member vr6pilot's Avatar
    Jul 5th, 2000
    Keyton, AL USA
    08-09-2008 02:02 AM #15
    bump for some love.
    getting ready to pull the timing cover and check my cams
  16. Member
    Oct 13th, 2003
    Memphis TN / AR
    08-09-2008 06:36 PM #16
    the upper timing chain was the problem, the chain was streched badly and the upper tensioner was at its limit. The intake cam had jumped by two teeth. All the chain guides were like new. The lower chain did not seam to be streched at all but we went ahead and replaced it. I think this might be one of many, this car only had 50k on it.
  17. Member vr6pilot's Avatar
    Jul 5th, 2000
    Keyton, AL USA
    08-21-2008 01:06 PM #17
    Mine, too, had jumped a tooth or more on the intake cam and possibly one on the exhaust cam. One of the chain guides was in three pieces.
    So now we know. Incorrect correlation between your G28 and G40 means your cam timing is bollocks.
  18. 09-02-2009 02:07 PM #18
    Thought I would chime in on this post. I have an 05 Jetta 2.5L. I took the car to the dealer who said replacing the timing chain may or may not fix the problem. They suggested I replace the engine. I should note that when I dropped it off at the dealer, the car just ran a little rough at idle. When I picked it up it ran rough consistenly and there was a rattle that wasn't there before, but the engine light was out. I think the 'new' issue may have been caused by them but can't prove it.
    I took the car elsewhere. The mechanic broke down the engine and said the timing is fine. He discovered the problem to be the vacuum pump, which seemed to be the source of the rattle as well. When he took out the old pump he found that there was a pin missing from the top. After putting it back together and starting it up, the car runs great but the engine light came back indicating the cam sensor, back to square one. So now the car is slow to accelerate and we are going to replace the sensor with hopes it resolves the problem.
  19. 09-03-2009 05:23 PM #19
    Quote, originally posted by BlueSteW8 »
    The engine speed sensor on the W8 should be in the transmission bellhousing. It reads the signal from an index wheel mounted on the flex-plate/flywheel. Should be located more on the driver's side I believe.
    ON the VR6, it would be mounted on the side of the block (towards the front of the vehicle) near the oil cooler closer to the transmission. The index wheel is within the engine block on the crankshaft.
