Last night, washed it. This morning, took a picture.
#14281
I played with one in Best Buy and couldn't keep it connected when moving it.
2006 GLI | Bagged&Beautiful&Teal
2000 Golf | K04&Low&meh.
1991 Golf | At least it's not a MK3.
Trade me wheels
#14283
#14288
Washed mine last night around 11pm, getting it ready for today. Today is my first Dyno day!! Meeting up with some locals and going for a get together and my first Dyno run. I will post up what she's pushin' I'm hoping that it's over 250, at least it should be but we'll see
Chapter 11 Dubs #85 - Charlotte, NC
2006 VW Jetta GLI 2.0L FSI Turbo :: Deep Black Pearlescent :: 6 speed manual :: APR Stage 2+ :: Southbend Stage 2 Clutch :: Raceland Ultimos Coilovers
#14290
Installed a Magnaflow 2.5" cat-back.
Sounds purrrrty.
2007 GLI - APR Stage II+
APR / Autotech / BSH / EBC / Forge / 42DD / Magnaflow / Neuspeed / Raceland
Pending Installs
Intercooler Sprayer / Ultimate Timing Belt Pulley
#14291
#14292
#14293
5w30 Syntec oil change w/ new Mann filter and swapped out the cam follower (again).
With the AutoTech pump rebuild kit, I'm looking at about 15-18k before I need to change it.
My MKV APR Stg II+ build thread: The build...the blog...the boosted...
My MKIV project thread: New to 1.8T and need some guidance
#14294
#14296
put a sticker on it cleaned the windows on the outside and textured my ed30 rep lip may put it on but i may wait and do it when its a weebit warmer later this week
#14297
Need MKV STUFF? Buy mine! http://forums.vwvortex.com/showthrea...-part-out!!!!*
Meet my Mechanic. CBTuning.net Say hello. Buy your parts from him.
#14299
#14300
Installed side skirts and lowered the front down some more
-Jon
2007 Shadow Blue Rabbit
#14301
1. Installed LED tails.
2. Rear fog wired and activated with vag-com.
3. Retrofit fog lights using ECS relay kit
4. Washed
PROBLEMS:
1) ECS fog trigger wire too fat -- had to trim down to fit pin into headlight switch connector.
2) Fogs turned on the first time when testing, removed headlight switch and reinstalled, now they don't turn on. Fuse OK. Might be my wonky euro switch (although the fogs worked once), or may be that the ECS fog trigger wire is not seated properly. Or???
#14302
Something similar happened to me. The pin on my trigger wire actually broke as I was trying to fit it into the empty hole in the connector to the euroswitch. I ended up buying an 8 prong connector (black plastic piece with 8 pins that could be removed), removed one of the connectors, and soldered it to the trigger wire as a replacement for the broken pin. Worked like a charm.
As for the fogs not working, check the pin to the trigger wire to make sure it's in all the way and didn't break.
#14303
Put my thunderbunny rear on and my votex front lip. Also washed and waxed and new wipers, LED sidemarker bulbs and hid look alike halogens. All I need is some assistance putting on my fk streetlines![]()
#14304
#14305
Cleaned the interior....dog hair and dirt temporarily gone.![]()
2007 GLI Fahrenheit
APR Stage 1
#763/1200
So glad I don't have to worry about "winter mode"!
VWGIRLS.YELLOWJETTA.COM
#14307
Re-installed my wiper delete and raised it up 3 threads to stop the sway bar from slamming on the control arm.![]()
#14308
#14309
Max camber = no more poke.
Washed and detailed the car.
Freshly washed.
Whore.
Got groceries.![]()
// DROP // DRAG // DESTROY // beer
// Open Road Tuning
Instagram: @bryangb
bags and wheels = build thread
#14312
Drew on it.
Sent from my ADR6400L using Tapatalk
#14313
// Open Road Tuning
Instagram: @bryangb
#14314
Custom made me some stainless cable rear hatch lift strings.
Willing to build you a set too if anyone is interested
god i love my car. it may not be fast, but it's crazy fun!
C2 stage 2 TURBO!!! ACHTUNG!!! 2.5liter 5cylinder contents under pressure!!!
