Results 1 to 15 of 15
Thread: DTC 16724 p0340 INTERMITTENT code
  1. 03-03-2008 07:15 PM #1
    Hello all, I keep getting DTC 16724, p0340 CPS sensor Intermittent. I've changed the g40 (CPS) sensor with an oe one, code went away for 2-3 days, now back. Was wondering what path of diagnosing I should pursue? I will also mention that the front o2 was replaced 4-5 months ago.
    The vehicle is 2001 Jetta V6 12v.
    Much help is appreciated.
  2. 03-04-2008 10:58 AM #2
    Anyone?
  3. 03-05-2008 07:40 PM #3
    Hello once again, does anyone know anything about dtc 16724 intermittent, and the flowpath troubleshooting method to pursue?
  4. Member E30 all day's Avatar
    Oct 18th, 2007
    516 area
    2009 e-class .. sold 03 JB and IYbt 20ths 01 wolf
    03-06-2008 03:06 PM #4
    my Cam positioning sensor is intermittent also i have a 1.8 motor .. but i just wanted to tell u i have the same problem but i never replaced the sensor because im afraid its gonna be a waste
    VW =
  5. 03-07-2008 05:01 PM #5
    have you tried checking your wiring?? between ecm and cam pos. sensor?
  6. Forum Sponsor Andy@Ross-Tech.com's Avatar
    Jun 5th, 2002
    2012 Passat TDI 6MT
    03-07-2008 05:10 PM #6
    The Bentley manual should contain testing procedures for the voltage of the wiring to the sensor as well as the resistance between various pins inside the sensor. Also, don't you have two sensors, G40 and G163? Which did you replace?
  7. Member E30 all day's Avatar
    Oct 18th, 2007
    516 area
    03-07-2008 07:47 PM #7
    Quote, originally posted by Kunkel »
    can u please explain further
  8. Banner Advertiser vwemporium's Avatar
    May 27th, 2002
    MONTGOMERY NY VWEMPORIUM@AOL.COM
    NA
    03-07-2008 08:15 PM #8
    Are you kidding?
    If you don't know how to check the wiring with an Ohm meter for continuity you should pickup a basic electronics book from radio shack and read a little.
    Its only three wires, power, ground, and pulse.
    Why don't you verify if you have FOD Foreign Object damage.
    Check the harness under the cal to the ecu for rodent damage etc.
    Tone out the wires and possibly run a piggy back.
    Verify measuring block values of the sensor with Vag-Com using the RB manual to test. Follow the test procedure of the RB for the cam sensor etc.
    Follow the rules post a complete auto-scan.
    Best,
    Jack
  9. 03-09-2008 04:17 PM #9
    I was recently getting p0340 due to my cam timing being 1 tooth off. (happened when rebuilding head)
    I've also seen a few postings where the same code was present due to the timing being off 1 tooth.
    I'd check your timing . . .
    T
  10. Member E30 all day's Avatar
    Oct 18th, 2007
    516 area
    03-10-2008 08:43 PM #10
    how do u check timeing a 1.8
  11. Banner Advertiser vwemporium's Avatar
    May 27th, 2002
    NA
    03-10-2008 09:22 PM #11
    RTFB
    094 for variocam.
  12. Member E30 all day's Avatar
    Oct 18th, 2007
    516 area
    03-10-2008 11:19 PM #12
    Quote, originally posted by vwemporium »
    RTFB
    094 for variocam.
  13. Banner Advertiser vwemporium's Avatar
    May 27th, 2002
    NA
    03-11-2008 12:26 PM #13
    Im sorry
    01-04-094
    RTFB = Read The Factory Book
    Or Dot to Dot or 0 to V
    12 to 12
    V to arrow.
    Modified by vwemporium at 5:28 PM 3-11-2008
  14. 03-15-2008 01:44 PM #14
    Get a Bentley manual or at worst snag a manual from your local parts store. Either will get you through it.
    good luck!
  15. Member E30 all day's Avatar
    Oct 18th, 2007
    516 area
    03-18-2008 08:41 PM #15
    i finally bought and installed the cam sensor .. thing took me 10 minutes and the book says 2 hours .. is there 2 cam sensors or just one
