Results 1 to 23 of 23
Thread: DIY: Single stalk cruise control retrofit
    Oct 5th, 2004
    Sterling, VA
    2K6 1K2 BRM & 2K8 7L6 BWF & 85 19 MF
    03-03-2008 10:08 PM #1
    All credits go to SVTWEB. He made it possible. I just describe what I did in my car.
    Standard disclaimer: This document is for informational purposes only. Neither the author nor this site will be held liable for actions taken resulting from the information set forth herein.
    Lil' background before we start:
    Up to MY06.5 I believe all US mk5s were equipped with the Passat B6 cruise control concept with the "third" stalk below the light/blinkers switch. Some may find it useful, others (like me) found it annoying, especially that I was simultaneously driving mk4 (gone by now). Surprisingly, VW decided to make a change in MY07+ GTI and started installing Euro style cruise control integrated in the light/blinkers switch. Bye bye third stalk.
    Tools and first steps are covered in the immortal MFSW retrofit by the.ronin: http://forums.vwvortex.com/zerothread?id=2938601
    You might also need a knife from your wife's/mom's silverware ;-).
    Parts required:
    1. Integrated light/blinkers/cc stalk - 1K0 953 513 A
    2. Lower cover of the steering column - 1K0 858 559 C
    3. SWCM: yes, you need a designated control module that works with the single stalk. So far I know the following Multi-Function SWCMs work with single stalk:
    1K0 953 549 AG
    1K0 953 549 AK
    And the one that does not work (works with the dual stalk):
    1K0 953 549 AJ
    1K0 953 549 AC
    1K0 953 549 J
    4. Clock spring: here is a list of clock springs I tested and the controllers I confirmed them working with:
    1K0 959 653 C (works with: AG, AK)
    1K0 959 653 D (works with: AJ, AG)
    5. Harness: this part is slightly confusing to me, as the clock springs listed above have a different connector, so they use different harnesses. AFAIK there are two Multi-Function harnesses:
    1K0 971 584 C (works with C spring, single igniter airbag)
    1K0 971 584 L (works with D spring, dual igniter airbag)
    NOTE: There is a great info about the compatibility of controllers here: http://wiki.ross-tech.com/inde..._(1K)
    After all this info some conclusion:
    Primo: The safest choice is the AG controller as it works with both types of clock springs.
    Secondo: If you get the harness that does not work with your airbag, don't worry. You can combine two harnesses by extracting airbag wires from the old harness (even if it is non-MF) and attaching them to the new one.
    How to: once you remove the SWCM (refer to the.ronin's DIY), you need to pull out the clock spring. Make sure the wheels are straight and the new clock spring is centered:
    Here is how it looks:
    Now time to remove the clock spring sensor:
    Finally, the access to the stalks:
    Now the most complicated part of this DIY: sliding out the stalk. It is locked with 2 latches marked with red arrows. One between the stalk and the column and the other behind the lever:
    The best way to remove it is to put the silverware knife between the stalk and column, use the small flat screwdriver to unlock the second latch (red arrows), and slide out the stalk on the two rails (green arrows).
    Now slide the new stalk and install the clock spring sensor:
    Last thing is to put the new clock spring. New ones come locked with the red tab, so make sure you remove it before the installation.
    The rest is described in the.ronin's DIY.
    Enjoy your new stalk:
    PS. First question after reading this is whether it is worth the money and effort. As a single mod for sure it is not. But if you consider installing the MFSW, you might as well kill two birds with one stone.
    Modified by maloosheck at 12:01 PM 3-15-2008
    Modified by maloosheck at 6:15 AM 6-16-2008
    Modified by maloosheck at 10:08 AM 6-18-2008
  2. 03-03-2008 10:25 PM #2
    very nice diy!
  3. Member Tucci's Avatar
    Feb 2nd, 2005
    Oakwood GA
    3.2 TT
    03-03-2008 10:48 PM #3
    Awesome Awesome DIY, but Ill live with my second stalk. ha
  4. Member
    Oct 5th, 2004
    Sterling, VA
    03-13-2008 01:54 PM #4
    Well, I know a lot of people has crossed this mod out of their lists once they found out the required effort, especially financial.
    But I think there is a hope. Apparently, there are vehicles with D clock spring and the original harness and with the single cruise control stalk. Which basically means that the only thing you might need for the stalk is the different controller.
    I am going to take a closer look at the whole thing over the weekend.
  5. Member DubRadio's Avatar
    Oct 14th, 2003
    Abingdon, MD
    07 Rabbit 2dr UG
    03-13-2008 02:08 PM #5
    shouldve bought an 07 with single stalk lol jk
    Like digging virtual holes in the ground? Come play in the Official Vortex Minecraft Server.
    XBL : northVdubbed
    Steam : Dubradio
  6. 03-13-2008 02:22 PM #6
    Awesome DIY!! FAQ material!
    Mar 28th, 2002
    Queens NY / Nutley NJ
    2009 WRX
    03-13-2008 02:33 PM #7
    damn, you've got balls to do something like that. If I tried to do that, my car would be all $%^&*@ up!
  8. Member silverA4quattro's Avatar
    Jun 21st, 2004
    Conshohocken, PA
    '10 Jetta TDI, 02 Golf 2.slow
    03-13-2008 04:31 PM #8
    Quote, originally posted by DubRadio »
    My 07 has a dual stalk
    I hate that damned thing. I think my car just missed the cut for the single. Our MKIV has the single and it's much easier to use IMO. I'm used to that single design too, all my previous Audis had that style.
    New Audis actually use the 2 stalk solution still, must be Audi owners preferred it.
  9. Administrator svander's Avatar
    Oct 31st, 2003
    Seattle Metro
    '11 S4
    03-13-2008 04:40 PM #9
    I my third stalk personally
    Added to the FAQ.
  10. Member crabpot's Avatar
    Dec 9th, 2006
    Mill Creek, WA
    2007 S4
    03-13-2008 05:35 PM #10
    I've used both and I prefer the separate stalk myself ... impressive DIY nonetheless.
    BPCDubs» We use a bidet, that's how euro we are.
  11. 03-13-2008 05:38 PM #11
    Nice work once again Michal
    Oct 5th, 2004
    Sterling, VA
    03-15-2008 03:02 PM #12
    Updated info about controllers, clock springs and harnesses...
  13. Member JUANE DSG TDI's Avatar
    Jul 13th, 2007
    MEXICO
    JETTA 2011 TDI DSG
    05-20-2008 04:39 PM #13
    does any one have an idea what`s the right part number for the control module and a harness for the mfsw with paddles for a dsg 2007 with a single air bag igniter? to make it work the transmission, menu volume etc?
    its a TDI
  14. Member labelskate's Avatar
    May 20th, 2007
    2005 s2000, 2008 gti
    05-20-2008 04:46 PM #14
    single stock ftw!
    I never used cruise control on my 07 because the dual stock was so inconvenient, imo.
  15. Member
    Oct 5th, 2004
    Sterling, VA
    05-20-2008 04:47 PM #15
    Quote, originally posted by JUANE DSG TDI »
    its a TDI
    Do you have cruise control like this:
  16. 06-17-2008 01:42 PM #16
    What was the approximate cost of this "mod" anyway?
  17. Member
    Oct 5th, 2004
    Sterling, VA
    06-17-2008 03:45 PM #17
    Quote, originally posted by VWsuperhero »
    Dealership prices ~$400.
    Classifieds ~$200.
    That's why I said it does not make sense on its own. With MFSW retrofit an incremental cost for this mod is ~$100 (at classified prices).
    Modified by maloosheck at 12:47 PM 6-17-2008
  18. 06-17-2008 05:22 PM #18
    seriously?
  19. Member
    Oct 5th, 2004
    Sterling, VA
    06-17-2008 05:25 PM #19
    Quote, originally posted by I Smoke Rocks »
    seriously?
    seriously what?
  20. 07-15-2008 04:16 PM #20
    Mine is an '07 with the double stalk. I actually prefer it to the single stock so I guess it is a matter of preference...but I really could be wrong and my car is an '06.5.
  21. 07-07-2010 09:03 AM #21
    Hello there.
    Does anybody know how to install cruis control in Passat B6, 1.4 TSI? I am interested special manuals, code for order spare parts? Is it possible to install Single stalk cruise control (I mean can I replace the standard stalk with the switch of moving direction by the universal stalk with the cruise control)? Official dealer said me that it is not possible (installing universal stalk)...only to install additional cruise control stalk...
  22. Member makeesmo's Avatar
    Sep 11th, 2004
    Bonham, TX
    2008 Jetta SE, 2001 Jetta VR6
    04-13-2011 11:07 AM #22
    Probably going to be replacing my stalk soon (repair, already have single) and I'm cool with taking crap apart. I am concerned about removing the airbag. Is there anything special I should know? Disconnect battery? Anything might need to be reset?
  23. Junior Member
    Apr 7th, 2011
    Austin, Tx
    1992 Jetta, 1994 Jetta, 1997 Golf, 2008 Jetta, 2011 Crossfox
    09-07-2011 06:19 PM #23
    Hi guys... malooshek... DO I forcibly need a new clockspring? my 2008 Jetta comes with a mid-line display (it is a 2.5L Bora commercialized in Mexico) and as per the VIN on the car, it is supposed to have a compatible CC module.
    Is there something else special I need to do this retrofit??? clockspring? cable? harness?
    Please let me know... I will post pics once I gt this done...
    J
