Results 1 to 21 of 21
Thread: fuse box diagram
  1. 03-04-2008 11:46 PM #1
    can anyone give me a picture of it or a link to it?? searched and didnt find anything for my GTI any help will be greatly appreciated thanks
  2. 03-05-2008 01:12 AM #2
    whats your email addy? might have something that will help
  3. Member shibubba's Avatar
    Apr 14th, 2005
    04 tdi wagon
    03-05-2008 02:03 AM #3
    I need one too..... which means I want this special thing-a-ma-gigger too Pm'ed
  4. 03-05-2008 02:47 AM #4
    i need one to.
    golfgtispecial@telia.com
    thanks.
  5. 03-05-2008 06:23 AM #5
    cool, i need email addy's though
  6. 03-05-2008 08:49 AM #6
    Quote, originally posted by D. Olson »
    Just remember everyone that the fuse box wiring for VWs can/does vary based on where the VW was built/sold. A USA Built GTI will be different from one built and sold in South Africa for example.
    Be careful that you use the correct model and country specific diagram.
    Best thing to do is to buy a VW Service Manual for your specific VW.
    Robert Bentley Publishers sells them. They can be purchased at VW Dealers, on-line and on various auction web sites.
    Charlie
    '80 VW Rabbit "C" - 81 VW Pickup - '85 VW Golf - 1987 GTI 16V - 2002 New Beetle - 2012 Toyota Tundra 4x4, 5.7L V8
    Visit the Unofficial GTI 16V Home Page at www.gti16v.org
  7. 03-05-2008 08:55 AM #7
    1 Headlight, Low Beam, Left 10
    2 Headlight, Low Beam, Right 10
    3 License Plate Lights 10
    4 Rear Window Wiper And Washer System 15
    5 Windshield Wiper/Washer 15
    6 Fresh Air Blower, A/C 20
    7 Tail Lights, Right 10
    8 Tail Lights, Left 10
    9 Rear Window Defogger 20
    10 Fog Lights 15
    11 Headlight, High Beam, Left 10
    12 Headlight, High Beam, Right 10
    13 Horn 10
    14 Back-Up Lights 10
    15 Engine Electronics 10
    16 Power Sunroof, Front Map/Reading Light 15
    16 Emergency Flashers 10
    18 Fuel Pump (FP), Heated Oxygen Sensor (HO2S) Control Module 20
    19 Coolant Fan, A/C Relay 30
    20 Brake Lights 10
    21 Interior Lights, Clock, Luggage Compartment light 15
    22 Cigarette Lighter, Radio, Luggage Compartment Release 10
    Fuse colors
    30A Green
    25A White
    20A Yellow
    15A Blue
    10A Red
    Fuse/Relay Panel - Rear Connections (Volkswagen Part Number 357 937 039)
    Connections and plugs on rear of fuse/relay panel:
    A1 Yellow 8 pin Headlight wiring harness
    A2 Yellow 8 pin Headlight wiring harness
    B Green 6 pin Headlight washer wiring harness
    C Yellow 8 pin Headlight or wiper motor wiring harness
    D Green 12 pin Miscellaneous equipment, varies (A/C, A/T, heated seats, seat belt warning, etc.)
    E Green 5 pin Instrument or brake light wiring harness
    F White 10 pin Engine compartment/engine management, wiring harness, right side (position 10 open)
    G1 White 12 pin Engine compartment/engine management, right side
    G2 White 12 pin Engine compartment/engine management, right side (position 12 open)
    H1 Red 10 pin Steering column switch wiring harness
    H2 Red 8 pin Steering column switch wiring harness (position 8 open)
    J Red 10 pin Steering column switch wiring harness
    K Black 12 pin Rear wiring harness
    L Black 8 pin Rear/Parking brake wiring harness (position 8 open)
    M Black 6 pin Rear/fuel tank wiring harness
    N Green 6 pin Air conditioning wiring harness
    P Blue 10 pin Rear window defroster/fog light wiring harness
    Q Blue 6 pin Fresh air blower fan wiring harness (position 10 open)
    R Blue 10 pin Light switch wiring harness
    S White 5 pin Engine compartment/wiper motor wiring harness, right side
    T Green 2 pin Individual circuits
    U1 Blue 14 pin Instrument cluster wiring harness
    U2 Blue 14 pin Instrument cluster wiring harness
    V Green 4 pin Steering column switch Multi-function indicator wiring harness
    W Green 6 pin Miscellaneous optional equipment, varies with vehicle type
    X Green 8 pin Warning lamp wiring harness
    Y n/a 1 pin 4 single point connectors for terminal 30 circuit (some may be bridged with red connector)
    Z1 n/a 1 pin Single point connector
    Z2 n/a 1 pin Single point connector for terminal 31 circuit
    30 n/a 1 pin Single point connector for terminal 30 circuit (may be bridged to 30B with red connector)
    30B n/a 1 pin Single point connector for terminal 30 circuit (may be bridged to 30 with red connector)
    Note: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market. Always consult appropriate wiring diagram for specific terminal assignments.
  8. 03-05-2008 08:56 AM #8
    hope this clarifies everything guys, had to type this all our to share
  9. Member thatcrazylaxdude's Avatar
    Sep 16th, 2006
    Springfield, MO
    '84 GTI, '10 TDI JSW
    03-05-2008 10:30 AM #9
    bru-CTi - That's a CE2 fusebox, he has CE1.
    Ain't nobody dope as me, I'm dressed, so fresh, so clean, so fresh and so clean clean.
    WTB: Clean MK1 hatch in the midwest
  10. 03-06-2008 12:00 AM #10
    yea mine does not look like either of those......
  11. 03-06-2008 12:20 AM #11
    bwahahahahahaha
  12. 03-06-2008 12:21 AM #12
    hahaha, I'm still laughing, but wanted to give props, as that was a very nice thing to do, and I'm sure that somebody will find it useful...bwahahahahahahaha
  13. 03-06-2008 01:02 AM #13
    lol all you like punk hehehehehe, yeah, hope it comes in handy oneday, maybe you peeps get some new MK1's from SA i the future
  14. Member thatcrazylaxdude's Avatar
    Sep 16th, 2006
    Springfield, MO
    03-06-2008 01:22 AM #14
    Idk, it's useful to me, but I already have that diagram because I put CE2 in my car.
  15. 03-07-2008 12:08 AM #15
    haha yea still would like one if anyone else would want to give me a hand...
  16. Member thatcrazylaxdude's Avatar
    Sep 16th, 2006
    Springfield, MO
    03-07-2008 12:14 AM #16
    Do you have a bentley yet? Should be in there, sorry I'm no help with pics.
  17. 03-07-2008 01:51 AM #17
    is this what you guys are looking for?? ifso ill try and help out with what everything is
  18. 03-07-2008 11:41 PM #18
    it sure is only wish it was three times bigger but no big deal ill hopefully figure it out tonight!
  19. 03-08-2008 03:36 PM #19
    alright deal, ive got probably very simaler issues as u
  20. 09-11-2010 12:44 PM #20
    hey boys, have u some pic or scheme or something of fusebox and wiring for golf from 1977, 1.5d? there is only 15 fuses.
    my mail maniacse(at)gmail(dot)com
    thank u!
  21. 07-24-2011 07:24 PM #21
    This is great Just what I needed
