Page 36 of 38 FirstFirst ... 26 32 33 34 35 36 37 38 LastLast
Results 1,226 to 1,260 of 1322
Thread: vwVortex Folding@Home Team!
  1. 11-12-2010 11:38 AM #1226
    just installed on my work PC that is on 24/7, I'll hook it up to my playstation and my 3 home PCs later I should start putting up some very decent numbers.
    Psssh. I suck dick for the glory. I buy my cocaine.
    PSST: THAT WAS SARCASM SPEAK FOR "You're a dumbass"
    Quote Originally Posted by Justin View Post
    Thanks for reminding me why I only come in here to lock posts now a days.
  2. Member XClayX's Avatar
    Apr 30th, 2005
    Minnesota
    2001 W.E Jetta
    11-14-2010 03:45 PM #1227
    Looks like someone turned this into a puzzle game.
    http://fold.it/portal/
  3. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    Cheap oversteer and some old stuff
    11-14-2010 05:01 PM #1228
    Someone on my floor showed me that. I've yet to try it but it looked like a solid game.
  4. Member XClayX's Avatar
    Apr 30th, 2005
    Minnesota
    2001 W.E Jetta
    11-14-2010 05:47 PM #1229
    Sofar it seems like it uses the CPU quite a bit. I've been hitting 80% on my MBP when running the different tools to adjust the proteins.
    The puzzles go from move one item to you gotta be kidding me.
  5. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    MKIV R32, MKV R32
    12-09-2010 11:25 AM #1230
    Still going strong?
  6. Member
    Feb 11th, 2009
    Lewiston, Maine
    2001 Wolfsburg Jetta
    12-12-2010 12:02 PM #1231
    I've turned my PS3 back to this for a while.
  7. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    12-13-2010 05:29 PM #1232
    My gtx 295 is going to be down until the third. I'll have my PS3 folding as much as possible in the meantime. My apologies
    edit I may have my i7 860 available next month. If so, I'll be using the SMP client and should get about 25-35ppd from it, depending on how much I'm using it.
    Apr 10th, 2002
    The Motor City
    A well rounded stable: Callaway Turbo Scirocco #10, Jaguar XJR, 67 Mustang Fastback, Chevy G35
    12-13-2010 07:27 PM #1233
    Quote Originally Posted by wheeltowheel View Post
    Your alive!!!!
  9. Member TLC Detail's Avatar
    Jul 14th, 2000
    BC, Canada
    12-23-2010 04:58 PM #1234
    Well I couldn't get the Linux clients to work at home...
    But I did set it up on my two computers here at work, since they're sitting idle 24hrs a day anyway... Both are dual-core ~2ghz machines, so not powerhouses but good nonetheless.
    Any idea why the client only uses 50% of CPU resources? System idle process uses the other 50%......
  10. Member
    Feb 11th, 2009
    Lewiston, Maine
    12-23-2010 06:57 PM #1235
    Not sure, but in Windows, have to use the switch -smp to make it use all the available cores. As far as I can tell, it runs the first work unit as single core, WU's after that initial one is done, uses multiple cores. on my machines, it's fah6.exe -smp to start it.
  11. Member TLC Detail's Avatar
    Jul 14th, 2000
    BC, Canada
    12-23-2010 07:51 PM #1236
    Not sure I understand how to 'use the switch -smp' in windows... I know how to double click things??? LOL Help!
  12. Member TLC Detail's Avatar
    Jul 14th, 2000
    BC, Canada
    01-07-2011 02:10 PM #1237
    Well 2 computers running it (soon to be 4) got me to 79th place so far on the team
    Averaging 3 WU/day I think?
    GO TEAM!
  13. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    01-07-2011 05:57 PM #1238
    What cpu are you trying to run the smp client on? You have to have a dual core machine for it to be beneficial
  14. Member TLC Detail's Avatar
    Jul 14th, 2000
    BC, Canada
    01-07-2011 10:53 PM #1239
    I'll double check when I go back to work tomorrow..
    Core 2 Duo does not need SMP client, correct? Wife's laptop shows 2 cores in the task manager, but is it really a *dual* core?
    I do believe both work computers are true dual-core PC's. One AMD and 1 Intel. E6600 or similar?
  15. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    01-26-2011 11:33 PM #1240
    Spiffy, it's a close game!
  16. 01-27-2011 04:46 PM #1241
    Looks to be so. I'm sure you'll pull ahead.
  17. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    02-08-2011 02:48 PM #1242
    I have recruited another folder! Splatmaster527. Oh yeah, and my i7 is going to be on-board soon
  18. Member TLC Detail's Avatar
    Jul 14th, 2000
    BC, Canada
    02-08-2011 07:13 PM #1243
    Good stuff
    I have 4 machines running it currently, I've moved up to 55th place in the team with 149WU complete...
    One question, how can people have so many points with so few WU's done? Are they harder/bigger WU's?
  19. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    02-08-2011 09:35 PM #1244
    Glad to hear you're joining in on the fun.
    Yes, if you see more points with fewer work units, they are probably harder or take more time.
    I run "bigadv" units on my core i7 which can take up to 4 days to complete with my machine running 24/7. Each of those work units is worth ~70,000 points.
    Depending on your CPU, you may be able to run the SMP client, which makes use of systems with multiple cores. I think I could even run it on my dual core atom netbook.
  20. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    02-14-2011 01:18 PM #1245
    Ok, the i7 is officially on folding duty for the team
    "Without order, nothing can exist. Without chaos, nothing can evolve"
  21. Member EpicVW's Avatar
    Feb 10th, 2000
    Bay Area, CA
    02-14-2011 03:15 PM #1246
    Just fired up my i7 2600k Hackintosh on this. Hope it helps! And that I have it configured properly...
  22. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    02-15-2011 12:03 AM #1247
    Did you set up the SMP client? Folding -bigadv units with the SMP client, you should be able to get ~43,000 PPD
  23. Member EpicVW's Avatar
    Feb 10th, 2000
    Bay Area, CA
    02-15-2011 08:13 PM #1248
    Not sure. New to this. I just downloaded the client from Stanford, and it shows up in my sys prefs. Punched in my username (same) and team number, and away we go? Doesn't seem like there are alot of options in this client. Is their something else I should be using?
    Edit: Also got it up on my WHS.
  24. Member Lectrol's Avatar
    Jan 30th, 2006
    Tucson, AZ
    Mercedes 560SEL, BMW E30 1990
    02-16-2011 02:07 AM #1249
    Got my first work unit done! place #125 lol.
  25. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    02-16-2011 01:03 PM #1250
    Quote Originally Posted by EpicVW View Post
    To use the smp client for your i7, you download the client from the high-performance client page here:
    http://folding.stanford.edu/English/DownloadWinOther
    There's an awesome tutorial on how to set it up here:
    http://www.overclock.net/folding-hom...mp-client.html
    I promise it's not as hard as it looks.
  26. Member EpicVW's Avatar
    Feb 10th, 2000
    Bay Area, CA
    02-16-2011 08:14 PM #1251
    Unfortunately, when I said "Hackintosh", it's a i7 running OSX. I downloaded the OSX client, and according to the activity monitor it is maxing out all of it's cores/threads. That should help, ya?
  27. Member wheeltowheel's Avatar
    Jun 19th, 2007
    Columbus, Ohio
    02-16-2011 09:25 PM #1252
    Oh, gotcha. That's the best you can do with OSX. I must have subconsciously discounted that because roomate is running Win7 in parallels on his macbook pro (running the SMP client in windows)
  28. Member O_loung1's Avatar
    Feb 13th, 2001
    11 gti apr st2-
    04-17-2011 01:09 AM #1253
    is there an easy way to remote monitor a windows xp home client
    since fah2web is no longer available?
    vortex folding thread.................. ............. ............... ...... ............ ........... .... ... ......... ..... ........ .... ..... ... intention
  29. Member
    Jul 25th, 2007
    Brunswick, MD
    2005 Audi S4/2002 Golf TDI
    04-18-2011 01:06 AM #1254
    Just curious if any of you running Folding@Home have looked at the power consumption of your PCs then calculated the cost monthly for running Folding?
    My old roommate ran Folding 24/7 on his PS3 and I charged him an extra $17/month.
  30. Member O_loung1's Avatar
    Feb 13th, 2001
    11 gti apr st2-
    04-19-2011 01:28 AM #1255
  31. Member
    Jul 25th, 2007
    Brunswick, MD
    04-19-2011 09:22 PM #1256
    I think you may actually be better off donating to a charity that would buy time on a supercomputer to run folding than having your own computer do it... A supercomputer will process a lot more data at a lower cost.
    Does anyone know if one of those exists?
  32. Member
    Feb 11th, 2009
    Lewiston, Maine
    04-20-2011 11:45 AM #1257
    Quote Originally Posted by 1stRabbit View Post
    I think the whole reason for having distributed computing was because it was difficult or prohibitively expensive to buy time on a supercomputer.
  33. Member O_loung1's Avatar
    Feb 13th, 2001
    11 gti apr st2-
    04-20-2011 05:24 PM #1258
    ^^^ right, also you if search for the tianhe-1A, just utilities alone averages out to be $3.5 mil usd/year,
    not including management, hardware, infrastructure.
    having family members die from various forms of cancer gives me more of a vested interest in this
    type of distributed computing than trying to chat with e.t.
    folding is like religion, some get it and some dont, no biggie
  34. Member .skully.'s Avatar
    May 18th, 2005
    Cleveland, Oh
    1998 Jetta, 1988 Scirocco 6MT, 2010 GTI
    04-21-2011 02:06 PM #1259
    keep it on topic sir
    501whp MK6 GTI Build Thread
    facebookGoogle+HS Tuning
  35. Member O_loung1's Avatar
    Feb 13th, 2001
    11 gti apr st2-
    04-22-2011 09:01 PM #1260
    any idea how that happened?
