Page 3 of 719 FirstFirst 1 2 3 4 5 6 7 13 53 103 503 ... LastLast
Results 71 to 105 of 25140
Thread: What did u do to your Mark3 yesterday?
  1. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    03-22-2008 07:29 PM #71
    i fixed my fuba antenna seal
    washed it for the first time since this past summer!
    p.s. Meguiar's ColorX works wonders
    pics to follow
    edit: pg3 owned
  2. 03-22-2008 07:56 PM #72
    New grill, and bought some new rims! spring is coming
  3. Member Mr.Red's Avatar
    May 27th, 2007
    7 ONE 8
    One of the O.G's of DubsOfQueens.com
    03-22-2008 08:10 PM #73
    shaved a front bumper and now Im cheaping
    out and not finishing it...
  4. 03-22-2008 08:12 PM #74
    i bought it.
  5. Member thingfrog's Avatar
    Mar 28th, 2006
    Rabbits
    03-22-2008 08:28 PM #75
    I replaced my torn up steering rack bellows.
  6. Member owenhscott's Avatar
    Feb 22nd, 2008
    High River, AB
    1989 Jetta GTX
    03-22-2008 08:32 PM #76
    Took her to the shop. Her clutch is gone, then she started bucking and jiving, like it was stalling, except more violent. THen it wouldn't start.... any ideas?
  7. Member Mr.Red's Avatar
    May 27th, 2007
    7 ONE 8
    03-22-2008 08:36 PM #77
    I got new tires and finally did a wheel alignment
    today was a good day..no i mean yesterday.
    But really today is tomorrow's yesterday
  8. Member thingfrog's Avatar
    Mar 28th, 2006
    Rabbits
    03-23-2008 01:36 PM #78
    I replaced my sway bar endlinks and washed it.
  9. 03-23-2008 02:27 PM #79
    Changed the stupid waterpump on my vr
  10. Member mj23afs's Avatar
    Aug 24th, 2005
    DWG PA
    03-23-2008 06:14 PM #80
    looked at it and wished that i could find a drivers side fender so the car will actually look decent.
  11. 03-23-2008 06:56 PM #81
    I looked at it sitting out back, We had 4 other cars in and out of the shop, and were to busy to get to it
  12. Member PKstrategy's Avatar
    Oct 21st, 2004
    Queens, NYC
    mk3 squared, 1 b5.5
    03-23-2008 10:56 PM #82
    Quote, originally posted by pkstrategy »
    pics to follow
  13. Member jetta98k2's Avatar
    Sep 14th, 2004
    CT
    98 jetta coupe, 00 cabrio
    03-23-2008 11:29 PM #83
    brought what was left of the beat up shell to the junkyard after it was found stripped bare.
  14. Member Aug's Avatar
    Apr 14th, 2001
    Walnut Grove, BC
    96 Harliquin # 258
    03-24-2008 12:25 PM #84
    So I'm bored today bc i did a bunch of stuff to the car yesterday.
    post up what u've done to ur car yesterday, or just..lately.
    What I did...yesterday and the day before...
    -Finished installing my Hella CELIS lights and got the headlight range motors to work
    - made the fogs work as DRL including the proper voltage drop by rerouting the wire to the headlights to the fogs after the DRL relay
    - installed keyless remote and got the hatch to open too with a relay
    -wired in my iPod adapter to my factory 99 green light headunit
    -installed programmable intermittent front wipers and installed the 98 and up rear wiper switch and relay
  15. 03-24-2008 12:40 PM #85
    i washed mine, and drove it around just for fun
  16. 03-24-2008 01:15 PM #86
    i started sanding my wheels on easter there going from polished alum to flat tan seemed liek a good idea until it took my an hour of sanding to do one but that one wheel looks good wasnt sure how many coats to do i used damn near a whole can on one wheel when in doubt over spray i think it equaled like 7 coats the more paint in the air the better of an idea it seemed
  17. Banned
    Feb 19th, 2005
    Huntsville, TX
    03-24-2008 03:05 PM #87
    Installed cam, dropped 1" in the rear and 1/2" in the front, cut rear fender to stop rubbing. next step wash
  18. 03-24-2008 03:15 PM #88
    installed a 2.5" Autotech/ Magnaflow catback, and I am currently trying to figure out the mess of wires and plugs that was once my wiring harness before my engine went under knife for a rebuild.
  19. Member Scooch's Avatar
    Sep 14th, 2004
    mk3's / 08 r6
    03-24-2008 05:09 PM #89
    Changed from 22mm adapters to 40mm adapters. Now I need to roll the rears
    koolhaus
  20. 03-24-2008 05:34 PM #90
    i looked at the screwed up bumber and fender that i side swiped a parked car with, then the ecu took a s*** some how, trying to figure the car out
  21. Member sio's Avatar
    Jan 30th, 2007
    Nashville, TN
    1997 GTI VR6
    03-24-2008 10:29 PM #91
    finished head gasket, new cat, new 02 sensor, new radiator, new thermostat, new fan control module, new fan switch, coolant temp sensor, g12+ flush, and some mobile 1 0w40. still runs hot (5 degrees)
  22. Member thingfrog's Avatar
    Mar 28th, 2006
    Rabbits
    03-25-2008 03:43 PM #92
    I cleaned it, inside and out.
  23. Member dangtz's Avatar
    Nov 26th, 2007
    NC
    97 Jetta GLS, 01 Honda Magna
    03-25-2008 03:45 PM #93
    stared at it for about an hour, and contemplated on how to fix the gap on the rear bumper.
  24. Member 2pt. slo's Avatar
    Jan 4th, 2004
    Creedmoor, NC
    98' GTI 2.0T, 12' TDI SportWagen
    03-25-2008 03:46 PM #94
    clutch cable... , but only took me 20 mins, still a pain though...
  25. Member 05JettaGLXVR6's Avatar
    Jan 24th, 2006
    Annapolis, MD/Stockblocks, NJ
    03-25-2008 08:40 PM #95
    Gave her a nice wash and wax.
    tryed installing my turbo timer no luck so far..
    Lugtronic
    Clutch Masters
    IE
    9.72@148 Stock Block
    9.46@155 JE pistons/IE rods update 9.36@153
  26. Member oopseyesharted's Avatar
    Mar 2nd, 2005
    South Euclid (Cleveland), OH
    1997 Passat GLX Vr6
    03-25-2008 08:41 PM #96
    Plugs, wires, cap, and rotor.
    Also, got rid of the cone filter that the previous owner rigged onto the car.
    Got some cabby steelies mounted on it as well.
    Dont laugh too loud.....LOL
    I have only owned it for a week.
  27. Member thingfrog's Avatar
    Mar 28th, 2006
    Rabbits
    03-28-2008 10:19 PM #97
    Tried yet again to fix my drivers door power window. The motor works fine. It seems to be the wiring somewhere.
  28. Member Tifun's Avatar
    Mar 26th, 2004
    LOA #2 INDY
    small block B5 A4 BT
    03-28-2008 10:34 PM #98
    Put more duct tape on the window to keep it up so the snow/rain wouldn't get me wet.
    NO SOUP FOR YOU
  29. 03-28-2008 10:53 PM #99
    disabled drls, new clock spring, new tail lights, springs and strut tops, alignment, replaced blown cluster bulbs. oh, and i found a hole in my rear floor cant wait to weld in a new one. bought new fogs and a new airbox to replace the wal mart cold air intake. ripped out all of the aftermarket stereo cables that were left over from the previous 19 year old owner. all i have left to do is replace the downpipe and spray painted side markers and the car will be legal.
    Modified by ratbox20v at 7:56 PM 3-28-2008
  30. Member hainuS4's Avatar
    Nov 23rd, 2001
    Diamond Bar
    95 golf sport
    03-28-2008 11:16 PM #100
    deleted the third brake light.
    Now, just need the hit'n'run fixed on the corner.
    TBS Fo Life!
    psn: PandaGti
    I can't wait for Oktoberfest!!!
  31. Member
    Nov 25th, 2006
    Toronto
    Cool White Jet
    03-28-2008 11:41 PM #101
    Beat on it, let it rest for the nite.
    www.Garage16.ca Is Your One Stop Shop For ALL Your Car Needs
  32. Banned PELLA's Avatar
    Mar 4th, 2006
    03-28-2008 11:43 PM #102
    made sure my timing belt was strong enough to last me for a little while longer.
  33. Member Mr. Hands's Avatar
    Jun 12th, 2006
    610, Pa & 410, Md
    LG9R
    03-29-2008 01:51 AM #103
    i jumped in place
    ->School Haus<-
    FS: Full Euro Center Console, OEM Vento Tub, Duckbill Lip, 16x7.5 & 16x9 Gotti Wheels
    FS/FT: 99 Silver Arrow VR6 Jetta 5-Speed
  34. Member Mr. Hands's Avatar
    Jun 12th, 2006
    610, Pa & 410, Md
    LG9R
    03-29-2008 01:54 AM #104
    Quote, originally posted by hainuS4 »
    umm im pretty sure it is a law that you need to have a 3rd brake light? could be wrong, but im pretty sure.
    ->School Haus<-
  35. 03-29-2008 01:57 AM #105
    ordered smoked dual chamber gti ecodes and got a grille too. emptied the water out of my turn signal!
    edit: pg4 is miiinee
