VWVortex.com - $20 wheel bearing puller, BOOYA!
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: $20 wheel bearing puller, BOOYA!
    1. Member B4S's Avatar
      Apr 16th, 2003
      Marionville, Ontario, Canada
      2002 Forester S, 1984 Volvo 244
      03-17-2008 09:38 PM #1
      Decided to make a tool tonight, to get the front wheel bearings out. Cost me $20 in metal, and a few minutes of welding. Works great too! [IMG]http://*****************.com/smile/emthup.gif[/IMG].
      - 2 stacks of washers (4 each, 2.5" O.D. at the biggest, 5/8" ID at the smallest)
      - 5/8" threaded rod
      - 5/8" coupler nut
      - a length of flat bar
      - some 3" OD Exhaust pipe
      - bit 'o welding.
      Modified by B4S at 8:43 PM 3-17-2008
      Modified by B4S at 8:44 PM 3-17-2008
      Modified by B4S at 6:55 AM 10-3-2008
      1984 Volvo 244 DL...with carb.
    2. Senior Member vdubspeed's Avatar
      Jul 18th, 2002
      Valdosta, GA
      I quit counting.
      03-17-2008 09:43 PM #2
      that's why the mk1 forum owns all....ingenuity.
      I'm lazy and just bought a 20 ton shop press
      Built > Bought
      58 Beetle | 79 Rabbit 20vT | 84 GTI TDI |84 GTI 16vT |12 Golf TDI ----89 325i | 99 QCSB Ram Cummins | 02 Burb 4x4 2500
    3. Member B4S's Avatar
      Apr 16th, 2003
      03-17-2008 09:47 PM #3
      I wanted to buy a press...but the 'manager' wasn't down with the idea .
      So, desperation got the better of me .
    4. 03-17-2008 10:15 PM #4
      Does it press the new ones back it, too?
    5. Member B4S's Avatar
      Apr 16th, 2003
      03-17-2008 10:23 PM #5
      Sure, I just flip the device over, so that it pulls the other way. I'll put in one of the C-clips so that it doesn't go too far in, and voila . It's a copy of a tool I saw on eBay, but 60$ cheaper [IMG]http://*****************.com/smile/emthup.gif[/IMG].
    6. Member veector's Avatar
      Mar 1st, 2006
      Southern Onterrible, Canada
      96 Jetta TD 81 Jetta D
      03-17-2008 10:28 PM #6
      awesome, should be put in the DIY forum [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Buju Banton - Hills and Valleys
      [ ][ ]====W====[ ][ ]
      { + }-------W-------{ + }
    7. Member white rabbit's Avatar
      Jul 23rd, 2001
      Baltimore
      2012 Colorado 3LT, 1988 GTA, 1981 Rabbit Pickup, 1980 Scirocco
      03-17-2008 10:31 PM #7
      if it removes the old bearings it should put the new ones in just fine. just remember that when pressing the new bearing into the hub, you press on the outer race only, and when pressing the hub back into the bearing, you obviously should press against the inner race only. doing it any different will probably damage the new bearings.
      the old bearing cases make good dies for pressing the new ones in. they will seem to get stuck in the spindle when doing this but come out fairly easily with a hammer.
    8. Member B4S's Avatar
      Apr 16th, 2003
      03-17-2008 10:34 PM #8
      For now, this tool is only set up for the outer race. One step at a time .
      As for hammering out the old shell used as a 'push', that's why I use such a long piece of 3" pipe, I just keep turning until it comes out too .
    9. 03-17-2008 10:55 PM #9
      The Schley tool is over 200$ I think, and it can do the job with the spindle unremoved.
      Looks like you could do the job with the spindle on as well.
    10. Member
      Nov 11th, 2002
      North Iowa
      '84 Rabbit VNT-15, '91 golf TD, '87 Jetta GLi, '84GTi 1.7TD, '84 Rabbit diesel
      03-18-2008 03:13 AM #10
      Im going to make something like this some day.
      I was thinking finer threads would make it easier to turn.
      With the big benefit of being able to do it on the car.
      How long is the threaded piece?
    11. Member goosler's Avatar
      Feb 11th, 2002
      hunterdon nj
      03-18-2008 11:03 AM #11
      Quote, originally posted by fatmobile »
      shoulda coulda woulda, but none of you did.......big thumbs up to the O.P. for some grassroots thinking/building of a great tool...... [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    12. 03-18-2008 12:00 PM #12
      Did this this weekend. I put the carrier on the furnace and the bearing in the freezer. No press or puller required. I have always heard of doing this and now it is the only way I will do it now. Have yet to put the hub back in.
    13. Member B4S's Avatar
      Apr 16th, 2003
      03-18-2008 12:45 PM #13
      I don't have exact measurements, but I could get them. I just eyeballed it and cut a section of threaded rod off the length that I bought. I've got another 2' of rod left, since it's only sold in long peices. Honestly, unless you spent some good money and got the hardened stuff, a finer thread would strip out IMO. I had to use a bar on the end of my vice grips to get the proper leverage. Once it 'pops', it's easy though .
      I like this little tool, and I don't have to remove the hub from the car to do the job if I don't want to. Makes future bearing swaps much less of a headache job. I like the freezer tip though, I think I'll give that a shot with the replacement bearings.
      I'd just like to point out that I didn't invent this, I just copied it. I've gotta say though...it's super easy to build, and you could probably get away with spending less than I did if you were crafty.
      Modified by B4S at 11:47 AM 3-18-2008
    14. 03-18-2008 01:24 PM #14
      Quote, originally posted by chickenfriend »
      You can get the same thing as the Schley from Harbor Freight for 60$
    15. Member B4S's Avatar
      Apr 16th, 2003
      03-18-2008 01:51 PM #15
      No harbor freights up here, and Princess Auto (canadian version of HF) didn't carry it. I still had a hard time justifying a $60 outlay for a few metal discs, cups, nuts and a bolt.
    16. Member
      Mar 5th, 2001
      Maine
      2016 VW GSW SEL, 1991 VW GTI 1.8t, 2012 Mazda 5 Sport
      03-18-2008 01:55 PM #16
      Flintstone Engineering at it's best. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    17. 03-18-2008 02:06 PM #17
      I just used a large deep impact socket and a sledge. To put it in a freeze the bearing, and put the spindle in the bbq. Works amazing, can do a job in 5 mins.
    18. Member MK1 Rabbit GTI's Avatar
      Jan 12th, 2006
      Fonthill
      83 GTI, 00 a4, 81 scirocco, 98 a4, 01 a4
      03-18-2008 02:36 PM #18
      he speaks the truth
      BBQ and freezer FTW! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    19. Member B4S's Avatar
      Apr 16th, 2003
      03-18-2008 04:31 PM #19
      It's tough to put the whole car on the BBQ though .
    20. 03-18-2008 04:35 PM #20
      HE SPEAKS THE TRUTH
    21. Member Blu_Hare's Avatar
      Mar 12th, 2007
      San Diego, CA
      '82 Rabbit Pickup / '11 Golf TDI
      10-07-2010 08:37 PM #21
      can you rehost these images please?
    22. Member SGLoki's Avatar
      Dec 12th, 2004
      The Ham
      Too Many.
      10-07-2010 10:01 PM #22
      Ditto this, the way I am imagining this I could turn one on the lathe at school....
      and I have a bearing starting to fail!!!
    23. Member B4S's Avatar
      Apr 16th, 2003
      10-08-2010 09:22 PM #23
      I'm afraid those pics are long lost .
    24. 10-08-2010 10:08 PM #24
      This link shows the basic pieces you need. I have this kit, it works great but i end up using parts of the old bearings to press in the new ones because they fit beter than the arbors the kit includes.
      http://www.harborfreight.com/fwd-fro...ers-66829.html
    25. Member Blu_Hare's Avatar
      Mar 12th, 2007
      San Diego, CA
      10-08-2010 10:24 PM #25
      but that's not $20
      lol, j/k
      I think I can figure it out
