VWVortex.com - DIY - 1.8t Lower PCV Hose install, pics!
    Page 4 of 8 FirstFirst 12345678 LastLast
    Results 76 to 100 of 199
    Thread: DIY - 1.8t Lower PCV Hose install, pics!
    1. 01-27-2010 02:23 AM #76
      How can I disconnect the white connector near the lower engine block connector? I can't see the shape of the connector clearly from outside, so can't figure out how. Thanks.
    2. 01-28-2010 10:00 PM #77
      great write up..lets see if i can follow directions correctly LMAO i will get started on removing this tomorrow morning
      hit me up on AIM and Yahoo Messenger..both SNs are IBeShiftin
    3. 01-29-2010 12:05 PM #78
      It would be so much easier if it wasn't 15 degrees fahrenheit right now. Can't get that damn c clip back on
    4. 01-29-2010 01:33 PM #79
      haha its 8:32am here in Honolulu, Hawaii. im about to start on the removal of this hose....should i be reachin behind the intake manifold or just take it off?
    5. 01-29-2010 07:28 PM #80
      It would be sooooo much easier if you took the intake mani off, but you don't have to. If you have small hands I'd say just keep it on.
    6. 01-29-2010 07:53 PM #81
      guess i should take it off but thats alotta work too..i wanna give up lol..havin a really hard time takin this off. the part will come in on tuesday or wednesday. and i screwed up and broke somethin else trying to make room for me to get in there..dammit..
    7. 01-30-2010 12:45 AM #82
      Yeah it realllllly sucked big time. Pretty sure I need to go back and push the plastic block connecter in more with the c clip. I got a Po107 code at autozone I think (dont remember exactly)... car is running lean though.
      Basically I just destroyed the one time use clips and had to cut off the T because it wouldnt come off the block connector, someone had glued them together! Just take your time and stay calm bro, getting frustrated will only increase your chances of breaking something.
      Modified by NHkid91 at 9:47 PM 1-29-2010
    8. 01-30-2010 01:22 AM #83
      im gonna try again tomorrow lol..im gonna take the intake manifold off already haha..is it hard? and im afraid i might break more hoses or something or find more problems when i do this. i ordered the eurojet hose. and if i dont wannna do it then the dealership is gonna charge about $120 something for them to install it
      Nov 27th, 2004
      Charlotte, NC
      2000 VW Jetta VRT, 2000 Audi TT Quattro
      01-30-2010 09:08 AM #84
      You can get everything off with the intake manifold on. You just need small hands, and you can reach from both sides of the manifold to get your hands in there.
      Mike
      Chapter 11 Dubs: Member #001
      http://www.chapter11dubs.com
    10. 01-30-2010 01:02 PM #85
      Any tips for getting the lower block connector piece back in? I just cant seem to get it in enough. Wiggle it alot?
    11. 01-30-2010 02:58 PM #86
    12. 02-02-2010 12:20 AM #87
      ok well i finally was able to unbolt the intake manifold and get to the lower pcv hose. broke a couple hoses in the process lol but i think i can just repleace those by going to Napa or something. lets hope that works and hope my eurojet hose comes in tomorrow....
    13. 02-03-2010 07:05 AM #88
      Don't know what hoses you broke, but any part of the pcv system is "dealer only".. thats what I was told. You could always rig something up with heater hose if needed. Good luck!
    14. 02-07-2010 06:05 PM #89
      i have a quick question. on the Eurojet site. it says that the replacement kit the offer for the top and bottom hoses is for the MK4 1.8t. i'm assuming that would work on my 1.8t GTI right?
    15. Member christanand's Avatar
      Aug 10th, 2006
      Toronto, Ontario - Buffalo/Niagara Falls, New York
      2002 VW Jetta 1.8T TIP
      02-07-2010 06:08 PM #90
      Quote, originally posted by rdsox15 »
      i'm assuming when you said your 1.8t GTI you were referring to a mk4 1.8t which you mentioned you read off the eurojet site right
      this means the answer is YES
      twitter: @dionsingh
      looking for a house -----> http://www.househuntingintoronto.com...search_mls.htm <----- looking for a house
    16. 02-07-2010 06:09 PM #91
      no, mine is not an MK4, just a 2002 1.8T GTI. i did not see a kit for that on Eurojet so i was curious if the MK4 one would work.
    17. Member msuzuki126's Avatar
      Jun 14th, 2007
      mk4?
      02-07-2010 07:51 PM #92
      Quote, originally posted by rdsox15 &raquo;
      yes the mk4 one will work, your car is a mk4 [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    18. 02-07-2010 11:29 PM #93
      ahh, i see.. you are right.. shows how much i know.. thank you.
    19. 03-04-2010 12:34 PM #94
      I have a MK4 2001 jetta 1.8T with hoses look exactly like the picture, I purchased the eurojet lower PCV hose like everyone suggested and found out that the eurojet hose cannot connect to the PCV valve because the angle is not right. does anyone else has this problem?
    20. Member
      Aug 22nd, 2008
      NH
      01 Jetta
      03-30-2010 05:35 PM #95
      will a broken breather hose cause loss of boost? or what will?
      WTB: tornado red jetta passenger fender. show me what you have.
    21. 04-03-2010 12:34 AM #96
      Quote, originally posted by jspeedmkiv &raquo;
      OK, so I've got the other type of bleeder valve/hose assembly thing:
      Assuming I buy the other type of valve (shown in the diagram), where do I run the other line that came off of the crankcase bleeder valve I had? It runs from that bleeder valve back up to the valve cover onto a nipple that comes off the side of the inlet where the upper Y-hose goes. Does it get capped? Or run somewhere else?
      I'm also stumped on this, I was going to cap it, but I have no idea if it's used for a vacuum or what. I've been searching for hours and haven't been able to find ANYTHING about it.
      posted a reply on this one too, he has the same engine http://forums.fourtitude.com/z...78652
      Modified by hollywood084 at 11:36 PM 4-2-2010
    22. 04-07-2010 11:20 AM #97
      that c clip is a pain to get back on everything else went good actually...only broke my disptick
      is there supposed to be slimey yellow **** in the old pcv hose?
      Modified by BlAcK20AE3088 at 9:07 AM 4-8-2010
    23. 11-02-2010 02:46 AM #98
      Just some more notes on this. It's definitely a PITA!
      1) During removal of old hose, I had to cut the portion connected to the PCV valve. I'd suggest doing this if it doesn't come off easily after the large metal ring is removed.
      2) Remove the dipstick tube. Mine wouldn't come out and I broke it anyways. Apparently, if any portion falls into the oil pan, it's designed to dissolve.
      3) You will probably need to trim the lower hose before connecting it to the upper hose.
      4) I used the zip tie idea to remove the C ring. Worked like a charm.
    24. Member vw fiend's Avatar
      May 9th, 2002
      Carmel, Indiana
      1966 Beetle, 1986 Cabrio, 2016 GTi, 2011 JSW
      11-06-2010 06:18 PM #99
      Great write up! Just used it to install the 034 Motorsports kit on my wifes car.
    25. 11-13-2010 06:06 PM #100
      Can't for the life of me get that damn C clip out of the oil filter housing! Help!!!
      Pretty much rendering my efforts useless. To make things worse the plastic dipstick funnell cracked near the lower collar.
