VWVortex.com - curious about these codes
    Results 1 to 5 of 5
    Thread: curious about these codes
    1. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      03-21-2008 10:02 PM #1
      I need some input, this car was brought in for a scan. Buyer seems to think something is wrong with tranny and seller doesn't think so. I can't find anything on the wiki, and obviously it has some comm problems. Would like to have some input/info on this scan. As you can see I posted the complete scan for your viewing pleasure.
      VAG-COM Version: Release 704.0
      Data version: 20070404
      Saturday,22,March,2008,19:02:59:21818
      Chassis Type: 9C - VW NB Cabrio
      Scan: 01 02 03 08 15 17 19 26 35 37 46 54 56 75
      Address 01: Engine Labels: None
      Part No: 06A 906 032 KC
      Component: 2l ULEV NB-C A6 G 4795
      Coding: 00003
      Shop #: WSC 00066
      3VWCK21Y13M311507 VWZ5Z0C0237192
      4 Faults Found:
      18033 - Powertrain Data Bus: Implausible Message from TCU
      P1625 - 35-10 - - - Intermittent
      17978 - Engine Start Blocked by Immobilizer
      P1570 - 35-10 - - - Intermittent
      16523 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
      P0139 - 35-10 - - - Intermittent
      18044 - Powertrain Data Bus: Missing Message from Airbag Controller
      P1636 - 35-10 - - - Intermittent
      Readiness: 0000 0000
      Address 02: Auto Trans Labels: 09G-927-750.LBL
      Part No: 09G 927 750 N
      Component: AQ 250 6F 0302
      Coding: 0000008
      Shop #: WSC 00000
      No fault code found.
      Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.LBL
      Part No: 1C0 907 379 L
      Component: ABS FRONT MK60 0101
      Coding: 0004097
      Shop #: WSC 00066
      Address 15: Airbags Labels: None
      Part No: 6Q0 909 605 E
      Component: 08 AIRBAG VW7 0517
      Coding: 0012344
      Shop #: WSC 00066
      Address 17: Instruments
      Control Module Part Number: 1C0 920 941 L
      Component and/or Version: KOMBI+WEGFAHRS. M73 V03
      Software Coding: 03234
      Work Shop Code: WSC 15504
      Additional Info: 3VWCK21Y13M311507 VWZ5Z0C0237192
      1 Fault Found:
      01321 - Control Module for Airbags (J234)
      49-10 - No Communications - Intermittent
      Address 19: CAN Gateway
      Control Module Part Number: 6N0 909 901
      Component and/or Version: Gateway K<->CAN V032
      Software Coding: 00006
      Work Shop Code: WSC 00066
      1 Fault Found:
      Address 26: Auto Roof Labels: None
      Part No: 1Y0 959 255
      Component: VSG NBC 2604
      1 Fault Found:
      01091 - Switch Front Canopy (F202)
      008 - Implausible Signal
      Address 46: Central Conv. Labels: 1C0-959-799.LBL
      Part No: 1C0 959 799 G
      Component: 6J Komfortgerát HLO 0004
      Coding: 00256
      Shop #: WSC 00066
      Part No: 1Y1959801
      Component: 6J Tõrsteuer.FS KLO 0001
      Part No: 1Y1959802A
      Component: 6J Tõrsteuer.BF KLO 0001
      Part No: 1Y0959811
      Component: 6J Tõrsteuer.HL KLO 0001
      Part No: 1Y0959812
      Component: 6J Tõrsteuer.HR KLO 0001
      3 Faults Found:
      01331 - Door Control Module; Driver Side (J386)
      53-10 - Supply Voltage Too Low - Intermittent
      01359 - Internal Central Locking Switch; Passenger Side (E198)
      27-10 - Implausible Signal - Intermittent
      01333 - Door Control Module; Rear Left (J388)
      Address 56: Radio Labels: None
      Part No: 1C0 035 157 D
      Component: Radio DE2 0006
      Coding: 06031
      Shop #: WSC 00066
      2 Faults Found:
      00668 - Supply Voltage Terminal 30
      07-10 - Signal too Low - Intermittent
      65535 - Internal Control Module Memory Error
      00-10 - - - Intermittent
      End --------------------------------------------------------------------------------------------------
    2. Member staytuned's Avatar
      Mar 26th, 2005
      pennsylvania
      86 audi 4000 cs, 91 jetta gli, 94 golf gl, 2003 jetta gls, and 2004 touareg
      03-22-2008 06:39 AM #2
      just at a quick glance - it seems that the can bus or data bus whatever you perfer is losing communication with the below modules - my suggestion is view the gateway installation list - then clear all dtc's - reset the readiness codes - drive it and see it any or all come back - at somepoint the battery may have been disconnected - if you want more detail rsvp
    3. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      03-22-2008 09:46 AM #3
      I agree with you about all of that. The car seems to lurch when going from "R" to "D", like it doesn't realize that it's in "D" after backing, then it seems fine. At least for the little I've moved it in the parking lot. My suggestion to the seller(an auction) and the buyer(a dealer) is to take it to a VW dealer and see what they diagnose. But, I could clear the codes and see what comes back.
    4. Member staytuned's Avatar
      Mar 26th, 2005
      pennsylvania
      03-22-2008 10:46 AM #4
      sounds good - must stress one point - when you clear the dtc's adapt the throttle body and the trans kick down - that could explain the erradic behavior in accel and shift changes
    5. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      03-22-2008 12:40 PM #5
      good point. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
