VWVortex.com - DIY Drain/Refill on 09A Tiptronic Transmission
    Page 1 of 6 12345 ... LastLast
    Results 1 to 25 of 126
    Thread: DIY Drain/Refill on 09A Tiptronic Transmission
      Dec 4th, 2004
      Maryland
      2002 Volkswagen GTI 1.8T (Sold), 2009 Nissan 370Z Touring (Current), 2002 Suzuki SV650S (Current)
      03-22-2008 02:40 PM #1
      DIY Drain/Refill Fluid on 09A 5-Speed Tiptronic Transmission
      (This is simply a guide. Perform the procedures at your own risk/responsibility.)
      1. Raise the car with a jack. Remove the 24mm (15/16 inch socket will work, just don’t strip it) drain plug and drain out the fluid (approximately 3 quarts or 2.84 liters came out of my car)
      2. Use a new drain plug + washer and replace it. (new parts required only sometimes according to wear and tear)
      3. Remove red tamper seal on fill plug and remove the plug. Then suspend a funnel from the top of the hood with a hose running into the hole. Pour in 3 quarts of Mercon V Fluid. I used Mobil 1 Synthetic Mercon V ATF. It was about $7 a quart from Advance Auto Parts. According to Coolvdub, this fluid has worked equal to if not better than the OEM fluid’s performance for a fraction of the price.
      There is a wire loom that is hooked onto a metal bracket. You can pop it out of the bracket to get better access to the cap. It is circled in the picture in yellow.
      Once you take the red tamper protector off, this is the black cap that comes out. As you can see, I had to break the sides quite a bit to get a flat screw driver in to pry it off. 60,000 miles of heat made it become stuck on pretty tight.
      This is the funnel that I used. The tip of the funnel has a ½ inch diameter. This just fits into the filling hole. This means that you could use a few feet of ¾ inch hose and plug one end into the filling hole and one end into the funnel. Then all you would have to do is suspend the funnel a few feet above the engine bay right under the hood and it would do the same thing that the $250 dollar VAG 1924 tool does.
      4. Lower the car back down off the jack. While keep all filling apparatus in place, hook up VAG-COM to the car and start the engine. Move the gear selector through each position for about 10 seconds.
      5. [Select]
      [02 - Auto Trans]
      [Meas. Blocks - 08]
      Set group to "004"
      [Go!]
      The value in field 1 should be ATF temp in °C.
      6. When the ATF transmission reaches around 40°C, place the pan under the check plug. Take the plug out. If a little bit of fluid drips out, the level is correct. If nothing comes out, add a little more until it overflows to a drip. Replace the check plug. (for this step, use of a shallow drain pan allows you to not have to jack up a side of the car and get the most accurate fill)
      7. Replace the fill plug and red tamper cap. (If you broke the red tamper cap as I did, it’s cool. The black fill plug will stay on without.)
      8. Take the car out for a test drive. According to Coolvdub on VWVortex who practices this, overfilling the transmission from a ¼ to a ½ quart makes it shift smoother in his opinion.
      9. I did this as well. Even though I drained out 3 quarts or 2.84 quarts. I put back 3.5 quarts or 3.31 liters into the transmission. After reading the threads on the forum, when people followed the Bentley repair manual procedures to the letter, the over flow plug would start dripping fluid at about 2.75 quarts or 2.60 liters. However, after driving the car, they would get groaning noises. When they would add in about half a quart of fluid, the car would be happy. Therefore, 3 quarts is the baseline figure plus ¼ to ½ quart of fluid.
      10. I can attribute this error to the fact that there haven’t been enough transmission failures for VW to revise the procedures for draining and refilling the transmission. Think about how they revised the 105k timing belt to a 60k interval now.
      Credit to Don aka Coolvdub for taking some of the pictures and verifying the steps and instructions of the procedure via email to me
    2. Member carlosabh's Avatar
      Jan 21st, 2003
      El Paso TX
      06 Jetta GLI, 06 VW Sharan, 98 VW GTI
      03-22-2008 07:41 PM #2
      When checking the fluid level at the correct temperature, the procedure in ELSA says that you have to have the engine running, select every gear (R, D, N , 3, 2) back and forth) to complete fill the internal transmission galeries, and then put again in park and check the level, failure to do so can result in underfilling the tranny, I did the correct procedure as ELSA and haven't had any issues, the first time that I just overfilled the transmission with 1/2 a quart more the tranny slip in the 2nd to 3rd gear change, so the problem appear to be that the Bentley procedure don't mention this resulting in fluid level too low.
      Dec 4th, 2004
      Maryland
      03-22-2008 10:17 PM #3
      That is what I have heard from other people as well. You are correct. 3 quarts of fluid is the baseline amount to fill after a fluid drain and most people add about half a quart to this to make the transmission happy and compensate for the variables that you mentioned.
    4. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      2016 GOLF 1.4 TSI 125hp 7speed DSG
      03-23-2008 12:06 PM #4
      You did first fluid change at 60k ?
      now I have only 20k on car and thinking to change earlier
      Dec 4th, 2004
      Maryland
      03-23-2008 02:13 PM #5
      I think 20k is really early. The oem fluid is synthetic. I would change it around 35-40k. I would of done mine earlier than 60k if I had known that it was possible. Up until researching it and talking to a friend on the forums, I had been believing the dealership's lies that the transmission is sealed and the fluid is filled for a lifetime. Also one think to note, a drain/refill replaces only about half of the transmission's fluid capacity. I am going to do another one in a few months so everything get changed. Then I will stick with 25-30k intervals.
    6. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      03-23-2008 02:27 PM #6
      how about to lose bolts on tranny pan and let drain more fluid?
      I will change at 30k like most other cars brand recommend
    7. Member coolvdub's Avatar
      Feb 19th, 2000
      California City,CA
      '02 Jetta GLS, reigning high mile champ 371,675k miles and counting
      03-23-2008 03:17 PM #7
      Just a note that the overfill thing is not an original idea from me. I read it on the Vortex and as soon as I can find that post I will make sure that person gets the credit for it. I have just used it and found it to work for me. By the way good DYI write up with pictures that are working AvantGTI7
      Don
      CANCER SUCKS but KAISER SUCKS MORE/But so far I kicked it's ASS
    8. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      03-23-2008 03:48 PM #8
      why not to use this Mobil 1 fluid?
      http://www.mobiloil.com/USA-En....aspx
      http://avlube.com/mobilatf3309.html
      it's recommended for VW with Aisin trannys
      mk4 tiptronics are made in japan by Aisin
    9. Member coolvdub's Avatar
      Feb 19th, 2000
      California City,CA
      03-23-2008 05:29 PM #9
      Fantomasz,
      That fluid is not the right fluid for the transmission we are talking about. Our transmission is made by Jatco.
      Don
    10. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      03-23-2008 06:00 PM #10
      but at least they recommend for audi and vw (beetle which is mk4)
      how You know that Mercon V is the right fluid?
    11. Member
      Dec 4th, 2004
      Maryland
      03-23-2008 08:36 PM #11
      He has used the fluid for over 70k on his transmission without any problems. This is how he knows. Mercon V should be fine as a fluid as long we are talking about the JATCO 09A 5 speed tiptronic transmission found in VWs.
    12. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      03-23-2008 10:31 PM #12
      ok,but one 70k interval is not sufficient
      maybe next 10 guys will burn their tranny in 5k
      not a single word about audi,vw
      im not saying this is bad fluid but why this one,not the other?
    13. Member
      Dec 4th, 2004
      Maryland
      03-23-2008 10:48 PM #13
      I cannot answer your question. But you can on your own. Be a pioneer. Go do some research and test it out and report back to us on the forums.
    14. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      03-23-2008 11:22 PM #14
      i will think about it
      i have only 20k on car so plenty of powertrain warranty left
      here http://www.blauparts.com/vw/vw...shtml they say that Pentosin is ok for tiptronics
      oem expensive fluid it's a Pentosin ATF http://www.worldpac.com/msds/WP_103.pdf
    15. Member coolvdub's Avatar
      Feb 19th, 2000
      California City,CA
      03-24-2008 12:12 AM #15
      Fantomasz,
      How I found out was doing a lot of research on the internet. I discovered that a derivative of the Jatco 5 speed transaxle was used by Land Rover as well as Mazda in the MPV platform here in the U.S. So I called up a Mazda dealer and asked what fluid was supposed to go in the Auto transaxle for the MPV, I was told Mercon V.
      I decided to take one for the team so to speak and switched over to this fluid. I have not had one single problem with it so far. You stated that maybe I was leading other people down a bad path, I have documented my use of the fluid and advised people to use the OEM fluid if it makes them feel better. In my personal experience with this fluid, it has worked far superior to the OEM fluid and has never come out brown and murky during a fluid change like the super expensive OEM fluid did. I also had transmission problems from 40-45k miles on my original tranny with OEM fluid, while it did last 200k miles before failing. I personally do not see any benefit to using the OEM fluid when a less expensive fluid has given me far superior cost and performance benefits.
      Don
    16. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      03-24-2008 12:22 AM #16
      cool [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      I have 20k on my GTI so You think it's good time to switch to Mercon V before any problems show up?
      Before OEM fluid turn into hot chocolate
      Modified by Fantomasz at 12:50 AM 3-24-2008
    17. Member carlosabh's Avatar
      Jan 21st, 2003
      El Paso TX
      03-24-2008 12:23 AM #17
      The OEM fluid for the 01m 4 SPEED is made by Pentosin, BUT the OEM fluid for the Jatco 5 speed tip is made by FEBI (G052 990 A2)
    18. Member coolvdub's Avatar
      Feb 19th, 2000
      California City,CA
      03-24-2008 12:32 AM #18
      carlosabh,
      Thanks for the info on who manufactures the 09A fluid, knowledge is always a good thing.
      Don
    19. Member Fantomasz's Avatar
      Aug 14th, 2001
      Europe
      03-24-2008 12:40 PM #19
      I just receive short reply from Mobil.I ask them for transmission fluid for my car.They reply with this.
      "Mobil does not have a product that will meet your vehicle transmission fluid requirement"
    20. 04-30-2008 03:54 PM #20
      Thanks for the great post and pic's. I just purchased an 03 Jetta 1.8 w/78k miles and it had a bad 3-4 shift. It would almost overrev the motor. I got different opionions from new valve body ($2500) to is the oil dirty or low. I put a 10oz red bottle of Lubeguard. I took if for a drive the next day and it did the same thing. It sat over the weekend and I took it to a VW shop. It shifted fine all the way in (nine miles). They were the ones who recommended the valve body. I still believed the oil was bad, so I just changed it as mentioned on this post and hope for positive results. My test drive shifted fine. The question I have is it was mentioned the drain tube starts to drip at about 2-3/4 ltrs of oil, so are you just putting in 3 ltrs + 1/4-1/2 liter more without checking it? It makes sense if we are overfilling a little the drain plug would drain it back out. I measured the amount that came out and it was 2-3 ounces less than 3 liters, so I must have been low since I added 10oz of lubeguard. I refilled with 3 liters + 4 ounces. Am I on the right path, I have not yet checked the drain plug since I do not want to loose any if I put in a little extra. I do not have a VAG-COM, but I do have a laser temp gun and can approximate temp from case temp and am guessing the oil will be approx 20 degrees warmer.
    21. 04-30-2008 07:27 PM #21
      One thing - to the original poster. You will not "change all of the fluid with another change". In fact, you will only "change" half again. You have 100% contaminated now. It's just 50% less contaminated as a whole. You would need to change it many times to improve it's condition but it will always be contaminated unless you drain it all at one time, which would involve removing the transmisison from the car. Thanks for the write-up. I get a little slippage. And HOW IN HELL is your Y-hose in such good condition, at 60K? Mine failed years ago at only 35K.
    22. Member
      Dec 4th, 2004
      Maryland
      04-30-2008 08:22 PM #22
      "Old Dude GTI", you are correct. This was a mistake on my part in the write0up. I would have to change it several times for the fluid to be completely new.
    23. 11-16-2009 03:53 PM #23
      i need to reference this link...
      thx
    24. Member vr6jettajay's Avatar
      Oct 29th, 2006
      Titsville, FL
      81 rabbit diesel 4dr, 00 golf gls tdi 4dr
      02-02-2010 04:32 PM #24
      Is there any additional info or a tech bulletin or anything like a bentley for the 5spd tiptronic EEF transmission? I have 2 bentley manuals for the mk4 and neither have anything for a 5spd tiptronic that I have been able to find or read.
      2003 Jetta GLX VR6 - sold
      1984 Cabriolet Wolfsburg - traded
      1981 Cabriolet - traded
      1986 Golf GL sold
    25. 03-03-2010 01:23 PM #25
      4 post above the man mentioned no vag com and adding 3.5 or 3.25 quarts with out pulling the plug to waste the fluid... I'm assuming as well if I let the car heat up to norm temp and I added fluid all 3.5 to 3.25 then I should be ok correct? Cause wit no vag I can't see temps
