VWVortex.com - vehicle speed sensor location???
    Results 1 to 10 of 10
    Thread: vehicle speed sensor location???
    1. Member rudell640's Avatar
      Jul 4th, 2006
      Spring hill, fl
      03 TR VW Gti 1.8t
      03-24-2008 09:37 PM #1
      something is wrong with my speed sensor, but i dont know where it is. I know its on the transmission but i have no clue what it looks like. If anyone has any pics or can tell me specifically where it is that would be great.
    2. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      03-24-2008 09:45 PM #2
      The VSS is on the transmission; on the top, and bolts-in directly down into the transmission casing.
      - Erik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    3. Member rudell640's Avatar
      Jul 4th, 2006
      Spring hill, fl
      03 TR VW Gti 1.8t
      03-24-2008 09:51 PM #3
      it is kinda near the battery at an angle?
    4. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      03-25-2008 12:08 AM #4
      Quote, originally posted by rudell640 »
      No, more towards the rear of the transaxle.
      Behind the shift linkage input, almost above the driver side output shaft.
      - Erik
      Nov 27th, 2004
      Charlotte, NC
      2000 VW Jetta VRT, 2000 Audi TT Quattro
      03-25-2008 10:14 AM #5
      C'mon Erik, you can do better then that VSS is inside this heat shielding bag.
      Mike
      Chapter 11 Dubs: Member #001
      http://www.chapter11dubs.com
    6. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      03-25-2008 10:21 AM #6
      Quote, originally posted by FaelinGL »
      Sometimes the obvious comes to simple to my nature...
      - Erik
    7. 03-27-2008 07:26 PM #7
      Is this the same for the 2.0?
    8. 03-27-2008 07:37 PM #8
      its such a pain in the ass spot....
      go stand near where the battery is and look down toward the back of the engine, you probably wont see it, but you might see a tinfoil heat bag covered in a bunch of grease and dirt, its inside the bag
    9. 03-27-2008 07:57 PM #9
      Awesome thanks.
    10. 06-10-2009 04:27 PM #10
      I have the same issue with an 02 Jetta 1.8T. I am going to try to replace the Vehicle Speed Sensor since I got a check engine code P0722. How easy (or hard) is this to replace?
