dude, jealous=me!!!!!!!! holy crap that thing is gonna be fun! AWD, and a 1.8t in a 2700 lb car, that is the recipe for FUN!!!keep us posted!!!
#1
Well finally begining my build.Starting off with an almost completely stock 1990 G60.
Neuspeed Intake
TT Stainless 2.25 Borla exhaust
Black leather Swap
Euro wheel
Euro seat belts (not installed yet)
Patec Coilovers
Heres where this will be happening.
Well I already had a Stage 4 g60 which was really fun but I want to go a different route this time. So bye bye g60.
This is going to be replacing the PG.
Tore that apart.
Cleaned up the pistons.
Going to need these:
My dad had the shop built for this:
The lift should help with this:
Should be fun in the end
#2
Horology, Renovations, Home, Auto, anything. You need it, I can do it. If I can't, I know who can! I'm here to help! Ask me anything, ill do my best.
MIKEPMCNAIR@GMAIL.COM
#5
Yeah the lift is awesome its got 9000lb rating. Put it in over Easter.
#6
That's awesome, it looks like you're set.
#7
congrats .... nice build![]()
Up and Live >>> www.Herbys53.com <<< sick of the BS , check it out :thumb:
860-798-5227 TEXT anytime
Herbys53 VW/Audi Corral May 29th Lime Rock Park Ct.
53Motorsports-Koni/APR/TT/Bilsteins/Oem+/Service:clap:
#8
Of all tyrannies, a tyranny sincerely exercised for the good of its victims may be the most oppressive. It would be better to live under robber barons than under omnipotent moral busybodies. The robber baron's cruelty may sometimes sleep, his cupidity may at some point be satiated; but those who torment us for our own good will torment us without end for they do so with the approval of their own conscience.
#10
nice man. I just got the motor started that i bought of you last spring. Well not the same motor but same pistons!
#11
Quote, originally posted by gabeskillzz05 » nice man. I just got the motor started that i bought of you last spring. Well not the same motor but same pistons! Sounds good
#12
Quote, originally posted by 18JettaPower » nice lift X 2
#13
Cleaned up the outside of the block, oil pan, valve cover. Bought another K03s and oil filter flange.
Now I need valves and circle clips and i can put the motor together.
Someone buy my g60 motor. I need money for valves![]()
#15
Update: Got my motor painted and then assembled it. Forgot to bring my camera with me so no pics as of now. Just need to get a few more parts to put the motor in.![]()
#16
Quote, originally posted by PSUCorrado » . Forgot to bring my camera with me ) fail!!!!!!!!!!!
i wanna see this ryan, get cracka lackin!!!!
#17
Use the Mk4 TDI oil filter housing. It makes oil changes so enjoyable.![]()
Thinking about a TDI swap? Review the TDI swap directory
My AHU-TDI Corrado's Conversion to European Spec AFN-VNT
#18
nice build. nice garage. is that extension ladder leading to the 2nd level door?
#20
Lucky bastard...that's what I said to myself when I saw the nice big garage. Then I saw the pretty new lift!![]()
Good luck with the build...looks like fun!
#21
Quote, originally posted by G60ING » Use the Mk4 TDI oil filter housing. It makes oil changes so enjoyable. ![]()
Already bought another 1.8t one because mine was broken.
Quote, originally posted by audisnapr » nice build. nice garage. is that extension ladder leading to the 2nd level door? Yeah when my dad got the building built, our township wouldn't allow trusses so we had to build a 2nd floor. The building just passes final inspection about a month ago so the outside stairs haven't been built yet.
Quote, originally posted by brilliantyellowg60 » nice pile of parts ![]()
Should start coming together soon.
#22
ooooooohhh 4 axles means double the fun!I'm paying attention
#25
Bought it from a guy in Hillside. Well thats what his profile says anyway.
#26
my dad has the same lift in his newly built garage!good luck with the build man! keep us posted
#27
Update: Turbo is on and motor is almost fully together.
I think I'm going to paint the non polished parts of the intake manifold black.
Ordered a few more parts. Hopefully they will be delivered before next weekend.
#28
If you ever get the chance to put a different one in I highly recomend it:![]()
#29
Yeah that might be something worth getting. Its the same as the 1.8t but upsidedown?
#30
Quote, originally posted by G60ING » If you ever get the chance to put a different one in I highly recomend it: would that really work on a 1.8T, i mean spacewise, there isnt really much room there?
Immobilizer off and plug & play harness for your swap, VCDS (vag com) scaning, cluster repair/odometer correction, key programing (including newest VW/AUDI), radio/NAVi decoding (including rns 510)....PM me
#31
subscribed.![]()
Toaster on NASCAR: "I'd rather set myself on fire than party with white trash and watch traffic."
#32
20V people sometimes upgrade to the taller 1.9 TDI block so i don't see whay it wouldn't be possible.
#33
i am very jealous of the garage...especially that i'm about the tear into minelooks like a sweet build
#34
Looking good so far! AWD eh?![]()
A lift is sure a nice thing to have (and help). I had to make due with neither so you have two up on me. Good luck.
A life frittered away disgusts God; he loves those who run straight for the finish line.
Never Ending 1.8T Corrado Project
#35
Update: Finally done with school for the summer. Got all the part so I can bolt the motor inNew rear motor and trans mounts, and vr6 clutch:
Solid front mount:
Now I need to clean up the trans so I can bolt it up to the motor.
