Quote, originally posted by vw collector » Most likely yes, just call me and come and get it if you like... ![]()
Thanks for bringing the MBC by Pedro!
I've finally finished installing the LC-1 WB controller. I have output 1 simulating the stock pre-cat NB O2 for the ECU. And I have the output 2 showing full AF from 0-1v on post-cat O2 line. I'm not using a post-cat sensor.
So I can log true AFR on O2 post-cat voltage
3psi = 12.5 AFR (+ 4bar FPR). I'll now start to raise boost slightly until AFR starts to lean out.
Modified by elRey at 1:59 AM 4-14-2008
unless you dont have a cat
now...you're still on stock injectors correct?
Quintin@USRT
