#143
Thanks guys. Though this is pretty old. We still enjoy the car daily.
And no, I'm not up for making another manifold. Sorry.
#144
very nice build, i may have missed it but what did you do about programming the ecu to handle it?, custom programming using vag-com?
#146
am in the process now of customizing the manifold and i will take the 3d example you showed earlier to a shop <-- thanks . also want to run stock turbo does anything changes from the mk4 2.o 8v to the mk3 2.0 8v would my coolant and oil line run like yours ? also will the mk4 oil filter housing fit mines like it did in yours ?
#148
Wow Adding this to my favs... Im replaceing my ko3 with a ko4 on my beetle and plan on useing my old ko3 on my girls 2.0 beetle. This has helped alot.. Im also curious as to what happened havent seen any further updates.. What ever happend with the Ecu? kept the stock ecu and modded the 02 readings is all i can seem to understand but just would love to know how its running and how much boost youve ran so far safely with a good AFR.. Thanks...
#149
Very interesting!
If you want to make your 2.0 8v faster, read the thread below!
http://forums.vwvortex.com/showthrea...owerful-2.0-8v.
