VWVortex.com - Jetta stumbles
    Results 1 to 8 of 8
    Thread: Jetta stumbles
    1. Banned Lawl Master's Avatar
      Mar 20th, 2007
      04-01-2008 01:12 PM #1
      My 5 speed 2.0 jetta (1998) stumbles like a drunkard when its wet out. Now I know that its been covered six million times and it usually needs wires, but it only stutters under load from the stop (idle to 1500 rpm) and when at a lower cruising rpm (1500-2000) and you give it more than 1/4 throttle. These situations only occur when the car is cold and not at operating temperture and its wet outside/raining.
      Once it hits normal operating temperature the stuttering dissappears and it drives like normal.
      Also, when its being a bitch like this, it doesn't like to start, until its warmed up, then it starts easy.
      Explanations?
    2. Banned PELLA's Avatar
      Mar 4th, 2006
      04-01-2008 01:14 PM #2
      ignition coil
      /thread
      Jun 4th, 2005
      Milwaukee, WI
      2008 Rabbit (Previous: 1998 GLS, 279,000 miles)
      04-01-2008 01:30 PM #3
      I have the same problem some times and I have new Magnecor wires (coil wire too) and a MSD Blaster II coil. The problem goes away once the engine is warmed up...
    4. Banned Lawl Master's Avatar
      Mar 20th, 2007
      04-01-2008 01:39 PM #4
      Quote, originally posted by PELLA »
      ignition coil
      /thread
      Is it cracked/broken? Or is it just from moisture?
    5. Member ReflexJettaVR6's Avatar
      Jul 6th, 2004
      Warwick, RI
      '83 Rabbit, '11 CC Sport, '17 Passat
      04-01-2008 01:42 PM #5
      Quote, originally posted by Lawl Master »
      I don't know, is it cracked or broken?
      Can't tell without seeing it. But I had a similar problem with my old VR. The coilpack was cracked. I replaced the whole engine, that took care of it
    6. Banned PELLA's Avatar
      Mar 4th, 2006
      04-01-2008 01:51 PM #6
      moisture wouldnt affect your car unless the ignition coil was cracked
    7. Banned Lawl Master's Avatar
      Mar 20th, 2007
      04-01-2008 02:06 PM #7
      So from what you're saying I should find a Magnum condom XL and put it on my coil pack?
      edit: yeah im a bit perverted, but thanks for the replies
      Jun 4th, 2005
      Milwaukee, WI
      04-01-2008 03:18 PM #8
      Do you know where the arcing would occur with my setup?
      Thanks
