VWVortex.com - Siphoning gas
    The Car Lounge
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 60
    Thread: Siphoning gas
    1. Member punisher89's Avatar
      Oct 11th, 2002
      NoLau
      I hate my car
      04-09-2008 01:29 AM #1
      OK, here's the deal my girlfriend totaled her car today (she's doin ok now) and when I got her home she realized she had just put gas in it the day before so its basically got a near full tank sitting in a tow yard somewhere in pompano. My quesation is, how hard would it be to siphon the gas out and do you think the tow yard will let me do it?
      I'll be damned if I'm gonna let almost $40 just sit there and rot away.
      Would you do it??
      I am the Lizard King.
    2. Member GiacGtiAgain's Avatar
      Nov 8th, 2006
      Commack, NY
      E46 coupe
      04-09-2008 01:33 AM #2
      blow into a portion of hose submerged in gas tank, be prepared to gargle gasoline, and take it like a man
    3. Member WhiteRat's Avatar
      Oct 5th, 2007
      El Paso, TX
      2005 Pontiac Sunfire, 2008 Suzuki XL-7 AWD
      04-09-2008 01:33 AM #3
      Quote, originally posted by punisher89 »
      Would you do it??
      The tow company has probably beat you to it lol free gas.
      My kids like me!
    4. Member SiviK's Avatar
      Jul 15th, 2004
      Armpit of CA
      '06 R53 MCS
      04-09-2008 01:38 AM #4
      Like white rat said, it's probably gone, but if not, the easiest/messiest way, take a pan container of some sort and stab the damn thing. catch the run off. there are pump kits you can use, I've seen em at local auto parts stores, and Harbor Freight. If nothing else.. grab a hose and suck that golf ball. LoL.. buying a pack of gum prior to siphoning is a good idea. Its not that bad.
    5. Member WhiteRat's Avatar
      Oct 5th, 2007
      El Paso, TX
      04-09-2008 01:39 AM #5
      Quote, originally posted by SiviK »
      Or find a crack whore. They'll suck on anything.
      My kids like me!
    6. 04-09-2008 01:42 AM #6
      make sure you have a lit cig in your mouth too .
      Makes me proud to be an American in some perverse way. **** your terrorist, I've a honey boo boo outside.
    7. 04-09-2008 01:49 AM #7
      Easy as pie. Find hose. Insert hose in tank. Suck on hose. Get high from fumes. Get mouthful of gasoline. Drop hose, inadvertently breaking siphon. Lather, rinse, repeat. Eventually you might get some gas into a gas can. Procure stiff drink. Your mouth will still taste like gas, but you won't care as much.
      I lost track of how many times I did that to the Squareback.
    8. Member punisher89's Avatar
      Oct 11th, 2002
      NoLau
      I hate my car
      04-09-2008 09:06 AM #8
      Nice, I knew I could count on quality answers from TCL.
      But seriously I ain't suckin a damn thing, anybody used a kit/pump that they would recommend?
    9. 04-09-2008 09:10 AM #9
      You can get a siphoning tube with a check valve. No sucking required. If you were in Canada I would say Crappy Tire, but in FL I'm not sure, pepboys? LOL
    10. Senior Member Jman5000's Avatar
      Nov 8th, 1999
      Columbus Ohio
      1988 Audi 90 Quattro (out to pasture), 1992 GTI 16V, 2010 Audi TT S-Line
      04-09-2008 09:15 AM #10
      Would you do it??
      No. Because it's probably been drained or siphoned already.
      The insurance company will make your girlfriend whole on the total. Consider $40 of that check "covering" the gas.
      ...and it's just 40 bucks. Is your time/effort and a mouthful of gas worth that?
    11. Member Neon Washer Nozzle's Avatar
      Mar 19th, 2004
      Athens, GA
      Mad tyte JDM '84 Mazda minitruck hellaflush dorifto poke and stretch pro-touring euro edition.
      04-09-2008 09:24 AM #11
      Most tanks I have seen have some sort of drain, its usually a plug in the bottom of the tank. If its just going to the junkyard, you can always drill/stab/axe a hole in the tank, thats what the junkyards usually do anyway.
      You can also get a hand pump from AutoZone or wherever but you might need to extend the line on it to get to the bottom of your tank. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      VW's are proof of miracles. Most of the cars on the Vortex leave a double rainbow behind in the parking spot.
      Sent from my crappy desktop PC using Windows 95 and pirated Wi-Fi .
    12. Member Neon Washer Nozzle's Avatar
      Mar 19th, 2004
      Athens, GA
      04-09-2008 09:24 AM #12
      Quote, originally posted by Jman5000 »
      yes, it is. I don't know about you, but I've never gotten 100% of the value of my car from the insurance company
      Modified by Neon Washer Nozzle at 8:26 AM 4-9-2008
    13. Senior Member Jman5000's Avatar
      Nov 8th, 1999
      Columbus Ohio
      04-09-2008 09:31 AM #13
      Quote, originally posted by Neon Washer Nozzle »
      yes, it is.
      Enjoy $100 of time/materials to reclaim $40. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    14. Member Neon Washer Nozzle's Avatar
      Mar 19th, 2004
      Athens, GA
      04-09-2008 09:48 AM #14
      Hardly... I think that pump costs about $8. And if that tank has a drain plug it would only take about 5 minutes to drain it. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    15. Senior Member Jman5000's Avatar
      Nov 8th, 1999
      Columbus Ohio
      04-09-2008 10:00 AM #15
      -You have to go buy the pump, maybe some other tubing/hose in case you have to siphon.
      -You need to have or acquire 10+ gallons of hopefully correct gasoline containment
      -The junkyard has to let you in to do this. If you show up w/the above gear they're going to ask you what you're up to and will likely kibosh the idea of violent metal-on-metal contact to puncture a tank of flammable liquid.
      -Of course this doesn't account for the likelihood that the gas hasn't been drained by the yard for safety and/or to fuel their rigs....which is likely has.
      -If the wheels (or even 2) are salvageable from the car, they're gone and the car is now resting on it's belly. Good luck accessing a drain.
      -If the damage is a total, but the car has decent salvage parts value, it'll be held in the junkyard-first-crack-at-it area to pull airbags, ECU, interior bits, battery, etc. Insurance won't allow someone into that area.
      It's a minor victory in the face of losing the whole car, but there is a hugely diminished value attempting to chase down the gas.
    16. 04-09-2008 10:54 AM #16
      "Otto, i think you know what to do with this (hands him a hose)"
      "oh man i should've saved the mint for last"
      name the reference
    17. Member
      Dec 31st, 2005
      SoCal
      Corvette & SV650
      04-09-2008 10:56 AM #17
      I don't see the tow yard letting you do this...too much liability, especially for someone that couldn't figure out how to do it on their own...
      Quote Originally Posted by apizzaparty View Post
      never thought once to use my lefty for the brake. sorry in my opinion it is dumb.
    18. Banned BillLeBob's Avatar
      Aug 10th, 2004
      04-09-2008 11:10 AM #18
      Simple
      1) Cut gas line
      2) put jumper wire in fuel pump relay
      3) Trun key to "ON"
      4) Fill cans.
    19. Member spitonit's Avatar
      Feb 6th, 2006
      Volvo 855 turbo , Mercedes C230
      04-09-2008 11:12 AM #19
      Quote, originally posted by smashingpimp01 »
      name the reference
      First thing I thought of was " A Fish Called Wanda "
      Probably way off.
    20. Member
      Feb 10th, 2002
      Massapequa
      04-09-2008 11:16 AM #20
      name the reference
      Simpsons. They were on a field trip to a Civil War reenactment. Uter (sp?) didn't make it back to the bus.
      Sim Simmer.
      Keys.
      Bimmer.
    21. 04-09-2008 11:31 AM #21
      Quote, originally posted by Big M »
      Winner!!!! they didn't have enough money to see the civil war reinactement so they were peaking over the fents as Otto was syphoning gas from the other field trip busses. That's all i have to add to this thread
    22. Member Neon Washer Nozzle's Avatar
      Mar 19th, 2004
      Athens, GA
      04-09-2008 11:57 AM #22
      Gas tanks haven't been made out of metal for a long time. They are all plastic nowadays and have been since the 1980's.
      Most tow rigs are diesel nowadays, good ones anyway [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      [QUOTE=Jman5000]
      QUOTE]
      Nothing a jack and a pair of jackstands can't fix. Assuming the car was wrecked recently they have to allow you access to it to get your belongings out of it before they start parting it out. Also, if the insurance has yet to make a decision they can't touch it.
      If the car has only been sitting a couple of days and its being held at a place close to you it might be worth pursuing, otherwise just write it off. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    23. 04-09-2008 12:08 PM #23
      best answer by far the tow company is going to laugh at you make you feel bad for bothering them then send you on your way
    24. Member Uberhare's Avatar
      Jul 30th, 2003
      Spokane WA
      2012 Golf TDI, 2015 Triumph Rocket 3 Roadster
      04-09-2008 12:40 PM #24
      Buy one of these:
      Super siphon.
    25. Member Surf Green's Avatar
      Feb 16th, 1999
      Silver Spring, GerryMarylandering
      2 Turbo Wagons... One is incredibly slow.
      04-09-2008 12:46 PM #25
      Harbor Freight probably has a rubber bellows siphon pump for $3.
      Course... stuff from Harbor Freight has the tendency to catch fire... And their non-powered stuff is no exception.
      I keep up with traffic with only 90 hp. What's your superpower?
      2002 Golf Wagon TDI - 2007 Fuji Heavy Industries WRB WRX Wagon - YouTube Track Videos - flickr
      Past: 1996 Surf Green GTI VR6 - 1985 Golf 1.8L - No Trim Level Edition
