Page 1 of 2 1 2 LastLast
Results 1 to 35 of 40
Thread: DIY: Audi S6 install MkV R32
  1. Member isdereks's Avatar
    Nov 25th, 2007
    Seattle
    MkV R32
    04-13-2008 02:51 AM #1
    Original: http://5thirtyone.com/archives/892
    This is a rough DIY for installing the OE Audi S6 LEDs. Thanks to Josh at OEMPl.us for getting one of their last sets out to me last week.
    Get the supplies, hardware, and tools
    Requirements (or highly recommended items): OE Audi S6 driving lights acquired direct through Audi or online, Audi S6 LED harness, jack + suitable jack-stand(s), electrical connectors + tools, electrical tape, thin metal strips for custom brackets + hardware, Dremel + cutting tools, hex and torx bit set(s), and a second set of hands.
    Front & lower grill removal
    Start with the two lower grills. Mark the bottom edge of the last horizontal grill on each side. This will be the highest that you are allowed to cut (for bottom placement). Both are secured with two philips screws closest to the aluminum center grill. Once these are removed apply pressure near the top of the grill to unclip then pull straight out.
    The center aluminum pieces slides off just as easy assuming you remove two screws from the top under the hood, two behind your license plate frame (towards the outer edges), and two (on each side) which are exposed once the lower grill pieces are removed.
    Before moving on to the bumper delete, you'll want to disconnect the headlight washers from the bumper cover pieces. Do this by prying the bottom edges up to slip your fingers underneath. The washers slide out at ~45 degree angle. Unclip the covers and lay them to the side.
    Bumper removal
    Now comes everyones favorite part locating all the necessary screws to loosen and put aside. Start underneath the front of the vehicle and locate the two screws in directly underneath the middle of the bumper. Follow that with three screws on the underside (left & right). Then, remove three screws from the front edges of the wheel wells. The final two screws are at the top of the bumper piece behind where the aluminum grill used to be. With a second set of hands, the bumper will now slide straight off.
    Before excitedly removing the bumper completely, unclip and unscrew the headlight washers from the bumper. You'll notice that a single hose feeds both washers [which is also secured in place with metal clips.
    With the front bumper removed, you'll have one naked looking MkV R32.
    Bumper trim + brackets
    This next step requires a little more trial and error. Because the S6 LEDs are not a direct drop in solution for any Volkswagen, the process of fitting requires patience and small passes with a Dremel cutting disk. The process was tedious - a combination of cut and test fit, cut and test fit. Using the last horizontal edge of the lower grills as guides, I marked the lowers with a pen to give me a rough idea of where to cut.
    Once both sides had been trimmed down enough to fit the LEDs, Kevin cut and bent a set of brackets to secure the lights do the bumper.
    Electrical, wire as fogs or tap sidemarkers
    Because I had already deleted my North American sidemarkers, I had a set of previously used harnesses to tap for power. Unfortunately, because the LEDs were not plug 'n play, I simply snipped the sidemarker harness and reconnected with to the OE Audi S6 harnesses. <strong>Remember, brown is ground.</strong>
    Some individuals might decide to run the Audi harness directly to the fuse box and reprogram their light switch in order for the LEDs to act as fogs, I chose to reuse the sidemarker wires allowing me to run the lights full time or as parking lights.
    Final results
    With the lights properly tested and wiring secured, it was time to re-assemble the front end of the vehicle. The end result was well worth the frustration and sore finger tips. I imagine the total cost had I commissioned a body shop to install the lights would have been in excess of $400.
    Modified by isdereks at 9:11 AM 4-14-2008
  2. 04-13-2008 02:53 AM #2
    Nice DIY, I just did my Euro R-Line dash kit, got the dash cubby and euro cupholder. Hopefully doing the dash cubby tomorrow.
    Looks great, I'm still weary about cutting up my bumper though. I'm gonna wait out for the JDM Axis HID fog light kit that someone posted on here.
  3. 04-13-2008 02:55 AM #3
    Great job. Thanks for posting the DIY
  4. Member RafaGolfBr's Avatar
    Dec 17th, 2001
    Coconut Creek - FL
    10 Mocha CC Sport - 10 Salsa Jetta LE
    04-13-2008 03:34 AM #4
    nice nice!
  5. Member crabpot's Avatar
    Dec 9th, 2006
    Mill Creek, WA
    2007 S4
    04-13-2008 03:54 AM #5
    Looks good Derek
    BPCDubs» We use a bidet, that's how euro we are.
  6. Member
    Aug 5th, 2002
    Boston, SF, Taipei, and Shanghai,
    2007 R32
    04-13-2008 04:45 AM #6
    nice work
    Goofy's euro .:R32
  7. 04-13-2008 10:53 AM #7
    I vote that this gets puts in the DIY sticky at the top
  8. 04-13-2008 12:00 PM #8
    Awesome job. Looks great. Im not a great DIYer so I'll buy the parts and drive out to you from PA and you can help me out. I envy you guys who are skilled at the more complicated mods. Peace.
  9. 04-13-2008 12:15 PM #9
    you rule.
    i hope you come up with more threads like these when you add some other stuff to your R.
    much appreciated.
  10. Member isdereks's Avatar
    Nov 25th, 2007
    Seattle
    MkV R32
    04-13-2008 06:11 PM #10
    Quote, originally posted by VW76R32 »
    Ha, for the price of driving (gas) I bet you could get the lights + have a body shop install them. When everything was buttoned back up I tried to decide whether or not it was worth the trouble, or if I should have just had someone else do it. I'm leaning more towards enjoying / being ok with something having been broken on my car when I am the one that does the damage, as opposed to someone else doing causing the damage.
  11. 04-13-2008 07:41 PM #11
    agreed i would much rather do it myself...altough not having a garage kinda stops me in alot of areas
    great install thanks for posting it up, at least i have an idea of what i face now
    Mar 11th, 2000
    Houston, TX
    2013 GTI
    04-13-2008 08:33 PM #12
    Scarred to death of the Dremel!
  13. 04-13-2008 08:36 PM #13
    I can't wait to do this on my CW .:R too. Looks great. Thanks for the write-up.
  14. Member isdereks's Avatar
    Nov 25th, 2007
    Seattle
    MkV R32
    04-13-2008 09:00 PM #14
    Quote, originally posted by CedDoc »
    I didn't have a garage. I had ask to use someone elses garage.
  15. Member Tourenwagen's Avatar
    Dec 28th, 2002
    NJ
    13 CW G6
    04-13-2008 09:57 PM #15
    Great writeup thanks. Can we get a close up of the fitment? Would like to see how the edges look... thanks.
  16. 04-13-2008 10:30 PM #16
    Thanks for the DIY, there goes $400 i was gonna make this week
    EUROMEDIAN your source for all things euro Blog.Video.Stills.News
  17. Member eurospek.'s Avatar
    Mar 30th, 2005
    Hampshire, IL
    04-13-2008 10:53 PM #17
    Great write up!!!
    2005 SAAB 9-2X AERO Arctic Silver 4eat | COBB Stage 2 Protuned
  18. Member
    Aug 5th, 2002
    2007 R32
    05-12-2008 01:43 PM #18
    do you have the part number for the 3-pin connector housing? thx
    Goofy's euro .:R32
  19. Member Air23h20's Avatar
    Nov 18th, 2004
    PCH, CA
    1963 DLX BUS, 1973 Thing 181, 2009 Sportwagon, 08 R32, 73 Beetle, 99 Jetta, 93 Golf 111, 85 golf
    05-12-2008 01:45 PM #19
    Live it, Love it, dub it.
  20. Member
    Aug 5th, 2002
    2007 R32
    05-15-2008 01:30 PM #20
    okay, I got the right connectors, but where should I run the cables to? please note i have an euro R, so no bumper markers...
    i know brown (1) is the ground, how about the other 2? can I just tap them on the parking lights wires? will that throw a code? errr... i guess this is the only time I wish I have a US bumper
    Goofy's euro .:R32
  21. Member GTI017's Avatar
    Jul 21st, 2004
    Seattle
    2010 BMW 335i M-Sport
    05-15-2008 02:11 PM #21
    Quote, originally posted by isdereks »
    you had me until this... i wold so pay the shop, but that is me
    were you in Magnolia this last week? I swear i saw you but was thinking to myself "Derek doesn't have LEDs"
    BPC>>Dubs - I am not only a member, I am also your father
    I wish I was a derivative so I could lay tangent to your curves
  22. Member tr.:R's Avatar
    May 5th, 2007
    Houston, TX
    08 R32. 05 Jeep Wrangler
    05-15-2008 02:35 PM #22
    dammit, now i want em
  23. Administrator BHB's Avatar
    Oct 26th, 2004
    Southern California
    '11 Grand Cherokee
    05-15-2008 02:39 PM #23
    love the way that looks
    Current: 2011 Jeep Grand Cherokee 5.7 Hemi 4x4, 2013 BMW 650GS Sertao, BMW 1150RT
    Gone: 2010 Audi S4; 2008 GTI; 2007 Audi A6; 2004 Audi allroad 2.7T; 2001 Audi A6 2.7T; 1999.5 Mk4 Jetta VR6; 1991 Jeep Cherokee 4.0 4x4
  24. Member R32Girly's Avatar
    Feb 7th, 2003
    Miami
    MK6 GLI Autobahn
    05-15-2008 02:43 PM #24
    i love it! nice DIY!!!
  25. Member UFC_Champ_Scott's Avatar
    Mar 15th, 2006
    Atlanta, GA
    1998 VW NewBeetle
    05-15-2008 03:37 PM #25
    Great work, dude. Nice garage, too!
    Lonesome Dove Design
    He who makes a beast out of himself gets rid of the pain of being a man.
  26. 05-15-2008 03:46 PM #26
    Looks good, add another .:R with S6 lights
  27. Member isdereks's Avatar
    Nov 25th, 2007
    Seattle
    MkV R32
    05-15-2008 05:46 PM #27
    Quote, originally posted by GTI017 »
    I was in Magnolia. My family stills live there
    IamGoofy, sorry I don't have the part number. Contact OEMPl.us. They should have that on file.
  28. 06-20-2008 01:54 PM #28
    Looking for a white MKV .:R32 I install the S6 lights
    ive done my car UG
    ive done a DBP
    and today i installed them on a TR
    All im missing is the CW. im only installing them on each color and then thats it. I get alot of requests to do it but its not really worth it for me. SO if you have a CW .:R32 and live in NY Ill give u a good price. after that last car is finished Im going to do a big photo shoot, and ill give prints to all involved
    Ill post pics of the 3 cars with the lights so far tonight
  29. Member tr.:R's Avatar
    May 5th, 2007
    Houston, TX
    06-20-2008 02:33 PM #29
    Quote, originally posted by xoxodr »
    ive done my car UG
    ive done a DBP
    hmmmm im in new hampshire. its not a long drive.
  30. 06-20-2008 03:24 PM #30
    Considering that you drove from Houston to New Hampshire....whats a few more miles.
    I think you should hook up Jack.
  31. Member TANiK's Avatar
    Jun 24th, 2003
    Beverly Hills, CA
    2013 GTI DSG (2008 BMW 135i gone, 2008 R32 turned in, 2003 GTI totaled)
    06-20-2008 06:33 PM #31
    OP: are you a real estate agent?
  32. Member isdereks's Avatar
    Nov 25th, 2007
    Seattle
    MkV R32
    06-20-2008 07:33 PM #32
    Quote, originally posted by TANiK »
    Nope. But someone in my girlfriends family is.
  33. Member
    Dec 27th, 2009
    Bahrain
    04 M3 cs, 07 VW R32
    02-03-2013 03:41 AM #33
    You wouldnt happen to have the Part numbers handy for the S6 LEDs and plugs etc would you? Cheers.
  34. Member
    Dec 27th, 2009
    Bahrain
    04 M3 cs, 07 VW R32
    02-03-2013 02:48 PM #35
    Quote Originally Posted by tWiStEd-tORqUe View Post
    Holy Zombie Thread
    4F0941067A Left
    4F0941068A Right
    Hahah thanks Bud and see you soon.
