VWVortex.com - *The unofficial VR supercharged reference thread* specs, setups, et cetera
    Page 138 of 244 FirstFirst ... 3888128134135136137138139140141142148188238 ... LastLast
    Results 3,426 to 3,450 of 6100
    Thread: *The unofficial VR supercharged reference thread* specs, setups, et cetera
    1. Member Rheinland Technik's Avatar
      Apr 2nd, 2010
      Charlotte, NC
      2010 CC 3.6 4Motion Exec.
      01-15-2011 07:08 PM #3426
    2. Member obdONE's Avatar
      Jan 28th, 2002
      Houston
      95 VRT
      01-17-2011 11:18 AM #3427
      Selling my top mount now:
      http://forums.vwvortex.com/showthrea...ir-Intercooler
      Glad to see you guys are still pushing the boundaries.
    3. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-18-2011 07:04 AM #3428
      Nobody on spark plug choice?
    4. Member
      Mar 31st, 2006
      WA
      91 RRC, 97 GTI
      01-18-2011 07:10 AM #3429
      i ran 7e's on my turbo setup from 6psi all the way to 15psi without problems. might be worth trying 6e's though since you will be staying on low boost and wont see peak until redline with the charger
    5. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-18-2011 08:21 AM #3430
      Thanks ill prob up the boost eventually just starting low
    6. Member Rheinland Technik's Avatar
      Apr 2nd, 2010
      Charlotte, NC
      01-18-2011 10:57 AM #3431
      Autolite [yes I did say Autolite] AR-3923 or AR-3922 work well. They are a single electrode plug and have a colder heat range good for forced induction use and do not foul or suffer spark blow out easily. I have used them on turbo VR6's and ABA's and they worked well in my old supercharged Jetta GLX. They are also easy to find at most parts houses.
    7. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-18-2011 01:31 PM #3432
      Gotcha. In the process of looking at a 3.0 vr anyone have experience with a motor bored .2 over? Anything to look out for?
    8. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-18-2011 05:34 PM #3433
      Okay here's another question.... I have a 98 gti. AAA block. I have the brackets about to go on... supercharger bracket is a bit odd fitting. Here's a pic can anyone tell me the.brand it is?
      That top bolt hole doesn't line up with anything. Its actually in the way. Hits the top of the head and valve cover making the whole bracket sit on an angle leaning foward. Here's an attempted pic of that...
      See the gap towards the back? Problem one. Now problem two... the idler sits flush against the alternator. But there's still a half inch gap for the bolt holes...
      I could stack a ton of washers but it just seems like its the.wrong figment all together.
      Thanks in advance
    9. Member prometheus_'s Avatar
      Oct 6th, 2009
      pickering, ontario
      96 Golf GTI
      01-18-2011 10:52 PM #3434
      I'm looking to be building a supercharged car this spring.
      I've got a rough idea of what I'm looking to get, but I don't know much when it comes to pulleys and such (dual idler etc).
      With that said, there's a V1 for sale a couple hours from my place for $1000.
      It came off a F150.
      Should that bolt right up with the right bracket & pulleys?
    10. Member KubotaPowered's Avatar
      Jan 27th, 2005
      Tucson, AZ
      2013 PG GLI
      01-18-2011 11:07 PM #3435
      Make sure it is CCW rotation.
      Quote Originally Posted by ..Derek.. View Post
      Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    11. Member prometheus_'s Avatar
      Oct 6th, 2009
      pickering, ontario
      96 Golf GTI
      01-18-2011 11:25 PM #3436
      Quote Originally Posted by KubotaPowered View Post
      I'll find out, but it should be as those guys run CCW
    12. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-19-2011 07:35 AM #3437
      If anyone has a bracket setup they wanna get rid of, lmk. I don't have a complete kit. Or if u have a few parts. That'll do aswell
    13. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      First world problems
      01-19-2011 08:44 AM #3438
      Quote Originally Posted by euroguy666 View Post
      Thanks in advance
      1. The top bolt hole is for if you drill into your head to gain extra support so not to rip the treads out of the tensioner position.
      2. There should be some aluminum stand offs and longer bolts for the idler. ~.460 thickness
      -Noah
      Corrado - Burns money faster than hookers and blow | 996 Turbo - Hates noise ordnance's, fuel and tires in that order | TT - Colorless Wonder with a C16 habit | TT - Colorless Wonder II Lives Again!
      "Life is tough, but it's tougher if you're stupid" - John Wayne
    14. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-19-2011 09:04 AM #3439
      Wats the thickness of the standoffs? .4 of an inch?
    15. Member TheDeckMan's Avatar
      Sep 26th, 2004
      W.Mass
      01-19-2011 11:36 AM #3440
      That is correct 0.460" (11.63mm)
      -Noah
    16. Senior Member .LSinLV.'s Avatar
      Nov 13th, 2009
      Vegas Bitches!
      12' V6 TDI ........ 00' VR6T ..........72' 914-6.................15' Honda CTX700N
      01-19-2011 11:41 AM #3441
      PM me for info
      Larry
      Demokratikally Elekted Minister of Shekels and Cuddles Therapist of the Independent People's Republik of Offtopikstan
      Quote Originally Posted by atomicalex View Post
      The boobs. I am waiting on the boobs here.
    17. Member 2PointGoGoGo's Avatar
      Sep 11th, 2005
      Blackhawk
      2008 Sierra, 2014 Tiguan, 2000 Cabrion
      01-19-2011 12:29 PM #3442
      I know this is going back a couple months but did verdict ever come out with a o2 spacer for those running the TT downpipes?
    18. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-19-2011 01:24 PM #3443
      Pmed. And thanks for the measurements if I can't get ones from a kit ill know about the size ill need to create something. My buddy is a master with his tig so well see. Working on a custom bracket possibly aswell!
    19. Member Rheinland Technik's Avatar
      Apr 2nd, 2010
      Charlotte, NC
      01-19-2011 03:31 PM #3444
      Thanks in advance
      The kit pictured is a copy of the of AMS, not made by AMS, as the cuts look more plasma cut rather than laser cut, so the quality is less than par. Top bolt hole has to be drilled into the head and tapped for threads [optional use, but not required]. I may have a set of spacers for the alternator bracket. You would rather use one spacer than a stack of washers for best stabiltiy and minimum flex.
    20. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-19-2011 04:30 PM #3445
      I agree on the washer comment. I basically need the spacers and that's about it. Im gonna get rid of the top hole and get the verdict support for the rear. That should be way more than enough support.
    21. Member MeCarTay's Avatar
      Mar 14th, 2004
      Verdict Motorsports
      01-19-2011 05:37 PM #3446
      Replied to your email
    22. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-19-2011 06:55 PM #3447
      Thanks phil. You helped me out a ton!
    23. Member obdONE's Avatar
      Jan 28th, 2002
      Houston
      95 VRT
      01-20-2011 11:35 AM #3448
      you should be able to get aluminum spacers from home depot / lowes easily enough. either that or phil or noah could make you some, I'm sure.
      Phil, what happened to that guy interested in my pulley? I never heard from him...
    24. Member euroguy666's Avatar
      Apr 8th, 2009
      toms river , nj
      1998 DE Gti vr6
      01-20-2011 08:29 PM #3449
      Phil hooked me up with the spacers and hardware. Thanks!
    25. Member MeCarTay's Avatar
      Mar 14th, 2004
      Verdict Motorsports
      01-21-2011 02:24 AM #3450
      Not a problem
      Quote Originally Posted by obdONE View Post
      I emailed him your info. Be patient!
