Page 140 of 155 FirstFirst ... 40 90 130 136 137 138 139 140 141 142 143 144 150 ... LastLast
Results 4,866 to 4,900 of 5419
Thread: *The unofficial VR supercharged reference thread* specs, setups, et cetera
  1. Member scirockin16v's Avatar
    Sep 3rd, 2005
    minibikes are big fun
    05-12-2012 10:41 AM #4866
    you were racing on a closed course right?
    Don't hate the player, hate the team.
    Jun 26th, 2008
    CT
    2001 Vr6 Supercharged Gti
    05-12-2012 10:56 AM #4867
    of course
    Jun 3rd, 2008
    Worst Case Ontario
    GTI/Saabaru
    05-13-2012 02:00 PM #4868
    Me(green) Prometheus_(upper red) and DMOE(lower red)
    BHCanuck
    Quote Originally Posted by BHCfarkas View Post
    BFA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  4. 05-13-2012 05:18 PM #4869
    Don't see that very often.
    Jun 3rd, 2008
    Worst Case Ontario
    GTI/Saabaru
    05-14-2012 09:54 PM #4870
    Can anyone share some insight?
    Car kinda had a wonky idle. Sometimes it's high. Sometimes it bounces. My biggest issue is while driving normal and "feathering" the gas to maintain speed it's a little bit unresponsive for like an 1/8th throttle.
    V1 charger
    36# tune from c2
    6puck sprung clutch(not sure if that's even relevant)
    Stock Audi a4 diverter valve
    I leave for sowo(13.5hr drive) would like to work this out
    Only thing that might change this also is the vacuum line on the throttle body is plugged. Not sure if that matters at all.
  6. Member shazzam's Avatar
    Feb 15th, 2010
    vermont
    02 jetta glx vr6 supercharged, 08 F150-DD
    05-15-2012 10:33 PM #4871
    so i need a little help, i have a used stage 3 vfe kit, i need new injectors unsure of what to run, was thinking 440cc or is this too big?
    Mar 8th, 2008
    Germany
    Jetta MK4 VR5 Turbo
    05-16-2012 01:52 PM #4872
    what boost are you running?
    you can calc the CC´s of the injectors 1:1 in horsepower.
    so 440cc @ 4bar will be ok for nearly 440hp
  8. Member shazzam's Avatar
    Feb 15th, 2010
    vermont
    05-16-2012 08:03 PM #4873
    its a stage 3 kit vfe says it will do 300 whp @ 10psi, so 300cc injectors? seems small, i will be running 4bar
  9. Member prometheus_'s Avatar
    Oct 6th, 2009
    pickering, ontario
    88 jetta coupe
    05-16-2012 08:27 PM #4874
    300whp?
    Not to be a negative nancy or anything, but I find that extremely unlikely from a vfe kit (or any standard V9 kit).
    Many here will agree that VFE is pretty shady when it comes to VWs, and they like to stretch their advertising a fair bit.
    300hp at the crank perhaps. After drivetrain loss, it'd be about 260-70whp.
    edit: their own graph for stage2
    looks like 250whp & 230lb-ft, compared to their advertised 280hp 250lb-ft for stage2
    add maybe 10whp per psi (their stage3 is 2psi more)
    Scraped.Crusaders.
    slalom coupe
  10. Member shazzam's Avatar
    Feb 15th, 2010
    vermont
    05-16-2012 10:28 PM #4875
    haha doesnt surprize me im getting pretty upset with them they are really hard to deal with
  11. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    Corrado SLC , TT 225QC
    05-16-2012 10:36 PM #4876
    250whp requires more than 10psi. On stock cams its more like 12psi. With 268 cams, 12psi and a good solid tune 300 is a lot closer, however it still is very difficult to go much over the 300 range as the ability of the belt to transfer drive torque is being overloaded at that point.
    I'm not endorsing the purchase of a Saab, cause I'd rather gargle battery acid. It was merely the best example I could think of.
  12. Member shazzam's Avatar
    Feb 15th, 2010
    vermont
    05-16-2012 10:46 PM #4877
    yea im just going off the info i got from the web page, anyways what size injectors should i be looking for? im getting a c2 tune for it
  13. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    05-16-2012 10:54 PM #4878
    Quote Originally Posted by shazzam View Post
    for over 6psi you need 30# or 36# injectors depending on the software. The 30# C2/UM file sucks the big fat one. If your running 8psi on GIAC, I suggest staying with that. The allowance of power and more boost with C2/UM is at a trade off in driveability and engine life. C2/UM runs way rich and will wash down the cylinder cross hatching.
    Only way to go is Lugtronics/other standalone.
    <--Have rebuilt way too many SC engines that the wrong software killed.
  14. Member prometheus_'s Avatar
    Oct 6th, 2009
    pickering, ontario
    88 jetta coupe
    05-16-2012 11:17 PM #4879
    don't forget, it sounds like it's for a 24v Jetta not a 12v.
    Scraped.Crusaders.
    slalom coupe
  15. 05-17-2012 12:08 AM #4880
    I had talked to united motorsports about my 24v stage2 vf kit and to put cams in he recommended 660 injectors 60#
    I am here: http://tapatalk.com/map.php?r1coaa
  16. 05-17-2012 01:21 AM #4881
    I have been looking for pics of a v9 with the outlet rotated foreword to a fmic and have had no luck. If anyone has any please post up!
  17. Member
    Mar 8th, 2008
    Germany
    Jetta MK4 VR5 Turbo
    05-17-2012 01:27 AM #4882
    ruf and me designed a new impeller wing for the rsc charger. it now pushes out 13psi. should be enough for 300hp on a vr6 engine. the main problem will be the cooling with a standard fmic. the pressure drop is to big so we only use liquid intercoolers for supercharged cars. maybe this will help the Vx chargers to more boost.
    we tested it on an r32 mk4 with a 9,5:1 compression. it made 370hp. ill post the dyno later
  18. Member websaabn's Avatar
    May 23rd, 2003
    Hopkins, sc
    05-17-2012 09:55 AM #4883
    Quote Originally Posted by DeckManDubs View Post
    I think that had some to do with your setup, i have 3 c2/um tuned supercharged VR6 cars in my driveway that run and drive great, 1 has 157k miles on it and has had the c2 tune since 07 when it had 115k, 1 with 113k and no issues had the tune since 90k ish, another with 171k and no issues aswell, the head was just off to do a 8.5:1 spacer and upgraded to 630 pro maf setup and the block looks great.
    The road to riches is paved with Jolly Ranchers!
  19. Member websaabn's Avatar
    May 23rd, 2003
    Hopkins, sc
    05-18-2012 11:50 AM #4884
    Change of plans, we will be in the Cabriolet @ SOWO if anyone wants to meet up PM me
  20. Member
    Mar 8th, 2008
    Germany
    Jetta MK4 VR5 Turbo
    05-23-2012 09:01 AM #4885
    donno why you runs such big injectors. you can go with green g60 injectors (280cc) @ 4bar to get 270hp. maybe its the better fuel in germany? i run 470cc@4bar on my v5 gt3071r setup with 1,5bar boost
  21. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    05-23-2012 11:15 AM #4886
    Started my build if anyones interested.
    http://forums.vwvortex.com/showthrea...he-Whole-Story
  22. Member mk3alltheway's Avatar
    Feb 9th, 2011
    Jefferson, NJ
    99 Wolfsburg (RIP) 97 CBR 600 F3 (Sold) 97 jetta glx (parted), 99 CBR 600 F4, 1991 Gti
    05-23-2012 11:59 AM #4887
    X2
  23. Member BOUDAH's Avatar
    Aug 15th, 2008
    Eldersburg, MD
    '04.:R32 , '13 CC
    05-23-2012 12:03 PM #4888
    Quote Originally Posted by mk3alltheway View Post
    X2
    VWgeorge2 has a bunch in both his threads. look him up. ( his first thread has the V9/ his second the V2/1 So don't feel misled if you don't see a V9, His first one regarding his hybrid setup has it clocked downward.
  24. Member prometheus_'s Avatar
    Oct 6th, 2009
    pickering, ontario
    88 jetta coupe
    05-23-2012 12:30 PM #4889
    Quote Originally Posted by napkin View Post
    much better fuel in germany
    for the most part, the best you can regularly get in north america is 94 octane which is weak compared to the 100+ you can get in europe
    Scraped.Crusaders.
    slalom coupe
  25. Member websaabn's Avatar
    May 23rd, 2003
    Hopkins, sc
    05-23-2012 02:02 PM #4890
    It was good meeting you @ SOWO Banana.Phone
  26. Member
    Mar 8th, 2008
    Germany
    Jetta MK4 VR5 Turbo
    05-23-2012 02:29 PM #4891
    hmm.. curious! in fact that you have to calc the boost on top of the fuel pressure. so when you run 4bar fuel pressure + 1bar boost... youre already at 5bar fuel pressure. cant imagine what stressy job its for the programmer to get a stable idle on such cars
    102octane? we also got e85 gas stations now
  27. Member mk3alltheway's Avatar
    Feb 9th, 2011
    Jefferson, NJ
    05-23-2012 03:00 PM #4892
    Isnt that what the whole new fad is with the rising rate fpr? The fact that its linear and easier to tune for, yielding higher numbers..
  28. Member
    Mar 8th, 2008
    Germany
    Jetta MK4 VR5 Turbo
    05-23-2012 03:24 PM #4893
    as long as the fpr is on the (under)-pressure line it will ever be the same
    so an original fpr will raise fuel pressure with rising boost.
  29. Member
    Jun 3rd, 2008
    Worst Case Ontario
    GTI/Saabaru
    05-23-2012 03:30 PM #4894
    Quote Originally Posted by websaabn View Post
    Was great meets you guys a well!!
  30. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    05-23-2012 07:11 PM #4895
    Rising rate FPR's = Junk. A bandaid fix that should be solved with standalone.
  31. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    05-23-2012 08:15 PM #4896
    i think the wording is getting people all confused. A regular FPR will raise fuel pressure 1:1 for boost. What you want to stay away from is 2:1 4:1 12:1 etc. these are usually called FMUs.
  32. Member prometheus_'s Avatar
    Oct 6th, 2009
    pickering, ontario
    88 jetta coupe
    05-23-2012 10:02 PM #4897
    Quote Originally Posted by Banana.Phone View Post
    No trouble on the way down?
    Scraped.Crusaders.
    slalom coupe
  33. Member shazzam's Avatar
    Feb 15th, 2010
    vermont
    05-23-2012 10:23 PM #4898
    Quote Originally Posted by dirtydeedss View Post
    if i ever get around to putting my car back together i will post up pics, atm the front of my car scattered around my garage, basement, and spare bedroom
  34. Member
    Mar 8th, 2008
    Germany
    Jetta MK4 VR5 Turbo
    05-24-2012 02:22 AM #4899
    Quote Originally Posted by bonesaw View Post
    correct but in his opinion they are trash too
    if he wants a stable fp, just pull off the pressure line
  35. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    05-24-2012 08:36 AM #4900
    Rising rate FPR's was how EIP use to tune, increasing fuel pressure on stock or low flowing injectors until they flowed. IE to the fuel pressure levels of CIS cars. But that was perhaps before your time.
