Results 1 to 6 of 6
Thread: Can open-air IAT sensor be placed in dirty air (before filter)?
  1. Member mjleamy's Avatar
    Mar 16th, 2004
    1991 GLI 16V running Megasqurit N Spark-Extra; 1974 BMW 2002tii, Malaga
    04-19-2008 02:30 PM #1
    My IAT sensor is suffering from heat soak (16V 9a in a GLI) and I need to relocate it. I am wondering what my options are.
    Thanks! Mike
  2. Senior Member ValveCoverGasket's Avatar
    Mar 20th, 2002
    its raining
    '67 rolls royce, '67 mgb gt, and a '13 mom wagon
    04-19-2008 03:58 PM #2
    if theres any way for you to put it into a metal intake pipe (ideally one thats separated from the intake manifold by a silicone coupler) thats probably the best place for it. itll still be close to the throttle body but wont heat soak from the manifold as much as if it were bolted to it. the closer it is to the cylinders, the better...
    id avoid putting it into the dirty air if you find yourself driving on dirty roads or in dusty areas. otherwise its probably not that big of a deal
  3. Member eurotrashrabbit's Avatar
    Oct 24th, 2001
    Sterling,VA
    65 sunbeam tiger, 76 rabbit,85 gti,89 cabriolet,95 s6 avant, 03 mazda protege 5
    04-19-2008 10:30 PM #3
    Not a great idea but you can use an ABA one closed element type
  4. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-20-2008 12:52 AM #4
    I have an open element 1.8t sensor zip tied to something by the filter, never had a problem with it there.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  5. Junior Member j1cam's Avatar
    Sep 13th, 2011
    Las Vegas, NV
    98 GLX
    04-27-2012 07:42 PM #5
    I want to do this in my VR and I have a couple of questions I hope you could help me with. What did you plug the intake manifold with where the sensor was located originally? Is the harness long enough to locate the sensor in front of the MAF? And, would the new 1.8t sensor fit the old vr sensor's harness? Thanks.
  6. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    04-28-2012 10:59 AM #6
    I left the stock sensor plugging the hole. I extended the stock wires about 2' maybe more. There are lots more details in a few threads in the 12v forum.
    -Paul
