VWVortex.com - mk3 gauge cluster removal walkthru
    Page 3 of 5 FirstFirst 12345 LastLast
    Results 51 to 75 of 104
    Thread: mk3 gauge cluster removal walkthru
    1. 01-17-2011 05:52 AM #51
      Quote Originally Posted by etsd311 View Post
      while i was in the process of removing my mk3 gauge cluster, i figured i'd make a simple walkthru with pics in case someone didn't know how to.
      you'll need a flat-head and phillips-head screwdriver.
      enjoy!
      gauge cluster before removal
      step 1
      pop off outer plastic cover next to headlight switch
      step 2
      stick your finger in here and press retractable button to remove headlight switch
      where the button is located on switch
      step 3
      remove screw hidden behind headlight switch
      step 4
      pop off plastic cover (if you have heated seats, remove outer cover first to remove switch)
      step 5
      remove screw hidden behind cover (or switch)
      step 6
      the plastic bezel is held in by the 2 screws you just removed and clips up top
      step 7
      once bezel is out, remove one screw on each side of gauge cluster
      step 8
      cluster sits on 2 rubber grommets at the bottom. wiggle it to an angle to get it out. unplug the 2 connectors at the back of the cluster (3 if you have ABS)
      step 9
      wiggle some more and you're free!
      hope this helps someone! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      Is this the stock gauges?
      Quote Originally Posted by Tony Danza View Post
      All 4 for $20. Do you need a payment plan?
      “I am the punishment of God...If you had not committed great sins, God would not have sent a punishment like me upon you.” genghis khan
      Nov 13th, 2002
      Olympia, WA
      87 Scirocco 16v (Milla), 01 Lexus IS300 (Lyla)
      01-17-2011 06:50 AM #52
      yep!
    3. 01-31-2011 09:07 PM #53
      nice diy, im doing this tomorrow to replace check engine bulb.
    4. Member
      Jan 29th, 2011
      SE PDX
      mk3 golf (jolf)
      02-13-2011 11:47 PM #54
      Do you need to buy a new cluster to get the gauges white or is there a way of doing it yourself.
      good write up btw
    5. Member VTECeateR's Avatar
      Oct 27th, 2000
      Bay Area, CA
      '16 GTI, '16 CX-5 GT
      02-20-2011 07:22 PM #55
      I have a pesky airbag light that I was thinking of removing. Can I just take the bulb out?
    6. Member Evin's mk3 wolfsburg's Avatar
      Nov 27th, 2010
      Massachusetts
      1999 volkswagen jetta wolfsburg
      02-28-2011 09:00 AM #56
      thanks for the help going to redo my gauge cluster lights soon
    7. Semi-n00b
      Mar 10th, 2011
      1999 VW Jetta MK3 Wolfsburg
      03-18-2011 09:52 PM #57
      Great write-up. I have a bulb burned out in the top right corner. VW dealer wanted close to $150 to replace it. Now, if I can get access to a garage (apartment life sucks sometimes) I may attempt this.
      Nov 13th, 2002
      Olympia, WA
      03-18-2011 09:55 PM #58
      you can totally do this wherever you live!
      i personally did this while sitting in my car listening to the radio in my carport.
      apartment life can also rule!
    9. Member deletedo1m's Avatar
      Jul 9th, 2007
      WC,PA
      97 TR jetta, 87 jetta, 81 caddy, 95 cbr600
      03-19-2011 10:17 PM #59
      Quote Originally Posted by Mac010 View Post
      Yea there is no need for a garage. If you can sit in your car you can take the cluster out don't be afraid to try it. Crazy that the dealer wants $150 for something that really only takes a few minutes.
    10. Member rudygetz's Avatar
      Aug 21st, 2006
      Miami, FL
      '83 Rabbit Diesel, '97 GTI VR6
      04-03-2011 03:20 AM #60
      Quote Originally Posted by deletedo1m View Post
      watching this
    11. Member sleepin gti's Avatar
      Jan 21st, 2011
      clarion pa
      megasquirt 3 powered 95 black gti VRT on a cup kit not slammed. and my minty mk2 jetta wolfy daily
      05-18-2011 07:33 PM #61
      good write up,
    12. Member vwjon21's Avatar
      Jan 16th, 2004
      Broward county, FLr
      MK5 jetta
      05-19-2011 11:09 PM #62
      i just replaced my cluster plug everything right, and when i turned the car on the back lights of the cluster doesnt work does that mean i left something disconnected or is that i have to change the blub???
    13. Member Si Trav's Avatar
      Oct 26th, 2008
      Queens Village NY
      lots of them
      05-21-2011 06:00 PM #63
      can someone tell me what size LED light bulbs are in the cluster I want to swap out my awful green ones for some blue ones
      Queens 718
    14. Member Si Trav's Avatar
      Oct 26th, 2008
      Queens Village NY
      lots of them
      05-21-2011 07:00 PM #64
      subscribed by the way
      Queens 718
    15. 05-23-2011 07:03 AM #65
      A lot of DIYs for cluster needless and lights but the only one I could find for actual removal of the luster
      thanks very much
    16. Member deletedo1m's Avatar
      Jul 9th, 2007
      WC,PA
      05-23-2011 08:10 AM #66
    17. 08-12-2011 06:26 PM #67
      do the rpm gauge and the speedo run off the same sensor?
    18. Member
      Nov 13th, 2002
      Olympia, WA
      08-12-2011 06:52 PM #68
    19. Member flotsam's Avatar
      Oct 8th, 2009
      2002 VW Jetta, 2001 VW Cabrio, 1998 Subaru Outback, 2006 Hyundai Sonata, 1995 BMW 325i
      11-01-2011 06:14 PM #69
      Fabulous, i was looking for this. I have a car I only have a few days to get through inspection. The air bag light is on and i replaced the part but don't have what i need to reset it yet. So i may just remove it to get through inspection.
      Everyone has photographic memory; some just don't have the film.
    20. Member
      Nov 13th, 2002
      Olympia, WA
      11-01-2011 06:20 PM #70
      unfortunately, that won't work if they scan the car.
      obd2 will report the fault and you will still fail the inspection.
      your best bet is to try to find someone or a shop who has a diagnostic scanner and can clear the fault code for you.
      good luck to you though. i always hated smog tests in los angeles, but now that i live in washington, no inspections!
    21. Member flotsam's Avatar
      Oct 8th, 2009
      11-02-2011 02:32 PM #71
      In Maryland the inspections are done by service stations & its a one time thing. But I don't now that they use scanners as part of their test. I thought it was mostly safety inspections (ie . brakes etc) Its been so long since i did one of these I can't say what will happen.
      Now emission tests are every two years now and they do connect a scan tool to the OBDII connector. Now that is for emissions so i don't know what they would do if they encountered an airbag fault.
      Come to think of it i am sure the emissions folks (and probably the mechanic doing the inspection) wouldn't even see it if they hooked up a scanner since I doubt they have a VW specific scanner. (my current problem!)
      I am going to disconnect the bulb! nothing to lose
    22. Member VR6 NRG's Avatar
      Apr 23rd, 1999
      Anthem, AZ
      2015 Audi S3 on air / 1996 VR6 Cabrio on air
      01-08-2012 11:41 AM #72
      this helped a lot
      just popped mine out in less than 5 mins. going to swap in another cluster to see if it fixes the P1613 code i have.
      2015 Audi S3 2.0T quattro - Air Lift / fifteen52/ PARTS SCORE / B&B / BFI / GIAC
      1996 Cabrio build thread http://forums.vwvortex.com/showthrea...6-build-thread
      I Sell Audi's in AZ
    23. Member
      Jul 3rd, 2011
      Joliet, iL
      99 VW Cabrio MK3, '12 Nissan Rogue (Wifey's)
      01-11-2012 12:21 AM #73
      Gotta say, after using this walkthrough, I've become quite the champ @ dismantling, and putting it back together again! Thanks!
    24. Member AnthonyLawson's Avatar
      Sep 9th, 2011
      Olathe, Kansas
      1995 MK3 Jetta 2.0, 1997 GTI VR6
      02-14-2012 03:31 PM #74
      Got to the bottom of the 2nd page and became impatient...what if you have one of those old car problems...where if you hit the dash hard a few times the cluster lights come on...hit it too hard and the lights go off and the speedometer drops and dies...hit it again...speedometer is fine but the lights don't work....
      http://i.imgur.com/YaKvp.gif
      Quote Originally Posted by I haz cheezeburgerz View Post
      I want my click back
    25. Member AnthonyLawson's Avatar
      Sep 9th, 2011
      Olathe, Kansas
      03-19-2012 05:00 PM #75
      Quote Originally Posted by AnthonyLawson View Post
      Actually figured this one out myself...the lights on the cluster are in a circuit...one gets loose, knocks the others out...
