Page 541 of 576 FirstFirst ... 41 441 491 531 537 538 539 540 541 542 543 544 545 551 ... LastLast
Results 18,901 to 18,935 of 20152
Thread: Hampton Roads Euros
  1. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    2010 JettaSW, 84 Rabbit GTI-G60, 90 Corrado, 02 GTI
    03-09-2012 06:17 PM #18901
    Quote Originally Posted by jagerauto View Post
    Thats pretty big.. I have to fit the oil cooler, intercooler, and radiator in the rad support. Thats why I was going to get a small one to mount vertically on one side of the rad.
    But I'm looking at a pretty cool intercooler that really like. I wont have to rout tubing all over the bay with it.
    Volvo one is about the smallest you will get unless you get one off Ebay and hope they dont pop. It fits upright between the upper radiator support and lower.
    Measures 4 X 11 without brackets for mounting on the end. With the mounts its 13 inches long.
    This one still has the shrouds from the volvo mounted on it.
    Fittings.
    Mounted.
    THru the grill.
    Quote Originally Posted by bengone1 View Post
    Amateurs swap wheels...
    If you are here to start an argument, run along and play. This place isn't for you.
  2. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    82 Rabbit 4DR Turbo Diesel, VR6 Caddy W.I.P.
    03-09-2012 07:07 PM #18902
    this is how I want to do my piping for my IC. Also I'm doing a 12" slim electric fan. I want to put that in between the IC and the rad. I'm sure my hopes are high, and there is no way this will all fit, but I have my hopes up.
    Also anyone want a intercooler, I wont need this one.. make me an offer. stock srt4 I think
    I'm on here way too much
  3. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-09-2012 08:16 PM #18903
    That radiator is shifted in that car. If you are going to go thru that trouble you might as well make an all aluminum race radiator fit.
    Saab has a in an out on one side inter-cooler about the same size as that one you have there. There is one on the shelf in my carport. (Ill get pics when the sun comes up)
    The BMW oil cooler that i have would stack over or under something like that nice, but one is going to not be as efficient due to the front bumper and how the air moves in the MK1.
    I installed a Civic radiator in my MK1 and the bottom 2 inches of it are not really doing anything because of the way the front of a MK1 is. But i can tell you that even being 1/2 the size width and having the bottom portion covered it still cools just fine. But you are going to have to rebuild the lower radiator support to get it in there.
    And those slim fans you need to make some sort of mount for them. The thru the raditor zip tie mounts suck.
  4. Member engineman98's Avatar
    May 30th, 2008
    Moyock
    2004 24v GLI, 2007 Fahrenheit GTI #975, 1984 rabbit GTI
    03-09-2012 08:21 PM #18904
    Quote Originally Posted by SpnksVW View Post
    This^^ I cut through the radiator in my truck with the stupid mounts that came with the fan. I fabbed up some L brackets and drilled some holes for mounts. It looked good when I was done and no more cutting radiators with it.
  5. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-09-2012 08:22 PM #18905
    This is back before some of the stuff was figured out and running.
  6. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-09-2012 08:32 PM #18906
    ALso have this one for a MK2. I moved the bleed tube ports to the driver side (like the should be) and since i was running a MK3 2.0 i didnt want to run a Y configuration i added a port. But a tig welder can correct that.
  7. Member bengone1's Avatar
    Jun 17th, 2003
    Newport News VA
    2001 allroad 6sp, 98 GTi TDi, Caddy TDi to be
    03-09-2012 09:15 PM #18907
    This all reminds me that I really need to go and see what Spanks has going on. I think I have that same Honda rad sitting somewhere.
    Malone tuning services available- Contact Ben at MaloneTuningVA@gmail.com
    http://malonetuning.com
    MK4, B5, B5.5 remote window control recoding available and VCDS MK5/6. SKC retrieval, Cluster matching, IMMO programming/delete.
  8. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-09-2012 09:33 PM #18908
    We'll see, I have a intercooler picked out, but if you have one cheaper let me know.
    As for the through rad mounts, Pauls looked fine. He didnt say anything bad about em.
  9. Member VR6Mann's Avatar
    Apr 10th, 2008
    Norfolk, VA & York, PA
    92 Jetta sold, 94 Jetta Sold, 98 Jetta GLX SOLD, 99 2.0 DD and 00 Jetta VR
    03-09-2012 10:10 PM #18909
    Anthony message heyfu or else use baseball bat..theres another person local with one but I forget.....those the rears or fronts??? not much to roll on rears on mk4s
  10. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-09-2012 10:20 PM #18910
    Quote Originally Posted by VR6Mann View Post
    anothony has a nice blue .:R I doubt he wants to chance his paint with a bat..
  11. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-09-2012 10:55 PM #18911
    I have a liquidation of all VW parts since i got into Gopeds.
    Cheaper, take up less space, hold less fuel, will kill you just as fast (if not faster) and still a blast to ride.
    The rabbit is staying for a while so the parts that might have a chance going on it are staying, but other than that, any reasonable offer is considered on all the MK2/MK3/Turbo/Corrado stuff that is here.
    When the wife's new bug gets here its going in the garage, so all the other crap has to be gone.
    Should be here April/May time frame.
    Mine did too for the first few miles, but they eventually work their way loose and the fan starts to walk all over the place.
  12. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-09-2012 11:01 PM #18912
    Greene has one too in NN. He did my Audi years ago.
  13. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-10-2012 12:42 AM #18913
    did you say gopeds? lol havent ridden on of them since I was 13.
    I have the oil cooler figured out... I'll just pick up a hood scoop from paul, the cool Kami one. Then top mount the oil cooler on top of the motor, and actually have a functional hood scoop!
    I'm thinking about matching the vertical volvo one with a intercooler that is short enough to give the oil cooler space to brethe. Then mount the radiator behind those, I might have to settle with the fan on the inside of the radiator, but then I can utilize the shroud for mounting it.
    Am I planning to far ahead? haha. I still have to get the truck welded up let alone painted and oh yea running. The motor isn't even assembled yet. But I have high hopes to have everything done by h20i. Including a Giles pump.
    Been thinking about just saying F the jet ski and go big! But I've wanted a ski for as long as I can remember
  14. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-10-2012 06:32 AM #18914
    Yes, Goped.
    42cc before i sold it.
    Start of a carbon fiber deck.
    Machined my own intake adapter plate.
    Mountain bike disk brakes And rear frame welded.
    54cc pocket bike motor adapted to goped.
    71cc auger motor adapted to goped.
    About ready to send two more frames out for powder coating. I just got one back and the 71 is mounted, but i need a longer cable for the throttle.
  15. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-10-2012 06:36 AM #18915
    you would love my kart, maybe a race is in order? lol
  16. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-10-2012 06:49 AM #18916
    Not into carts.
    I can legally drive mine on the streets as long as they dont know its over 49cc and cops cant do a thing about it. (unless im speeding)
    Can you?
  17. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-10-2012 07:00 AM #18917
    Not into carts.
    Can you?
    Honestly they probably wont catch me
    I'm in chesapeake, they might stop me and say hey dont do that.
  18. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-10-2012 07:22 AM #18918
    Good luck with that.........
  19. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-10-2012 10:04 AM #18919
    yea
    Mine has launch control that will put more G's in your pocket than an .:R
  20. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-10-2012 10:18 AM #18920
    yea
    Wow! I have a rocket powered lawn chair and girl scout cookies.
  21. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-10-2012 03:53 PM #18921
    I wasn't bragging, just joshing. But I love when I dump the clutch the front wheels come off the ground, and with a ground clearance of 3/4", it's crazy lol.
  22. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-10-2012 08:33 PM #18922
    My wife's ER-6N bike will do the same thing.
    Big deal.
    Now if you want to continue with the "my peepee is bigger" post you go right ahead!
  23. Member bengone1's Avatar
    Jun 17th, 2003
    Newport News VA
    03-10-2012 08:44 PM #18923
    Nice, I have a Kawi 650R that I trashed and half podged into an er6n with ZX6R front forks and brakes. Let me know if you need anything. I mount and balance bike tires as well as everything else.
    Oh, and my winky is the biggest evar
  24. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-10-2012 09:07 PM #18924
    I have a FZ6 personally. Few years back i had a GSXR750.
    Ill take your word on your peepee.
  25. Member bengone1's Avatar
    Jun 17th, 2003
    Newport News VA
    03-10-2012 09:37 PM #18925
    FZs are great bikes. I am a fan of Yamaha build quality. The FZ you can actually ride all day. The 650 was my first. I have a Japan spec 94 Kawi ZXR400 that I play with. My wife has an 06 SV650s
  26. Member AnthonyR32's Avatar
    Mar 26th, 2008
    Chesapeake
    .:R32 MKIV
    03-10-2012 09:48 PM #18926
    Maan I want a bike, haven't ridden one since I was 17 though .. my cousin's lame dirt bike :/
  27. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-10-2012 10:31 PM #18927
    Big deal.
    So I shall..
    why are you butthurt? Apparently you think I am joking your mo-peds? I dont know, but seems like your getting all hostile because I was telling you about my kart, and not in anyway except maybe joking, bragging about my kart or how big my slong is.
    Trust me I wouldn't brag that my kart is better than anything, it's no where near a race kart but still tons of fun!
  28. Member VR6Mann's Avatar
    Apr 10th, 2008
    03-10-2012 10:44 PM #18928
    So I shall..
    Hunter get off your own dick damn.....and Anthony hit up either heyfu or matt greene..... Those ****in scooters are balla reminds me of this video... http://www.youtube.com/watch?v=j-cnXGFha_M
  29. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-10-2012 10:48 PM #18929
    says the guy that got a fox body, or did you
    You've posted that twice now about fender rolling, Anthony has got the fender rolling covered.
  30. Member AnthonyR32's Avatar
    Mar 26th, 2008
    Chesapeake
    .:R32 MKIV
    03-10-2012 10:58 PM #18930
    I am still looking to get my fenders rolled .. hopefully this guy comes over tomorrow.
  31. Member VR6Mann's Avatar
    Apr 10th, 2008
    03-10-2012 11:43 PM #18931
    Photobucket
    Hahaha nope obivously you dont have any friends lol Paul, Austen, Gary, Dom all saw my car like 2 weeks ago hahaha.......Photobucket
  32. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-11-2012 12:23 AM #18932
    [QUOTE=VR6Mann;76345663Hahaha nope obivously you dont have any friends lol Paul, Austen, Gary, Dom all saw my car like 2 weeks ago hahaha.......QUOTE]
    why would you lie about selling your car and getting a stang?
    Hey guys it was a great run moved up....traded my VR today for a nice rustang....
    Went from this
    [IMG]n777427999_2634940_5581519[/IMG]
    To this
    [IMG]Machinery Love[/IMG]
    To this beast
    [IMG]24561647-206-1993-fox-body-Mustang-GT[/IMG]
    Hahaha everyone in here is butt hurrt from yesterday and damn the fitment on this thing
    I dont understand you. You flipped face because your butthurt V&R kicked you out, at least what I heard, and for good reason because you did bash them and Gene when you were talking to me a while back.. I just nodded my head and didn't want to get into it. Cince then I've learned your very two faced and I've heard you say stuff behind numerous peoples back as well as mine. I may have told you how I felt about Gene's shop, but I had already been talking to him and let him know how I felt about it long ago. Funny your the one to proove me right. I guess I was the only one to see the picture, or maybe I put on a two faced front of my own to be able to hear everything. At least have the decency to be like Matt and just be a dick, and stop acting like your everyone's friend.
  33. Member SpnksVW's Avatar
    Dec 21st, 2004
    Hampton VA
    03-11-2012 05:41 AM #18933
    So I shall..
    The only one that is always "buthurt" on this forum is you. You are actually one big joke and thats not just my personal opinion. Personally i could give a rats ass what you are trying to convey on this forum.
    Good luck with yet another car that someone else built that you claim your own.
  34. Member VR6_notlosin's Avatar
    Oct 12th, 2009
    Virginia
    SC GLI Reflex S.
    03-11-2012 08:41 AM #18934
    Volks and Rings has a new Eastwood fender roller! If anyone needs there fenders rolled
    Come see us . !! We got one due to the overwhelming request to roll fenders.
    Hunter I finally got a truck ! Lol dodge
    Ram that is
    VR6 24v ELITE #506
    Volks and Rings - VW performance and repair. OPEN for Business
    Call 757.874.0018
  35. Member jagerauto's Avatar
    Jun 3rd, 2009
    Chesapeake
    03-11-2012 10:01 AM #18935
    I still dont know why you continue pick at my posts, clearly I have nothing against you.
    I'm not butthurt trust me, just fed up with some people one here
    I dont even know how to reply to claiming it as my own build. I give plenty of credit where it's due.
