Installed 15mm spacers on the rear wheels! Looks great! A very subtle improvement.![]()
#36
Quote, originally posted by TTracing » Joe, what oil cooler did you ordered? Mocal 235 16 row with lightweight racing hose, remote oil filter housing and Canton Mecca 6 in screw on filter.
#37
#38
I finally put the battery back in and drove it to work....![]()
haven't driven it in about 2 and a half weeks...
#41
Quote, originally posted by sims159915 » changed my spark plugs....they were horrid.
Doin' those right after I change my fuel filter. I plan on getting those done today.
#42
Quote, originally posted by DnA-TT »
Doin' those right after I change my fuel filter. I plan on getting those done today.Same here, only after I chip it (this weekend??)
Never underestimate the stopping power of a tree.
#43
Yesterday tried to crank it and the battery is dead....Haven't moved it in a while.....I guess I have to junk it now!
#44
Got my intake and catch can on, but now I need to repair the vacuum crap under the intake manifold cause I have a CEL from breaking a lot of it![]()
#45
Quote, originally posted by EvoJetta » Yesterday tried to crank it and the battery is dead.... Haven't moved it in a while.....I guess I have to junk it now!
Junk it due to a dead batttery??
#46
Washed and vacuumed.De-greased the engine. Also cleaned the windows.
Ah...feels good to look at a clean TT. We had a sprinkle of rain then a bunch of dust blowing around. My car looked like a leopard w/ all those damn spots!![]()
#47
I hit it and swore at it because the instrument cluster is starting to take a ****![]()
#48
I washed off 9 eggs that were pelted at it.Then later in the day just gazed in AWW at the damage the eggs caused.
So painful!!!
Wish people weren't such cowards and instead of throwing them at my car just tried throwing them at me. (wouldn't go over as well for the culprit.)
#49
I'm giving my car a nice wash/clay/prep polish/wax today and am doing a quick vacuum today.Woohooo sunny and 64 degrees, it's nice out!
P.S. The A4 forum is dead on Vortex, I just wanted to say hi haha
#50
Well, I chipped mine today (InMotion) and swapped out the spark plugs for one heat range colder.It now officially goes like hell.
Next up, new (to me) wheels.
#52
Errrric, I miss the TT forum here... nobody goes in the A4 forum, I have to hang out at AudiZine instead!
#53
to that. How about audiworld? Wouldn't that be better?
...or, you could pick up a 180q and BT it for cheapThat's give you an excuse to come back
And, I cleaned my engine bay tonight, and tomorrow is the outside
Modified by l88m22vette at 10:37 PM 5-4-2008
#54
I can't stand AudiWorld's forum layout... I refuse to go there![]()
#55
Swapped wheels to 18" x 8" and put 20 mm spacers in the back. Was going to put 15mm spacers in the front, but I need to get the right size bolts.
#57
Took my buffer/polisher to the outside. waxed n fresh'r n errrr.
#58
Put on those 15mm spacers on the front.Tonight - smoke Lamin-X on the tails.
#60
audiforums.com > whoretex > audizine.com > audiworld.com > honda-tech.com
#61
It really depends on which car you drive when it comes to what forum is best.
#62
Changed my plugs a couple of days ago. I'm not sure when they were changed last (maybe 20K ago? Previous owner probably had it done at the 40K service.). They weren't bad, but I didn't waste my time/$ with the change. Plus, it allowed the TT and I to bond.![]()
I called a friend about the damn fuel filter. He explained how the quick disconnect works...I'll give that another go this afternoon.
I'm gonna look for some ramps and a torque wrench this afternoon, too. I've been wanting both of those for a while. If all goes well, I'm going to install the ECS poly dogbone mounts today, too.![]()
#63
I just ordered poly FSB bushings to fix the creaking in my front suspension and a Neuspeed Rear Stabilizer Bar from TTStuff. Also got an air filter/cabin filter... timing belt, haldex, and oil being changed this Wednesday. Hopefully after all this I can recover financially and work on getting a DP/Exhaust and chip for the summer!
#64
Quote, originally posted by Phrost » It really depends on which car you drive when it comes to what forum is best. Agreed. The Vortex has a pretty good Corrado forum that is VERY active.
#65
Oil change - Castrol Syntec 5w-40
Fuel Filter change
Poly inserts for dog bonePaid somebody to do 'em for me.
Don't have a good place to dispose of oil (yet...);
Couldn't get the f*$%King quick disconnects on the fuel filter;
Got the dog bone off no problem, but couldn't get the center bolt out (I think that woulda needed some air tools and/or a vice...neither of which I have)Glad it's done. I like the shop: Got a recommendation for a great VW/Audi shop from a local. Turns out...the Audi division is visible from my porch!
Makes me feel good, in case I ever have to leave it over night. I'm rollin' up on 60K, so I'm trying to space out the stuff a little. I think I'll go for a Haldex and brake fluid change next. Then, TB/WB/etc.
#67
Changed up the air intake. Took the top part of the stock box off leaving the bottom part installed (mainly to revert back to stock when going to the dealer) installed a K&N cone filter and now it goes whoooooosh pshhhhh
#68
Quote, originally posted by DnA-TT » Couldn't get the f*$%King quick disconnects on the fuel filter; Don't worry - many a seasoned mechanic have broken them trying to get them off. I had someone else do it as well - actually when I had my TB done - did'nt cost me anymore.
#69
Thanks, Joe. My man-pride took a little blow from the fuel filter...I don't feel so bad, now.
#70
FINALLY got the parts together that i ordered. got the neuspeed 22mm front sway and a 1/2 kmac kit, both going in this week along with oil change, plug change, and alignment.my front sway is creaky as hell and im tired of hitting it with silicone spray to make the sound go away- time to cure it once and for all and upgrade in the process...
i was debating for a while whether to get the kmac or not because my drop is mild and there isnt THAT much neg camber, but the look has been bothering me, and i might as well save my tires a little more.
i seem to do mods in spurts usually when its time for an oil change, so the next episode after this one will be another oil change, haldex change, maybe some spacers, replace windshield (slightly cracked. thanks winter!) and finally get the driver's door latch sensor replaced...
| 40 Ford Panel RIP | 51 Chevy PU sold | 64 Chevy Belair current | 67 Mercedes 250S RIP | 76 BMW 2002 sold | 85 Volvo 240dl wagon RIP | 85 BMW 325e sold | 88.5 Suzuki Samurai JX sold | 91 Subaru Legacy sold | 92 BMW 318is RIP | 99 VW GTI sold | 01 Audi TT 225q RIP | 03 Audi A4 3.0q sold | 03 Jaguar 3.0 sold | 05 BMW 330xi sold | 06 Audi A3 current |
