VWVortex.com - VR6 Rebuild Kit
    Results 1 to 23 of 23
    Thread: VR6 Rebuild Kit
      Apr 9th, 2008
      WACAPA
      MK1, MK2
      04-30-2008 11:50 AM #1
      Hey!
      I would like to rebuild my vr since it's almost at 150,000.
      *Instead of piecing parts together, is there a rebuild kit that I could buy?
      *What major things should I replace?
      For all of you that have a lot less miles then me... LUCKY.
      Thanks!
      Modified by packin stussy at 9:59 AM 4-30-2008
    2. Member wide_load's Avatar
      Dec 6th, 2005
      Guelph, Ontario
      VRT, BT A4
      04-30-2008 11:53 AM #2
      MJM has some kits as far as rebuild goes. Depends how in depth the rebuild will be though.
      Apr 9th, 2008
      WACAPA
      MK1, MK2
      04-30-2008 11:55 AM #3
      I want to make sure I hit the major parts. I also don't want to be spending more then a $1,000. I'll probably do the work myself so that saves me more monayyy
    4. Member
      Apr 9th, 2008
      WACAPA
      MK1, MK2
      04-30-2008 12:23 PM #4
      Whats ARP Hardware?
    5. 04-30-2008 12:28 PM #5
      If u can do all the work urself.. get a billet crackpipe and thermostat housing kit. replace the the radiator hoses..timing chain kit..sachs OEM cluth.intake manifold gaskets.sparks n plugs...coilpack..headgasket.full coolant flush
    6. Member Biff Tannen's Avatar
      Jan 24th, 2005
      Hill Valley, PA
      '97 Passat w/ V, '01 GTI w/ V, '02 Jetta w/ T, '17 Jetta w/ T
      04-30-2008 12:29 PM #6
      Quote, originally posted by packin stussy »
      Whats ARP Hardware?
      And you're going to do this all yourself?
      Cost depends on how much has already been replaced on the car. If everything is original, then you're definitely going to need to spend more than $1000 to do it right. If you just want a bare bones rebuild, then $1000 will be ok, but expect to fix more things along the way, and also take into account things that will need fixing that you didn't know where defective (make sure you have enough left over money for this).
      Daily Driven
      Whatta you lookin at butthead
    7. Banned
      Jun 17th, 2005
      04-30-2008 12:42 PM #7
      I had my motor rebuilt about 6 months ago
      did:
      motor mounts
      axle
      pan and pump
      all gaskets in and around the motor
      chains were done
      rear main seal
      plugs n wires
      lightweight flywheel
      clutch was replaced 2 summer's ago
      mk4 HG
      valve springs
      lifters
    8. Member 1Qckcab's Avatar
      May 15th, 2006
      BMP 20th
      04-30-2008 12:42 PM #8
      Metal impeller water pump
    9. Member CrazyClutchVR6's Avatar
      Feb 22nd, 2005
      York, PA
      2002 Jetta
      04-30-2008 12:56 PM #9
      Quote, originally posted by 1Qckcab »
      no doubt
    10. Member
      Apr 9th, 2008
      WACAPA
      MK1, MK2
      04-30-2008 12:58 PM #10
      MauveVR: how much did that cost you?
    11. 04-30-2008 01:23 PM #11
      ahhhhh rebuilds!
    12. Banned BlakVRBeast's Avatar
      Dec 17th, 2006
      05-01-2008 01:07 AM #12
      Whats ARP Hardware?
      ARP makes hardware such as rod bolts , main and head studs , very strong and durable , def needed on boosted cars
    13. Member Jettin2Class's Avatar
      Jun 26th, 2002
      02 Passat Wagon
      05-01-2008 01:24 AM #13
      Quote, originally posted by BlakVRBeast »
      I don't know about needed, but definitely nice peace of mind. I've been boosted for 2.5 years, 10psi. No problems whatsoever. Plenty of people have gone beyond me with stock internals too.
    14. Member nfx's Avatar
      Jul 18th, 2004
      MD
      MK3 2.0T, 2013 Elantra GT
      05-01-2008 02:00 AM #14
      how much are they paying you?
      2.0T... it's back!
      Don't call it a build thread
    15. Member A2kameiX1's Avatar
      Feb 28th, 2007
      WA
      86 gti vr6
      05-01-2008 02:08 AM #15
    16. Banned BlakVRBeast's Avatar
      Dec 17th, 2006
      05-01-2008 02:16 AM #16
      Quote, originally posted by Jettin2Class »
      yes im aware of that , try 20+psi of boost on a stock block and see whats the first thing to go ...stock rod bolts and the weakest point in the engine and no ARP is not paying me , i use the stuff in my car so might as well let everyone know thats its good stuff
    17. Member mk2eurogirl's Avatar
      Apr 26th, 2006
      East heart West
      05-01-2008 03:42 PM #17
      bump for packin stussy
      Oh, Hai IG: @bethisloco
    18. 05-01-2008 04:13 PM #18
      edited for finding out myself.
      Modified by Let's pump iron! at 1:15 PM 5-1-2008
    19. Banned Mace_Windu's Avatar
      Jan 26th, 2005
      05-01-2008 05:24 PM #19
      If it ain't broke
      don't fix it
    20. Member Da_Mount's Avatar
      Jan 19th, 2003
      NC Triangle
      B6 Passat & MKIII Jetta GL
      05-02-2008 01:12 PM #20
      Sweet Dub and the sky is the limit when it comes to the cost of a rebuild especially when a machine shop is needed ... good luck.
    21. Member
      Apr 9th, 2008
      WACAPA
      MK1, MK2
      05-02-2008 01:16 PM #21
      Quote, originally posted by Da_Mount »
      if it was mine i would say thanks! but ill say thank you on behalf of the owner!!
      i think rebuilding my vr is just what it needs
      all i do is surf all day. so i should get another hobby lol and this is the perfect opportunity
    22. 10-01-2009 08:43 PM #22
      Dude if you don't know what ARP is then I think that you are not a mechanic and believe me repairing a motor is pretty complex. You need to test for cracks with dye penetrant you need to determine if your head is warped, you need to balance your rods, pistons go in at a 15% angle etc. . There is no point in just replacing if you cant determine if the way it is now is ok or if it needs machine work. If you open and realize that your pistons have caused indents in the cylinder walls, if you need to overbore. The head might need a full rebuild as well cause is you close it up and realize that oil is still passing means that your going to have to do it all over. Listen you dont have to take my word on this but rebuilding a motor you need very special tools torque wrench, snap pliers, feeler gauges to check wear, valve spring compressor, dial indicator, micrometer, compression tester. Well I wish you good luck but I doubt that this job could be considered a DIY job unless you are a trained professional or have access to trained profesionals to help you out.
      Good luck
    23. Member phil123's Avatar
      Aug 13th, 2009
      Irvine, CA
      10-01-2009 08:50 PM #23
      Quote, originally posted by koyo001 »
      Good luck
      Most ridiculous bumping of a thread goes to you.
      2017 MB AMG C43 | 2001 Cabrio VR-T | 1995 GTI VR6
      A2Resource |
      FS: MK3.5 Mirrors
