Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 71 to 105 of 167
Thread: Success! Finally Euro LED Tails installed without running wires!!!
  1. Member 9Schnell's Avatar
    Apr 7th, 2008
    Broadview, Seattle
    02-22-2009 01:29 PM #71
    Quote, originally posted by Mr_Peach »
    I'm digging in to mine now.
    Care to expand on your 'headache'? Probably too late for me.....
    I did mine last year, its pretty easy.
    I ran the wires up front tho.
    LMK if you need a hand.
    2013 S4, 2012 Tiguan SE w/roof & nav 4mo, 2012 Golf R - rip w/2328 miles, 2011 Tiguan S 4mo, 2010 CC Lux, 2009 Jetta S, 2008 R32, 2003 GTI VR6, 1998 GTI 2.0L, 1965 Type 1 2276cc
  2. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    2008 VW R32 :: 2000 MBZ ML55 AMG :: 2006 Mini Cooper S :: 2003 Aprilia Atlantic 500 :: Yam. Morphous
    02-22-2009 02:19 PM #72
    Quote, originally posted by davidraeside »
    I'm having a noob moment here. I bought the harnesses from ECS, but I need to move the pins around.
    I find instructions for moving the pins on the blocks that have the purple release tab, but I'm needing to move the pins on the other block.
    How do I do that?
    Quote Originally Posted by petef View Post
    ... you have no way of knowing whether the previous owner(s) was a civilized driver or a hoon like Peach.
    Quote Originally Posted by Dave Barry
    Wouldn't "Hoon Like Peach" be an awesome band name?
  3. 02-22-2009 02:40 PM #73
    it's easier to explain if you look at this thread:
    http://forums.vwvortex.com/zerothread?id=3358144
    Basically you release the purple clip, make a tool out of a paper clip as shown, insert the tool release the pin.
  4. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    02-22-2009 02:49 PM #74
    Thanks, I saw that.
    I want to modify the block that doesn't have the purple clip.
    Looking at the photo above, my three wires are in the wrong slots on the right hand blocks. I need to move two of them.
    Agghhh, it gets worse. I just figured out that what I thought was a splice in the ECS wire bundle is a diode.
    Anyway, I need to understand the basics of "re-pinning" these connectors before I can make progress.
    Modified by Mr_Peach at 11:51 AM 2-22-2009
    Modified by Mr_Peach at 12:05 PM 2-22-2009
  5. 02-22-2009 03:33 PM #75
    to repin it's pretty simple.
    if you're re-pining the other side without the purple clip you need to lift up the piece that locks down the pins. if you look at it carefully see a flat area you can lift up with a small flat screwdriver.
    yeah the ECS wires come with a diode. just remove the diode and cover with heatshrink or electrical tape.
    you just need to splice 2 wires to one.
  6. 02-22-2009 03:37 PM #76
    if you look at the pin itelf in the picture above there are two metal flares that stick out on each side of the male pin.
    to remove it, you release the flat black piece (be careful) then you need to stick a paper clip bent into a U to release the flares holding the pin.
  7. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    02-22-2009 04:45 PM #77
    Thanks.
    Still struggling with it.
    I'm guessing these pins aren't designed to be released.
  8. Member 9Schnell's Avatar
    Apr 7th, 2008
    Broadview, Seattle
    02-22-2009 04:49 PM #78
    Thanks.
    De-pin tool works magic.
    Heres a link to a cheap set that works ok.
    http://www.ecstuning.com/stage...Tools
  9. Member hmsa's Avatar
    Jan 20th, 2003
    2011 Audi A5, 2008 VW Tiguan
    04-05-2009 06:14 PM #79
    Quote, originally posted by r32-1163 »
    After all that, the Bulb out message wouldn't go away. Played with it for a bit, and here's how I got rid of the message, I turned on the one in red below:
    OP, is there a chance you still have that picture or could tell me which byte/bit you turned on to the get rid of the bulb out message?
    I've been playing for a couple of hours with my coding but nothing worked.
    TIA.
    Modified by hmsa at 6:20 PM 4-5-2009
  10. Member maotsetung's Avatar
    Mar 30th, 2009
    AIEA, HAWAII
    2012 Mk6 GTI CW, '98 B5 PASSAT (Broken), 2006 VW Jetta 2.5
    04-12-2009 12:09 AM #80
    does anybody know where i can get these connectors?..or if possible..any part numbers so i can try getting from the dealership..
  11. Member maotsetung's Avatar
    Mar 30th, 2009
    AIEA, HAWAII
    04-12-2009 06:14 AM #81
    bump
    Modified by maotsetung at 1:54 AM 4-12-2009
  12. Member hmsa's Avatar
    Jan 20th, 2003
    04-12-2009 11:43 AM #82
    Quote, originally posted by maotsetung »
    1K0-972-764.
  13. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    MKIV R32, MKV R32
    04-13-2009 09:52 AM #83
    Quote, originally posted by hmsa »
    TIA.
    I had that image somewhere, but managed to misplace it. Imagine that.
    I need it again as well.
    AWhiteRabbit | Do Not Buy From GrkTurbo
  14. Member hmsa's Avatar
    Jan 20th, 2003
    04-13-2009 02:37 PM #84
    Quote, originally posted by PSU »
    r32-1163 was very kind and sent me the link.
    Basically it's Byte 19, Bit 3 checked.
    Unfortunatelly, it didn't work for me.
  15. 04-13-2009 02:54 PM #85
    ...just run the wires..
  16. Member hmsa's Avatar
    Jan 20th, 2003
    04-13-2009 02:57 PM #86
    Thanks again to r32-1163 I could now clear the bulb out message.
    I missed clearing the DTCs after coding.
  17. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    MKIV R32, MKV R32
    04-18-2009 09:12 PM #87
    Quote »
    Thanks again to r32-1163 & hmsa I could now clear the bulb out message.
  18. Member
    Feb 8th, 2003
    Northeastern/Mid-Atlantic USA
    08/VW/MKVR32
    04-20-2009 01:18 AM #88
    I just wish someone would come out with an entire kit and instructions. That would work for me.
    Simple and no pain. Pure plug + play.
  19. 04-20-2009 04:05 AM #89
    Quote, originally posted by parklane »
    no one has anything like that yet, even so, there are already 2 proven ways to do this.
    1) Run the Wires
    2) Build the harness, splice the stock wires, or solder in the headlights.
    Both of which requires VAGCOM to complete the job.
  20. Member Mr_Peach's Avatar
    Sep 18th, 2007
    Woodinville, WA
    05-03-2009 03:52 PM #90
    Got mine working, except for the rear fog. These threads helped a lot.
    Some thoughts:
    Using the ECS harnesses, I had a couple difficulties - the harnesses weren't built right, even for a Jetta, so I was doing some mods on the "purple clip" side that I didn't think I would need to do. I think I totaled the purple clip on one, but it still works OK.
    The second difficulty I had with the harness was that they should be "handed"; the left harness is different from the right harness. I built two "lefts" and it was obvious when I was plugging in the right one that I had goofed; the wires were all shifted one position.
    After doing the coding from speedbump, they worked fine for a day. Then today, I got a "bulb out" diagnostic, along with an MFD message about the right brake light. I could observe the right parking light was either not on or very weak. Thinking it had to be a coding error (or DTC clear error), I of course cleared my codes a couple times. Finally I pulled apart the right taillight again and discovered I had pinched a wire under the stud, shorting it to ground intermittently. Sometimes a fault is truly a fault.... And of course *this time* I dropped the damn nut down the fender 15 minutes with a flashlight, dental mirror and magnetic pickup tool saved that one.
    As for the rear fog light: I connected the trigger wire to the switch, and I pulled off the lower dash cover to access the ECU. I then moved the seat and tried playing "twister" to get my large middle-aged self under there a few times before I decided I would be royally pissed if I slipped a disc or something trying to do this. Either I need to pull the seat completely out, hire a twenty-something to do this, or settle for no rear fog light (those grapes are probably sour anyway....)
  21. 05-03-2009 04:05 PM #91
    on all the videos on youtube it looks like the lights are flickering... is it just bc of the camera or do these lights have a slight flicker?
  22. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    MKIV R32, MKV R32
    05-03-2009 07:51 PM #92
    Quote, originally posted by FreeGolf »
    Camera.
    Even my cell phone causes the lights to flash.
  23. 05-03-2009 07:56 PM #93
    gotcha... kind of reminds me when you film the television you sometimes get that flicker...
  24. Member MattWayMK5's Avatar
    Dec 16th, 2006
    North NJ
    2007 Rabbit, 2012 Jetta TDI
    05-12-2009 08:24 PM #94
    Installed my lights today and everything works perfectly except when I turn my parking lights on the center of the tail is red like it should be but the outer ring is amber. When I step on the brake the center lights up brighter red and the outer ring lights up brighter amber. Any ideas on why this isnt red? As I turn the signals on they flash between red and amber but im pretty sure they outers should be red when just the parking lights are on.
  25. Member nikhsub1's Avatar
    Apr 17th, 2008
    Los Angeles
    2011 JSW TDI 6MT
    05-12-2009 08:29 PM #95
    Quote, originally posted by MattWayMK5 »
    Where is facepalm? It is mentioned like 50 times that you need VAGCOM to fix that.
    Revo Tune / afe Intake / Neuspeed Turbo Exit Pipe / Mufflerectomy / ST Coils / Superpro LCAs / 25mm BFI RSB / Golf R Steering Wheel & Shifter / DG Short Shift Kit / RNS-510 / MKV R32 Brakes Front & Rear / Euro Golf R HIDs / Nurburgrings / S53 Whispbars
  26. Member MattWayMK5's Avatar
    Dec 16th, 2006
    North NJ
    05-12-2009 08:34 PM #96
    Quote, originally posted by nikhsub1 »
    I did every change in vagcom that is suggested in here
  27. Member nikhsub1's Avatar
    Apr 17th, 2008
    Los Angeles
    2011 JSW TDI 6MT
    05-12-2009 08:44 PM #97
    You did this too?
    Amber coding by Sparkstack:
    After Coding
    Byte 9: 0F
    Byte 13: 00
  28. 05-12-2009 09:05 PM #98
    If you did then it should work. I doubt ours are flukes, lol.
  29. Member MattWayMK5's Avatar
    Dec 16th, 2006
    North NJ
    05-12-2009 09:06 PM #99
    You did this too?
    After Coding
    Byte 9: 0F
    Byte 13: 00
    I did that except I have 0A on Byte: 9 Because when I enter 0F it says there is a code error
  30. Member MattWayMK5's Avatar
    Dec 16th, 2006
    North NJ
    05-12-2009 09:13 PM #100
    Ok I got it fixed now. I entered Byte 9 as 0F and Byte 13 as 00 at the same time. If I tried to just change Byte 9 it would switch Byte 13 to 14 automatically. Thanks so much guys. A big to the both of you
    Modified by MattWayMK5 at 9:17 PM 5-12-2009
  31. 05-12-2009 09:21 PM #101
    Great.
    To avoid more confusion, reposting the long code again
    Note, DRLs are turned off and Rear fog is not enabled. (you can modify as needed after you clear the bulb error)
    Modify the code, clear DTCs and you're good.
  32. 08-31-2009 07:36 PM #102
    i have a gti 07 with hella led tails. i get a light out fault every time i turn my parking lights on and use my driver side blinker. even when the code is on the blinker will blink 5 times and then stop. can you please help me with this situation? thanks
  33. Member DarkNeo's Avatar
    Jun 18th, 2004
    SoCal
    Golf R32
    06-26-2010 05:20 PM #103
    Quote Originally Posted by davidraeside View Post
    I did the same too... thanks for all your help!
    Currently my harness looks like this:
    I guess I have to move the wires on the female plug down. Pin 1 down to pin 2 and pin 2 down to pin 3. How the hell do I pull the wire out?
    Official OG '08 .:R32 Owners Club Member
  34. 06-26-2010 08:33 PM #104
    the pin removal tool or a thick paper clip.
  35. Member DarkNeo's Avatar
    Jun 18th, 2004
    SoCal
    Golf R32
    06-26-2010 10:50 PM #105
    Quote Originally Posted by r32-1163 View Post
    It a bitch to get the pins out from the female plug, its impossible
