VWVortex.com - replacing coolant flange
    Results 1 to 9 of 9
    Thread: replacing coolant flange
    1. 05-03-2008 11:42 AM #1
      have to replace leaking coolant flange today, is it possible to do it without draining the radiator?
    2. Senior Member bluefox280's Avatar
      Dec 18th, 2003
      Broomfield, CO
      05-03-2008 12:58 PM #2
      Its' possible, but you'll still naturally drop coolant thats in the hoses and the upper half of the system...
      - ERik
      PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
    3. 05-04-2008 10:24 AM #3
      how many miles is on your car?
      You play PC Video Games, click on this!
      http://www.facebook.com/pages/I-Hate...14689205221694
    4. 05-04-2008 12:42 PM #4
      about 92,000 miles
    5. Member BORA_1_8T's Avatar
      Dec 20th, 2005
      Albuquerque, NM/El Paso, TX
      MKVI GSW TDI
      05-04-2008 12:48 PM #5
      it's not to hard and you will also drain whats in the overflow tank and here is a tip I learned when i did it on my car make sure the engine is cold Hot coolant really really burns
      Back in a Dub again
    6. Member
      Nov 27th, 2004
      Charlotte, NC
      2000 VW Jetta VRT, 2000 Audi TT Quattro
      05-04-2008 01:03 PM #6
      Don't forget to open the coolant reservoir. This adds an alternate vent path and allows for quicker and more complete draining.
      Mike
      Chapter 11 Dubs: Member #001
      http://www.chapter11dubs.com
    7. 05-04-2008 05:03 PM #7
      thanks for the advice!
    8. 05-04-2008 05:11 PM #8
      i had my car overhead due to a bad waterpump. this melted my coolant flange to the point of replacement.
      when i replaced mine, i of course drained and flushed the coolant system.
      whatever you do, be sure to replace the coolant with the G12 coolant.
      if you dont, the coolant will "gel" and seize up the waterpump, leaving you with having to replace the pump again.
      also, if you need to replace the pump, look into a metal impellar, and not the cheap plastic ones that come OEM.
      i wish you all the best of luck
    9. 05-04-2008 05:12 PM #9
      i cant help but you reminded me i need to fill mine
