VWVortex.com - ABA wiring diagram??
    Results 1 to 6 of 6
    Thread: ABA wiring diagram??
    1. Awaiting Email Confirmation Racer16's Avatar
      Aug 21st, 2002
      NNJ
      2000 audi s4,2001 a4,1999 a4,2002 gti,86 gti,85 scirocco,91 corrado,91 jetta gli,2000 passat
      05-07-2008 05:51 PM #1
      Anyone have a engine harness wiring diagram for a late 2.0 aba gti???1998 Gti 2.0 5 speed.I need the wiring harness diagram for the engine harness.I search but couldnt find any links that work.
    2. Member hockeystar17mnj's Avatar
      May 30th, 2007
      Northern NJ
      2010 GTI
      05-07-2008 06:03 PM #2
      BENTLEY
      Garden State Euros Northern New Jersey Tri-State European Car Club
      Current: 2010 vw GTI
      mods: APR carbonio stage 1&2 intake, APR K04 flash, AWE turbo outlet pipe, B&B DP, Magnaflow catback, Diesel Geek shifter, APR 27mm Rear Sway bar, autotech dogbone insert,BSH recirc. catch can, Southbend Stage 3 clutch disk, K04!!
    3. Member Wishing on a Vr's Avatar
      Feb 7th, 2003
      Good Ol' Jerzy
      A2 jetta carat, Built 2g GST, Full race 1g talon,Mk3 cabrio VRT, R32T MK3 JETTA, MK4 12v VR6 Jetta
      05-07-2008 07:23 PM #3
      you looking for the j28 plug diagram?
      1996 Jetta-3.0L 24v/R32 Head. Gt4294, Custom SRI, PTE 1000 A/w intercooler Haltech PS1000. List goes on.
      1995 Cabrio-OBD 1 12v Vr6 Stock Block with ARP hardware, ATP Exh Manifold, 60-1,Tial 38mm WG, HKS SSQ BOV, Custom SRI, ATP FMIC, Lugtronic
    4. Member Wishing on a Vr's Avatar
      Feb 7th, 2003
      Good Ol' Jerzy
      05-07-2008 07:37 PM #4
      http://mysite.verizon.net/e.se...iring
      Idk if this helps but its a start.
    5. Awaiting Email Confirmation Racer16's Avatar
      Aug 21st, 2002
      NNJ
      05-08-2008 07:15 AM #5
      Yes that does help.As i need this to figure out which plug i need for my 20v swap thanks.I'm guessing T68 is all the wires coming from the ecu???Can anyone confirm this???
    6. Member Wishing on a Vr's Avatar
      Feb 7th, 2003
      Good Ol' Jerzy
      05-11-2008 02:08 PM #6
      Heres the link I think you need..do a search on Boostin20v he should be able to help you out if you got anymore questions http://monty.syr.edu/swap/wiring.htm
      Modified by Wishing on a Vr at 2:10 PM 5-11-2008
