VWVortex.com - TDI routine maintenance
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 38
    Thread: TDI routine maintenance
    1. 05-09-2008 06:41 PM #1
      I just bought an '06 Jetta TDI. I'm not new to cars but I am new to turbo diesels. Any tips besides just changing oil?
    2. 05-09-2008 06:57 PM #2
      Just go by the owners manual on the maintenace stuff. And make sure you only use vw approved oil. If you use anything else you will damage the cam and lifters and it will cost over 3000 to fix.
    3. 05-09-2008 11:30 PM #3
      Major Volkswagen Scheduled Maintenance #1
      40K Service all Engines include
      Tire rotation, oil change, engine oil filter, top off all fluids, inspect front and rear suspension, inspect exhaust system, inspect engine for oil leaks and coolant leaks, inspect Cv boots, inspect brakes, inspect drive belts, inspect timing belt, Replace: spark plugs, air filter, pollen filter, check and top off battery electrolyte level, lubricate all doors, lubricate sun roof, check all lights, check all systems for fault codes, road test Vehicle.
      Change your oil every 5,000 miles.
      Also due at 80,000, etc
      TDI engines only -- Drain water separator
      (Through 2001 TDI Engines) Replace timing belt and tensioner at 40,000 miles. (Automatic Trans Only)
      (2001 and Newer) *Replace timing belt At 80,000 miles, highly recommended to avoid severe engine damage to 1.8T, 2.0L, 2.0T & 2.8L engines, it is also recommended to replace the water pump along with the timing belt to avoid engine overheating in the event of the water pump properler braking, therefore having to do the repair all over again and paying labor twice. Volksguru.com [IMG]http://*****************.com/smile/emgift.gif[/IMG]
    4. 05-10-2008 05:30 PM #4
      5,000 per oil change??? The PD engine can go for ten with proper 505.01 oil.
    5. 05-11-2008 02:51 AM #5
      Volksguru needs to get updated.
      Come on over to TDIclub.com for some better info.
      And don't take it to the dealer.
    6. 05-11-2008 11:33 PM #6
      whatever dude! the recommendation by the manufacturer Volkswagen is every 5,000 MILES not 10,000 follow the rules on how to maintenance your car. [IMG]http://*****************.com/smile/emthdown.gif[/IMG]
    7. Senior Member
      Mar 24th, 2001
      05-12-2008 12:52 AM #7
      Quote, originally posted by HBone80 »
      For 2004-2006 TDI engines sold in the US, be sure to use VW 505.01 rated oil. Oil with this rating is not commonly found in the usual auto stores; you may have to buy it at a VW dealer or from some internet mail order parts place.
      You did get service records listing the correct oil, right?
    8. Senior Member
      Mar 24th, 2001
      05-12-2008 12:55 AM #8
      Quote, originally posted by ABIMELECH »
      Go to: http://www.vw.com/myvw/yourcar...en/us/
      Select 2006 Jetta TDI
      Give various mileages
      You will find service intervals every 10,000 miles after the initial two at 5,000 and 10,000 miles.
    9. 05-12-2008 05:46 PM #9
      The rules for oil changes BY VOLKSWAGEN is every 10,000 miles after the initial two 5,000 mile oil changes.
      MY2002 ALH engines got a revised timing belt which pushes the timing belt change to 80,000 miles.
      MY2003+ ALH got a revised rollers which pushes the change to 100,000 miles.
      MY2004+ PD's are 100,00 miles for the timing belt.
      Since we are talking about MKV's, the timing belt is still at 100,000 miles, with the oil changes at 10,000 miles (after the initial two oil changes at 5,000 miles each).
      Fuel filter changes: 20,000 miles (get a Mityvac to assist in doing the fuel filter changes).
      Water separator: not really needed unless you get really crappy diesel.
      The key to diesel is buying from high volume places, so that the diesel stays fresh.
      In the winter months, use a high quality Anti-gel additive, such as Stanadyne One-Shot All-season formula (which is endorsed by VW). Many of us, use Power Service Diesel Fuel Supplement.
      Air filter: Pay extra money for the cold weather filter, which has a layer of foam glued to it, to prevent snow from soaking into the paper filter element, and acts as a pre-filter.
    10. 05-12-2008 08:51 PM #10
      Quote, originally posted by GT17V »
      Mk5s fuel filters don't have a water separator, it's all one unit, you can't drain it like you can on earlier cars.
      Mityvacs aren't that helpful with Mk5s either as they have an in-tank tandem pump.
    11. 05-12-2008 09:28 PM #11
      Dealerships change the oil on all the Volkswagen engines every 5,000 miles, at least the (2) dealerships I have Work for. Do you know or have any idea of whow black is that oil after 5,000 miles imagine 10,000 miles it will blacker and thicker, but that's your choice you go ahead and do what you want after all is your car. About timing belts! Do you you want to talk about timing belts? Lets Do it Because I am very good at it, Dude! I have seen Several Timing belts broken between 80 and 85, we recommend the timing belts at 80,000 just to be safe, I do replace the tensioner,the upper idler roller and the (2) lower Idler rollers obviously along with the timing belt, we also recommend the water pump due to the plastic propeller. We explain the customers and they make the decision if they want to do it or not, but our job as Volkswagen professionals is to inform our customers of what could happen, because we have seen it several times before and our job is to protect their investment. And by the way I was only talking about oil changes. Have a nice day.[IMG]http://*****************.com/smile/emgift.gif[/IMG]
    12. 05-12-2008 10:59 PM #12
      Dealerships at their own discretion can recommend more servicing than what VW calls for.
      Onto the topic of oil.....
      Color is not an indication of oil condition.
      let me emphasis this again
      COLOR IS NOT AN INDICATION OF OIL CONDITION
      Try pulling the dipstick on a TDI a few minutes after an oil change--- instant black. This is why you cannot judge the oil by its color. This is why you get the oil analyzed. VW spec oils will easily last 10,000 miles based on oil analysis.
    13. 05-12-2008 11:21 PM #13
      You don't think I know that I would be stupid if after (9) years of WORKING on Volkswagen TDI'S I didn't Know that there is some oil left inside that engine and that the new oil kind of rinse it off therefore turning the new oil black as well. I was not judging the oil by its color. Obviously you don't get my point of the importance of oil changes every 5,000 miles. I could explain here the whole theory, why the engine oil gets black the way it does in TDI'S engines but now I am wasting my time.
    14. 05-12-2008 11:26 PM #14
      changing the oil too early on the TDI, has proven itself on OCI's to be detrimental to engine wear--- OCI's have shown, 5,000 mi oil changes on TDI's to increase wear vs. 10,000 mile oil changes, using VW specification oil.
      Also, 505.01 oils have a weird property to shear down initially, then its viscosity increases back up as it absorbs soot.
      There is theory, and then there is reality. Sometimes the two don't match up.
    15. 05-13-2008 12:00 AM #15
      I also Know what is soot, A particle made primarily of elemental black carbon, wich is found in diesel engines, soot warms the air by absorbing sunlight and radiating the heat to the air. this is also another reason to have the oil change done every 5,000 miles. About increasing the engine wear for doing the oil changes every 5,000 miles thats not true. We are not talking about heavy machinery hear we are talking about a diesel car. I know a customer that owns a 1998 BEETLE 1.9 TDI WITH 241,000 MILES and he has always done the oil changes every 5,000 miles since he bought the car and still runs like a Champ. So next time you are ready to do your 10,000 miles oil change, before you drain your oil completely take a sample and look at it tell me what you see. [IMG]http://*****************.com/smile/emgift.gif[/IMG]
    16. 05-13-2008 08:35 AM #16
      I have -02 Passat 130hp pd. VW LongLife serviceinterval for 02-03 cars could be as long as 31 000 miles with 506.01 long life oil.
      I'm using 507.00 rated oil changing it every 12500-13500 miles. Color doesn't tell anything in diesels because it turns black in 200miles.
      For TDI most important is changing air and fuel filter at least once a year especially if you live in cold climate area and use summer and winter spec diesel.
    17. 05-13-2008 01:20 PM #17
      Oh, you work for a dealer, that explains quite a bit.
      Were those 80k broken TBs on cars with 100k kits? Do you also change the stretch bolts?
      As some one said, in Europe with ULSD you can get 30,000 miles out of an oil change if you do proper sampling.
      I see your 2 broken TBs and raise you the 14 dealer botched jobs we found off the top of our search: http://forums.tdiclub.com/show...unt=1
      and the 4 dealer botched jobs oilhammer himself has done THIS YEAR alone http://forums.tdiclub.com/showthread.php?t=141633
    18. 05-13-2008 01:27 PM #18
      Why is sunlight getting into my engine? I'd think that I would have bigger problems.
      Quote »
      And the difference being? People have SHOWN, with oil sample analysis that you do have increased wear with shorter OCIs. No touchy feely 'oo look at the black oil' they actually got the numbers.
      Quote »
      241k? that's it. That car's a Baby. Talk to us in another 150k.
      Quote »
      You can't *see* anything. It's black. Why not do an Oil Sample Analysis and compare it to the dozens taken by TDIClub members? http://forums.tdiclub.com/showthread.php?t=154548
    19. 05-13-2008 10:35 PM #19
      I don't care you can't argue with me, I have seen what I have seen and you don't. [IMG]http://*****************.com/smile/emgift.gif[/IMG]
      Modified by ABIMELECH at 6:41 PM 5-13-2008
    20. 05-13-2008 10:45 PM #20
      Quote, originally posted by anony13 »
      Frequently Asked Questions Volksguru.com
      How often should I change the oil in my Volkswagen?
      Every 5,000 miles, on turbo engines it is highly recommended to use synthetic oil by Volkswagen and by Volksguru.com TDI Engines use synthetic oil as well but it is specific for this engines.Castrol SLX OR TXT 505.01 Professional Motor Oil.Use oil viscocity 5W40 or if not available 5W30. Really
    21. 05-13-2008 11:10 PM #21
      Ummm... how does sunlight affect the oil INSIDE my engine?
      It sounds like you are throwing out quasi-technical jargon to try to impress people.
      Nine years eh? Would you be surprised to know that there are MANY people that have MANY more years working on Diesels (be they VW or otherwise) that can see that you are inaccurate in your statements and have the information to back up their statements?
    22. 05-13-2008 11:51 PM #22
      Volksguru.com
      You're either a shill for volksguru or an idiot.
    23. 05-13-2008 11:56 PM #23
      He is Volksguru.
      Judging by his location... he probably works for Stuart VW.
    24. 05-14-2008 04:41 AM #24
      Old TDI's need 505.00 oil. Newer PD's need 505.01 oil for normal oilchange interval = 10 000 miles
      LongLife system that we have in Europe specification is 506.00 which is 0W-30 and 507.00 / 5W-30
    25. 05-14-2008 10:56 AM #25
      O man shut up with the 5k change interval ALREADY!!! Its 10k and motor happy. Anybody who wants to learn something come over to the tdiclub everyone else can remain in there own bubble
