VWVortex.com - disable DRL
    Results 1 to 6 of 6
    Thread: disable DRL
    1. 05-17-2008 11:43 PM #1
      how can you disable a jetta drl...day light running lights
    2. 05-18-2008 10:43 AM #2
      Probably need a Euro switch if they make one. Was 05 the new body style? I noticed that, unlike some cars, the lights seems to be the same brightness on DRL as when on. At least on my 2002.
    3. Member 77kafer's Avatar
      Jul 29th, 2004
      New Windsor, NY
      '77 Standard Beetle, '92 Cabriolet, '96 Golf Harlequin, '03 Jetta Wagon, '13 Tiguan SEL
      05-18-2008 10:59 AM #3
      If it is a Mk5 then you need to disable DRL with VagCom. Euro switch will only allow the use of parking lights (front and rear) as running lights after DRLs are disabled.
      Supposed to be 77käfer, but there are no umlauts on an american keyboard
      Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
    4. 05-19-2008 11:32 PM #4
      ive only been in a mk5 once, but if its the same as a mk4, turn the headlight switch all the way to the left, push in, and push back to the right, itll come out. then take the harness of and youll see the metal tabs with lettering. take a key and push down the one that says TFL. then put it back in. rinse lather repeat
    5. Member 77kafer's Avatar
      Jul 29th, 2004
      New Windsor, NY
      05-20-2008 06:54 AM #5
      Quote, originally posted by 16vjetta_gli »
      It is not the same as a mk4, that is why you have to use a VAGCOM.
    6. 05-20-2008 02:23 PM #6
      Owning a MKV and having turned off my DRL's you need Vag-Com.
