VWVortex.com - Oil change: how to guide for 2006 2.0T Passat...???
    Results 1 to 5 of 5
    Thread: Oil change: how to guide for 2006 2.0T Passat...???
    1. 05-18-2008 05:48 PM #1
      Any how to guides or, if not necessary, tips on changing oil in an 06 2.0T Passat???
      I bought the filter and realized it's not what I am used to. I plan to run the Amsoil 5w-40 European.
      Thanks in advance for any info.
    2. 05-18-2008 09:31 PM #2
      the biggest difference the oil filter.
      This thread below is a good thread to use.
      http://forums.vwvortex.com/zerothread?id=2918689
      you need to buy a 36mm socket wrench for the oil filter removal.
      YOu can get the oil filter drain tool (if you want to spend the extra money) from http://www.ecstuning.com
    3. Member panabrite's Avatar
      Sep 14th, 2007
      07 Passat wagon
      05-18-2008 10:10 PM #3
      I just replied to that old thread ..oops
      Can't you just put a wrench on the oil pan plug and drain into a pan and put a set of channel locks on the filter housing and drain and remove cartridge ..
    4. 05-18-2008 10:14 PM #4
      Quote, originally posted by panabrite »
      the oil drain plug is no different from any other car-- you can use a wrench. THe link is the best one I can find, that describes the oil filter, which happens to use a Pella pump.
      The filter housing, I would not use channel locks, unless you really want to destroy the housing (which is very thin plastic) and screw up. Use the right tool for the job. The socket isn't that expensive.
    5. Semi-n00b
      Nov 6th, 2016
      Wisconsin
      MK6 Golf R, MK5 Jetta, B5 S4, B5 A4, B8 A4, B5 Passats (2)
      04-04-2017 12:33 AM #5
      Heres a quick video to walk you through the process! Good luck!
      https://www.youtube.com/watch?v=BOoXC98Y4Do
